Has anyone had experience with the ISSPRO R4130? It is supposed to read the temp of the turbo and shut down the engine after when the turbo cools to 300 degrees in diesel engines. According to the product promotion you can turn the ignition off, remove the key, lock the doors and the sensor will shut down your engine when the turbo cools off. Any info would be helpful.
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by rjohn37: According to the product promotion you can turn the ignition off, remove the key, lock the doors and the sensor will shut down your engine when the turbo cools off. <HR></BLOCKQUOTE>
Hi, rjohn37, and Welcome! to Ford-Diesel.com.
I have the ISSPRO TTM, and it's wonderful. If I could have only one accessory on my PSD, it would be the TTM. It should be standard on any turbo-engined vehicle.
Sitting in the truck waiting for the turbo to cool down to a safe temp is just about the most boring waste of time I can imagine. After doing that for a month or so, I installed the TTM. Now I just go on about my business and let the TTM do all the waiting.
------------------ Ford-Diesel.com is a member-supported website, for more info: Click here. ........ Ole retired guy in west Texas with Darling Wife and Sierra Blanca - the white mountain of a '99.5 F250 diesel-powered CrewCab.
Nice when it worked! Been without it for a month now
ISSPRO hasn't shipped any recently. so I can't get mine replaced.
Excellent concept, but mine is broke. I will continue until I get one that works!
Where did you mount your TTM, anyone. On our ambulances here they're mounted on the dash, and look kind of obtrusive. How else can they be done? Underdash, maybe?
I am interested in a TTM also. Did you mount the thermocouple before or after the turbo?
Some have suggested using this monitor, as well as a manually engaged exhaust brake to WARM UP the engine without the key in it (after starting and bringing exhaust temp to 300 plus. Is this feasible, anyone done it?
Anyone used one thermocouple connected to BOTH a TTM and a pyrometer gauge?
2000 Excursion Limited 4x4 Toreador Red ext./gray int. 7.3PSD, 3.73LS, Skidplates, TeleMirrors, Ford Aero deflector, PSDV8 badging
2000 Excursion Limited born 11/99 4x4 Toreador Red ext./gray int. 7.3PSD, 3.73LS, Skidplates, Pwr/Htd TeleMirrors, 6CDchanger, HtdBuckets, LT265/75R16E Bridgestone Dueler A/T Revo, Ford Wraparound deflector, PSDV8 badging, RoofMarkerLights, Tekonsha Sentinel brake cntrlr, PCM=AXD0, Edge Evolution II, WalkerBigTruck Muffler, RS9000, RS5410, Performance Friction 2 piece rotors/pads, Sylvania SilverStars, Landyot Gen III, Air Lift rear air bag system, Amsoil from MAXoil.com in diffs/trans/transfer 251k miles.
TTM's are wonderful, but if you have a EXCURSION, if the TTM is on for more than 15 seconds it will cause your GEM module to shut off your Keyless Entry Key FOB for about an hour after the TTM shuts down the engine.
I mounted mine next to my fuse box under the dash.
2000 XLT EXCURSION, Chestnut, PSD, 3.73 LS, AT Tires, Skid Plate, Tele PWR TT Mirrors, Chrome Wheels, Reverse Sen. Aid., K&N Air Filter, 3 Guages, TTM, APCM
2000 XLT EXCURSION, 4X4, Chestnut, PSD, 3.73 LS, AT Tires, Skid Plate, Tele PWR TT Mirrors, Chrome Wheels, Reverse Sen. Aid., K&N Air Filter, 3 Guages, TTM, APCM, W-D Turbo Brake, Rancho RS9000's, Grover Air Horn 1609KD, Towing a 2001 Dutchmen Supreme Travel Trailer Model 31BH4-DSL.
