Joined the ranks, now want advice/experiences with mods
Hi everyone,
I purchased my X on Friday, thanks to those who sent me advice on what to look for while I was shopping. Now I'm looking to do some upgrades...
Truck is a '00 PSD 4x4, bone stock with 66K on it. Still has the stock Steeltex AT's with a little over 1/4" of tread left and black shocks...
After putting in a lot of seat time with it this weekend (put about 1000 miles on it during the ordeal to move my Suburban to my grandparent's place) I found that it does cackle but does not have any idle knock.
The guestimator says that I'm getting 16 MPG empty and 15.5 with 1/4 towing - 1/2 highway and 1/4 in town driving. Haven't filled up yet but have 1/4 tank left with 450 miles on the tripmeter.
Here's the order of things I'm looking at. Advice, experience, etc is welcome...
1: Tank and prepump mods. Looking at the kit from ITP and a Racor 460R from DIS in addition to 'harpooning' the tank while it's down.
2: Regulator kit and HX mod from ITP
3: ISSPRO Boost, pyro and tranny temp gauges
4: Reconfigured radiator hoses, coolant filter and Evans coolant
5: Spin on tranny filter pre cooler and magnafine post cooler (yes, I'm anal about clean fluids)
6: New tires, shocks, and U-codes
I must say that I love my X and expect that I'll have a permanent grin on my face for the next several weeks if not months.. [img]/ubbthreads/images/graemlins/laugh.gif[/img] [img]/ubbthreads/images/graemlins/laugh.gif[/img]
Before anyone suggests the BTS tranny, the wife already OK'ed the trip to the Ozarks for next year's tax money... [img]/ubbthreads/images/graemlins/cool.gif[/img] [img]/ubbthreads/images/graemlins/laugh.gif[/img] Hopefully the stock tranny will hold out...
Anyway enough rambling about my new baby... [img]/ubbthreads/images/graemlins/laugh.gif[/img]
Later,
Joe H
'00 (born 1/00) PSD X 4x4 Limited 285 Dayton Timberline ATs and Rancho 9000x's Prepump & in tank mods and HX Crossover installed 4.5" Magnaflow Stainless Exhaust w/downpipe
AFE Stage II Magnum Force Airbox
Re: Joined the ranks, now want advice/experiences with mods
No need to 'poon' the tank, it should fill very well as is.
I'd stop with the pre-pump and tank mods and see how much improvement that makes before jumping for the regulator kit, save the money for the exhaust, and chip [img]/ubbthreads/images/graemlins/smile.gif[/img]
2002 PSD Excursion 2WD, VDO guages, PPIII, pre-pump and tank mods, ZooDad, 4" exhaustw/ Magnaflow muffler and downpipe, Bilsteins, Hellwig bar, Air Lift rear bags, monochrome SD grille and bumpers, 20" Weld Velociti 8's
Looks like a good plan to me, but I'd probably do as you've already been advised and do the pre-pump and maybe the tank mod and see how you fair with those. My personal opinion on the HX mod is that I'm not ready to do it yet.
The only other advice I'd have for you is to do a flow test on the tranny return line with all your filters. There's a certain amount of flow over a certain amount of time, and if you over filtered your fluids (if that's possible [img]/ubbthreads/images/graemlins/smile.gif[/img] [img]/ubbthreads/images/graemlins/smile.gif[/img] ) you might introduce too much restriction in the line. The other "gotcha" is that if there's too much flow restriction I believe the cooler bypass opens and you won't be running your fluids through the tranny coolers.
Good luck!!
Have a good one,
Dave
PS - GO AIR FORCE! (my dad was in for 22 years and I"m definately an airforce brat)
2002 Excursion Limited - 7.3 PSD, 4x4, Auto. Tekonsha Prodigy Controller. ISSPRO EV Gauges in A-Pillar mount. Diesel Turbo Lifesaver. Pre-pump Mod. SCMT-Trimode. AIC. Back Door storage bins. Banks 3 1/2 inch Monster Exhaust. AIS. "U-Code" Springs. Powerstroker Exhaust Brake. Husky Liners. Bilstein Shocks. ART Brakes, Helwig Rear Anti-swaybar. Zoodad Mod. Airlift Rear Airbags. Racor 3550 CCV. Forest River Wildcat 26FBS TT.
Sounds good. The suspension mods by far gave me the most bang for my buck. The regulator mod was also sweet as it made a world of difference in improving how the engine ran. As far as the HX mod, I'm not real carzy about it. I did it, but it really didn't seem to make any difference. The only thing it did do, was cause me worry about having high pressure oil in a flexible hose that is in very close proximity to the turbo and other surfaces, upon which it can rub. I always carried my plugs with me, but a failure of this hose under operation would kill the engine immediately, and make quite a mess under the hood. And since my wife drives this truck most of the time, it's not somthing she would be able to do anything about on the side of the road, with my toddler and newborn in the cab and freezing temps outside. Anyway, for piece of mind, I removed this mod. If you still want to do it to your Ex...and wouldn't mind one that only has a few miles on it....let me know, I'll sell you mine, cheap (PM me).
Toolman1
Thanks for the info, keep it coming.
The brakes are still good and no warped rotors. Where is the best place to purchase the Hellwig rear swaybar?
Too bad you didn't reply sooner Toolman1, I just ordered the HX and prepump kits last night...
What's the easiest way to knock the neck restrictor out of the filler? Hole saw or... ?
Thanks,
Joe H
__________________ 2000 PSD Excursion Limited 4x4. Black/Gold. Jack-It 3-1/2 inch kit--315 Mickey Thompson MTX. APC headlight harness with 65/100watt bulbs. Nokia auto hands free kit with "left hand" mount.PSD front fender badges. In tank mod, pre-pump mod. Pro Liner roof. Home made tymar type intake with K & N cone filter RC-4780. Bullydog stock/45/75/125 chip, Over 202k miles and going strong.
Yeah, I used a hole saw, but only after I removed the entire filler neck assembly from the truck. I don't recommend doing this mod while the filler neck is still on your truck....unless you have one heck of a good vacuum and can be certain that no plastic debris will fall into the opening. I know I posted a complete "how-to" on this subject some time back. It might be under my old user name of Toolman (wihtout the 1 at the end)<--long story.
