Instruments went up, then died, the came back to life - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Power Stroke Excursions
Old 05-02-2007, 03:59 PM   #1 (permalink)
I have an 04 Excursion w/03 6.0L pulling 10000 travel trailer. While pulling my travel trailer last week, straight level road, constant speed, my instruments went to the high side, speed 100, RPM maxed out, fuel gauge full, temp gages high side, everything went to high side, motor (6.0L) just running normally, all warning lights went on, then everything on instrument panel died, everything looked just like I had turned off the motor. Radio still worked, my engine running normally, then everything came back on normally. Only happened that one time, lasting maybe 5-6 seconds for all to occur. Anybody have an experience like that before? I pulled my trailer over the same road in the opposite direction a few days later, everything worked fine for entire trip. Thanks for the help. I really don't know where to look on this one.
luckeyd is offline
Old 05-02-2007, 07:03 PM   #2 (permalink)
Dunbar's Avatar
Re: Instruments went up, then died, the came back to life
You must have run through a class II paranormal poltergeist. Was there slime on the outside of your truck afterward? If so call ghost busters before traveling on that side of the highway next time.
Good luck with the gremlin and I will watch out for similar behavior.
David
David Dunbar
2003 4x4 7.3 Excursion Ltd
4" exhaust, Tymar DIY, Vcode & modified Fcode, Helwig, Inappropriately valved Bilsteins, Isspro 3 gauge w/ windshield mount, DP tuner 80-60tow-40tow-HI, 6.0 31-row ATF cooler,
BTS Transmission, DI Up pipes
Tomball Texas
Dunbar is offline
Old 05-02-2007, 11:11 PM   #3 (permalink)
I think every thing you are talking about is on the "Bus"
A twisted pair or three wires that run around the vehicle instead of discreet wires
Sounds like this "Communication System" went down for a moment
Think of it as a robust Ethernet but handling smaller simple packets of info
We have been using this in industry for many years in many ways it is more reliable than a bunch of single discrete purpose wires.
I don’t have a problem with ford going to this type of system it is cost effective and fairly reliable, understanding that any system can fail.
Like Ethernet or any system like this it can have a problem from interference.
I would wait and see if it repeats, it may never do it again
Bruce
Bruce1954 is offline
Old 05-03-2007, 09:39 AM   #4 (permalink)
Thanks Bruce1954,
I understand your explaination as I work in the computer industry. It is a reliable system, maybe as Dunbar said, there was a poltergeist on that side of the road. At any rate, it hasn't happened since then, but it will sure get your attention when it does. Thanks again.
luckeyd is offline
