Old 02-18-2006, 12:19 PM   #1 (permalink)
Just bought a set of Revo's
My truck has 69,000 miles and my BFG's finally needed replacing. Since my truck had to be pulled up a snow covered hill by a Chevy 3/4 ton pickup (after a 1/2 ton Suburban on passenger tires passed by me with no problems) I decided it was time. The BFG's lasted quite a while, but they were not great tires....wet traction was marginal and off road (at least recently) they were terrible. I did a search here and decided to go with Bridgestone Dueler Revo's in the 285/75/16 size. I hope you guys were right about how great these tires are....they were $901 out the door [img]/ubbthreads/images/graemlins/shocked.gif[/img]
2003 Excursion Limited 6.0 PSD, Mineral Grey Metalic, 3.73 Ltd Slip, 2nd Row Buckets, Tele PWR TT Mirrors, DVD
dgreen1069 is offline
Old 02-18-2006, 06:31 PM   #2 (permalink)
Re: Just bought a set of Revo's
That is a little high, The first time I bought them they were not bad.
When I bought my second set a little over ayear ago I asked what happened, they said they are great tires and we have some out there now and the price has gone way up.
I think I got out the door for about 800 even but they wanted close to 880 as I recall. This is a dealer I use often.
I think you will like them, As far as I know they are the best on Ice and snow on the X.
Bruce
2005 X PSD Limited Mineral Grey, 4X4 Has Second row bench then Every other factory option available.
Under Construction
4x2 Lift Gate Lifts,
Tekonsha Prodigy
Ford 30MM Rear Bar
Catch All Linners
750 W Inverter
06 Chrome Package Grill,bumpers and hooks. After an encounter with a Honda, (She got the ticket)
2005 Ex and Specs and Pictures of 2002 X
Bruce1954 is offline
Old 02-18-2006, 06:48 PM   #3 (permalink)
There was only one other shop close to me that could order them. It would have saved me another $40, but I wanted to get them on this morning.....you guys know how it is. Tirerack.com had them for $168, but the shipping and installation charges would have jacked the price up another $150. I like the way the 285's look, I just hope they are as stable as the 265's while towing.
Old 02-19-2006, 06:42 PM   #4 (permalink)
Be sure and post your towing experience. I am considering a set also, but tow and would sure like your input.
2000 Excursion Limited 2x4, 3.73 LS,PSD/Auto,ATS turbo shroud,Badging,BullyDog 4" exhaust,AIS,HX crossover,ISSPRO gauges/A-Pillar,SuperChip 1705, Pre-Pump & In-Tank Mod,Banks TransCommand, ZooDad, Baldwin Oil ByPass,Ford AIC, F350 rear springs, Helwig Rear Sway Bar,Michelin's LTX MS
2003 Sunnybrook/Mobile Scout & Hensley Arrow
sail684 is offline
Old 02-19-2006, 06:43 PM   #5 (permalink)
I have towed heavy with both tires one the X I think tires are a few items down the list when it comes to stable towing. Just run the pressure on up when you are towing.
Bruce
Under Construction
Tekonsha Prodigy
Ford 30MM Rear Bar
Catch All Linners
750 W Inverter
Old 02-19-2006, 08:23 PM   #6 (permalink)
FamilyRide's Avatar
I tow with them too. Not sure I'd call it heavy, but about 7500#. Like Bruce said, just air them up as you should, and you're good to go.
I turned 28k miles this week and they're still great!
2004 EB Excursion, 4x4, 6.0, everything but step tubes and 2nd row chairs, Magnaflow Exhaust, Isspro Gauges in an under cubby pod, Fumoto sitting on V Codes and Revo 285's.
FamilyRide is offline
Old 02-20-2006, 05:36 PM   #7 (permalink)
Hey SeaRay Jim! How are you???
Nearing 30K miles on my Revo's and love them. Will definately buy another set. I do not think you will be disappointed....
2002 4x4 7.3PSD Excursion, U-Codes, '03 Jounce Bumpers, Hellwig Sway Bar, Rancho 9000 shocks, Rancho Steering Stabilizer, Air-Lift rear air bags, Factory DVD, Driver side A-Pillar grab handle added, Rain-X wipersfront-24", rear-17"), riding on 285/75/R16 Bridgestone Revos.
