Installed V and F code springs - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Power Stroke Excursions
Old 07-20-2007, 02:15 AM   #1 (permalink)
Hey all,
I just got through installing V and F code springs and noticed a couple of things: 1) the truck seems to be making a sound when steering from lock to lock--sort of a thunk, about a full steering wheel turn before the stop. 2) Also, now the front Husky molded mud guards rub the tires when turning in on either side, especially the passenger side. I removed the 4" lift the truck came with, and it didn't make any sounds when steering before. Has anyone had these issues after the spring upgrade? I'd really appreciate any feedback.
Thanks.
jsanchez is offline
Old 07-20-2007, 12:15 PM   #2 (permalink)
Feedback Score: 3 reviews
Re: Installed V and F code springs
Its dot the spring its the track bar..did you tq it to over 380lbs?
Cary
Cary
caryt is offline
Old 07-20-2007, 12:45 PM   #3 (permalink)
Cary,
I had an installer do the job--he came highly recommended. I'm going to have him look things over; what should I have him look for?
jsanchez is offline
Old 07-20-2007, 01:13 PM   #4 (permalink)
Nope. I didn't have any strange noises or interference with the Husky flaps. However, I am running the stock 265/75/16 tires. What size tires do you have? I have heard that 285/75/16 tires will rub those flaps.
2001 Excursion Limited 4X4, V10
Done so far:
Rear Hellwig (#7643),
Front Poly Frame Mount Sway Bar Bushings (Energy Suspension #4.5180G),
Gen II Landyot Radius Rods,
Rancho RS9000X's (RS99267 front, RS99266 rear),
Rancho steering stabilizer (RS5410),
Super Duty Front Bumpstops (F81Z-3020-DA)
Domelight & Foglamp overrides, Heated & Lighted TT Mirrors, Silverstars, Husky Floor & Cargo Liners, Husky molded mudflaps, V10 badges, OEM clear headlights & corners, latex tubing in door weatherstrips
U Code Front Springs (2C3Z-5310-GA),
F Code Rear Springs (6C3Z-5560-F) with added leaf from original spring pack (the 38" long leaf, 3rd from bottom, not including anti-wrap leaf)
Landyots Removed during spring change, may add Gen IV's in the future as an experiment
<span style="color: blue">2001 Excursion Pictures and Mods</span>
towrig is offline
Old 07-20-2007, 04:58 PM   #5 (permalink)
Towrig,
I have 265/70/17 on the X--it is an '05 EB 4x4 6.0. I looked at the mud guards and it looks like I'll have to trim about 1.5" from the side that's toward the frame to clear the tires as I'm turning. I'm not sure what might be making that sound? Cary mentioned the torque on the track arm--anyone know about that?
jsanchez is offline
Old 07-20-2007, 05:22 PM   #6 (permalink)
FamilyRide's Avatar
Husky's and 285's and mine doesn't rub anywhere. It didn't at stock height and still doesn't with the V codes. One side looks close, but no rub at all.
2004 EB Excursion, 4x4, 6.0, Magnaflow Exhaust, Isspro Gauges in an under cubby pod, Fumoto, V code front springs, Revo 285's and bubba lights
FamilyRide is offline
Old 07-20-2007, 05:49 PM   #7 (permalink)
Guess I heard wrong. I am glad they will fit though. My next set of tires will be the 285's.
Done so far:
towrig is offline
Old 07-20-2007, 10:18 PM   #8 (permalink)
A pop noise is more related to the trackbar ..have him use a 5' extension to a 3/4 T bar and use locktight and get it TIGHT! No impact will get it tight enough.
Only other thing it could be is ball joints, they can pop when getting worn.
One other thing all shackel and spring bolts should be left lose till the truck is on the ground then tq'ed with Locktight.
Cary
Cary
caryt is offline
Old 07-20-2007, 10:28 PM   #9 (permalink)
Cary, thanks for the info. I'll have the guy check the trackbar and ball joints. Although, I only have 30k miles on the truck. I'll let you guys know how it goes.
Thanks again!
jsanchez is offline
Old 07-20-2007, 11:49 PM   #10 (permalink)
FamilyRide's Avatar
Since it had a 4" lift on it before, was there maybe something that was done then that didn't change that should have when going to the V and F's.
Old 07-21-2007, 12:04 PM   #11 (permalink)
Did you install a adj track bar? Mandatory with a lift.
Cary
Cary
caryt is offline
Old 07-21-2007, 12:13 PM   #12 (permalink)
FamilyRide's Avatar
Cary
Ya, that's what I meant. [img]/ubbthreads/images/graemlins/phoney.gif[/img]
Old 07-21-2007, 12:52 PM   #13 (permalink)
If I understand you correctly, the 4" lift came with a dropped pitman arm and a longer/lower bracket for the trackbar. These were replaced with factory parts. Just to be sure, is the trackbar the same as the panhard bar? The stock one was used even with the lift, and I didn't add one that's adjustable.
jsanchez is offline
Old 07-22-2007, 11:32 AM   #14 (permalink)
Track or pan same thing. If when the X was sitting on the ground you could put the Track bar bolt back in "without" forcing the Axel over to install the bolt then you don't need one.
Cary
Cary
caryt is offline
Old 07-22-2007, 04:17 PM   #15 (permalink)
Thanks for the info.!
jsanchez is offline
