ISSPRO gauges - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Power Stroke Excursions
Old 10-28-2009, 06:38 PM   #1 (permalink)
njneer1's Avatar
ISSPRO gauges
On the website the ISSPRO install pdf says to run the pyro thermocouple inside through the firewall by removing the plug for the clutch. Does an Excusion have this since they were not offered in manual trans ? I didn't see it when I installed Fog lights on my 2000. I would think there would be more manual trans conversions if it did.
2000 Limited, 118K, 7.3L, 285 Cooper ATR's, super chips 1705 on tow/performance, Bilsteins, Isspro EGT/Boost/ Trans temp.
1997 4runner,5spd,TRD supercharged,Bilsteins,H&R coil springs front and rear
1968 roadrunner,383,4spd
1970 roadrunner,383,4spd,pistol grip,58k 0riginal miles
1970 Charger,383,4spd,pistol grip,my first car
njneer1 is offline
Old 10-28-2009, 09:04 PM   #2 (permalink)
njneer1's Avatar
bump....need help
njneer1 is offline
Old 10-29-2009, 12:16 PM   #3 (permalink)
It didn't occur to me that the hole that I used would have been for the clutch when I did my install, but that's exactly what I used.
BTW, next time you're ready to replace your warped rotors try ART rotors. They're not cheap, but you won't regret it. I think I've had mine over 4 years and more than 100k miles with no issues. I replaced the front pads last fall, but that was only because the drivers side hub failed on me and destroyed the pads. Prior to ART I think I replaced my rotors at least once a year!
Dave
2000 Excursion XLT - 4X4 - Black/Gray - Power Stroke - ART Rotors - MBRP 4" turbo back - AFE stage II - FTVB - V & B code Swap - Rancho RS9000's - Hellwig rear sway bar - Firestone air bags - ISSpro EV Gauges - ISSpro TTM - DP Tuner F5 : no start, stock, 40TC, 60TC, 80EC, 120RC - 4x2 Lift Gate Cylinders - UVCH Quarter Mod - Fumoto drain valve.
JDWHITTAKER is offline
Old 10-29-2009, 02:58 PM   #4 (permalink)
njneer1's Avatar
Thanks, I wonder why no one is switching Ex's over to manual trans if the clutch cylinder hole is there ?? I would love mine as a manual trans.
Thanks for the rotor tip also! What's the purpose of the 4x2 lift gate cylinders ?
njneer1 is offline
Old 10-29-2009, 03:11 PM   #5 (permalink)
You're welcome. I don't know why nobody's switched over to a manual tranny. I'd prefer it too, but nobody ever talks about it, so I didn't give it much thought.
4X2 lift gate cylinders lift the gate a couple of inches higher. I think due to the higher ride height of the 4x4 model, the lift cylinders were shortened in an attempt to be able to lift the gate while the excursion is in a standard garage. Either that, or so that short house wives can still reach the gate on the 4x4 excursion. I'm 6'5" and none of my cars have ever been in any of my garages, so head clearance was a primary concern for me. Honestly I wish I could get that gate even higher, I still hit my head occasionally.
I see that you just joined recently...Welcome. There's a lot of helpful information and people here. I researched all of the modifications that I've done to my Excursion here, and I definately couldn't have done it without this website!
Old 10-29-2009, 03:59 PM   #6 (permalink)
njneer1's Avatar
Thanks for the welcome. I am learning a ton from this site ! Just trying to learn the proper etiquette so I don't piss anyone off !
njneer1 is offline
Old 10-29-2009, 05:49 PM   #7 (permalink)
6 speed tranny
Someone from the powerstroke.org forums did the conversion and was even trying to sell it. He may be on these forums too.
It didnt seem too bad of a swap because the thread talked about swapping the auto tranny back into that ex, and being able to swap back a 6 speed. He probably has the know-how to do the conversion if you are really that curious.
2000 Excursion 7.3 zf6 6 speed Lifted - Ford Powerstroke Diesel Forum
2000 4x4 Ex Limited
DIY intake, AIH delete, ISSPRO gauges-egt,trans temp, boost, 4" Diamond Eye Exhaust, JWVB, 6.0 trans cooler
F5 dp-tuner, 60tow, decel, 80tow, 80econ, 120race
cryo powerslots, superduty hq stainless steel lines, hawk super duty pads
V-code front leafs, ITP pre-pump filter kit
leoneo01 is offline
Old 10-29-2009, 06:17 PM   #8 (permalink)
njneer1's Avatar
Thanks Man, Not member over there but I will check it out.
njneer1 is offline