IMartin is offline
Old 02-26-2006, 03:38 PM   #8 (permalink)
I also love my Revo's. I purchased the 285s but after a couple thousand miles I sold them and bought 265's. My mpg went way down the tube. Let us know how it works out for you.
Jared
2002 Excursion Limited 7.3L PSD, Auto, 4x4, 265/75/16 Revos, Blue Gold, AFE Stage II with ProGuard7, MBRP 4" stainless, DP tuner (hi idle, stock, 40, 60, 80, 120).
1999 BMW 540i, 6 speed, sport package, totaled.
2000 BMW 540i, 6 speed, sport package, not totaled.
jnyost is offline
Old 02-26-2006, 09:34 PM   #9 (permalink)
Ditto on the mileage. Dropped at least 1mpg. Maybe 1.5mpg. The trade off....
IMartin is offline
Old 02-26-2006, 09:41 PM   #10 (permalink)
I lost 3....
jnyost is offline
Old 02-26-2006, 09:49 PM   #11 (permalink)
Mudraga's Avatar
Are you guys sure you're mileage is actually dropping? Are you taking into account the fact that the taller tire is not rotating as many times in a given mile as the shorter tire? It's going to throw off your speedometer and odometer readings, making them show that you've gone fewer miles than you really have. Unless you're getting your speedo recalibrated for the taller tire, its going to appear that your mileage is dropping because you are actually going farther per revolution than with the smaller tire.
I'm running 295/75s right now and I'm trying to determine how to properly take the height difference into account when calculating my mileage. Of course, without actually having a professional speedo recalibration, I'm probably wasting my time too. [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
2002[1/02] Excursion 4x4 Ltd. PSD,Unknown chip/program, K&N GenII FIPK Air Filter, straight pipe exhaust, Autometer Z Series pyrometer and boost gauges, Air Lift SuperDuty air bags with Load Controller II onboard air system, Sonnax Tricumulator, HX hose.
Mudraga is offline
Old 02-26-2006, 10:02 PM   #12 (permalink)
I'm sure. I calculated it. The easiest way to do it is to compare the size of the old circumference to the size of the new. You'll get a ratio of something like .9****. If you don't want to calculate circumference you can probably find it on the manufacturers websites. Multiply the ratio times your current mileage. I went from always being above 17 to never breaking 17. I went from 17-20 to 14-17 (uncorrected). The corrected still barely added 1 mpg. It just killed my truck. It might be different where you live too. My town is full of lights and hills. I noticed it on the stop and go with the hills. It might not be nearly as bad with flat country.
Jared
jnyost is offline
Old 02-27-2006, 07:20 AM   #13 (permalink)
Jared
Actually, the only "correct" way to do it is to measure miles driven with and accurate GPS device. That being said, it can be calculated with the method you apply above, but I think you forgot one step. You arrived at the .9 ratio figure, but forgot to transform that to it's reciprocal to the correct multiplier of 1.111
Correct?
When checking my mileage utilizing my GPS, it's exactly the same as it always was.
TurboDave, EWCS(SW)USN Ret
H&N Turbo 6 Racing
Seviervile TN
A MAN AND HIS TRUCK, IT'S A BEATUFUL THING
01 Excursion LTD (EBM3) 7.3L, PSD, Turbo, 4X2, TTS Race Magnum (original owner)
86 GN (original owner)
87 GN (second owner)
08 Honda Accord EX-L
My Photo Gallery
turbodave is offline
Old 02-27-2006, 11:06 AM   #14 (permalink)
The 285's dropped my RPM's by a couple of hundred (hwy). As we all know, the further the rpm's are over 2000, the worse the milage gets. That being said, I did not not notice any real world milage difference (I regularly make 500-600 mile round trips, and the amount of fuel needed for this trip did not change much).
boatpuller is offline
Old 02-27-2006, 11:39 AM   #15 (permalink)
Mudraga's Avatar
True, but the taller tires mean more weight, less aerodynamics (higher truck), and the wider tires mean more rolling friction. All factors that counteract the benefit of lower RPMs. I'm just trying to figure out if those factors outweigh the lower RPMs or vice versa.
Anyone know of a tall skinny tire? I'd love to get a tire as tall as my 295/75s, but that was as skinny as a 265 for less road friction.
Mudraga is offline
