has anyone had any experience with the ITP porduct high pressure oil crossover? it is suppose to equalize the pressure between the fuel rails I am lead to belive. does it and is it a worthwhile upgrade?
thanks
2002 X 4X4 PSD, limited ultimate, white, 4" pro comp lift, 35" BFG, centerlines, banks 3.5" exhuast, SCMT, aFe intake mod, pre pump mod, HX mod, weather techs, packasport box on top. http://www.superford.org/registry/index.php?vID=1457
Actually, it equalizes the pressure between the High Pressure Oil Rails, not the fuel rails. We have had VERY positive comments from customers that experienced a quieter and smoother running PSD with the kit. I'm sure that others will chime in here but wanted to make sure you understood what it was really connecting.
I've got one and like it. The engine is definitely smoother and quieter so even though I still have a mild, intermittent idle knock I'd still give it a firm two thumbs up.
I have a leak from one of my stock HP hoses. Still waiting to get it fixed. I've installed one of ITP's HX kits and you know what? The elak has stopped. I am still going to get it fixed, but I wonder why balancing the pressure stops the leak? Is one side seeing more pressure than the other? Interesting problem.
well it is installed. had a leak problem during startup, had to retighten the hoses. no problem now. X runs great, ran great before but it does seem quite a bit quieter now. with the windows up it is very quiet while idle and off throttle. when I jump on it, it sounds the same.
it was an easy install but a bit awkward using the tools at those angles. will I need to remove the hose before taking it in for service work?
thanks Dennis
Depends on the dealer--even the local PITA's didn't say anything when I took my rig in with the ITP hose installed but some might pitch a fit if they see it.
