has any one swapped in a Kingpin dana 60 Axle into a Super Duty ? the bolt pattern for the rims is one catch.. I think that could be remedied maybe redrill or swap parts?...also the spring perch spacing and angles.. maybe welding a trac bar bracket etc... caliper interchange etcetc.. any one tried it?
Deo
2000 Excursion XLT 4x4, 12V P Pump Cummins, 0-ringed head, AE G56 6 spd, southbend FE clutch, guages, lazer dv, 370's, Black Vinyl floor, 285 Nitto Dura Grapplers, 4" remote BD Exhaust Brake, 4" exhaust, Working on Twin turbos HX50 9cm and BHT3E 20cm with tial external wastegate, looking for 2008 XL front clip http://picasaweb.google.com/therabbittree/Excursion02#
2005 Excursion Eddie Bauer 4x4, 6.0L, Rear Capts. Dark Green
1992 W350, srw, dump flat, 5sp, pods
1996 Passat TDI Wagon, worked
Why...KP D60 will cost way more than a SD D60 and the later will bolt right in.
I'm no rocket scientist, but maybe he's looking to switch to kingpin style knuckles?..?
possibly for crossover steering ? high steer arms:..?/ Since there's more aftermarket gear available for modding the kingpin styles. This is usually desirable when/if doing substantial lift on the rig.
just my thoughts.
Other than that, yes, I'd agree; I think the super 60's are just slightly beefier.
not sure if this link helps or maybe ya'll are already familiar w/ it, but helps me a bit to understand as I'm looking for options of building a rock crawler rig on a SD chassis.
__________________ y2k F250 7.3 psd Calif emissions, ext cab long bed 265/75/R16 E rated tires, 190k miles 4x4 (nv271 manual t-case) 7.3 #1247981 1/18/00 (forged rods), 3.73LSD, non-diode 4R100, Dp tuner stock, 60t 60e 80t 80e, high idle. DIY 6637 air filter, wicked wheel, turbo master WG controller, turbo lifesaver, bellowed uppies, 4" downpipe & exhaust, 203t-stat, triple pod glowshift gauges (egt, tranny, boost), Ride-rite 2330 air bags, BTS VB, Sports a Western plow when the white stuff flies.
Trailers:
I'm usually towing 1 of several trailers I've built.
15ft car hauler (1000lbs empty; 5500lbs loaded)
26ft deck over car hauler (2000lbs empty; 7k loaded)
36ft car hauler (Was tongue pull; have since converted into 5er'. 4500lbs empty; 14k loaded) https://lh5.googleusercontent.com/-g...0/IMG_4130.JPG
I do read Pirate4x4 web forum every now and then. The reason I was thinking about the swap was to get rid of th eballjoints, sget rid of th eunit bearings and get rid of the vacuum auto lock hubs in one shot.the price of th edynatrac bearing kit is about $2000 and that buys alot of kingpin dana 60's well at least 2 ..that was the idea . I want to upgrade to a Dana 60 from the Dana 50 and , I would also like 3:55 gears etc... etc.. sounds like i should just keep the superduty style from the reponse here.
Deo
