or Know where to get them? [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Hmmm. 45 gallon tank, figure you are running solo, so let's say worst case you are getting 18 mpg, (I see higher, but i'm being pessimistic.) Gives you 800 miles of range. Driving 70, your vehicle has 11.5 hours of endurance...don't know if you do!
Even if ya don't drink coffee, you'll still need a coffee can! [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
First - never heard of anyone WANTING a bigger tank on the Excursion, and then second (of course) never done it either. [img]/ubbthreads/images/graemlins/shrug.gif[/img] The only 'extra' fuel tank on mine is a 20 gal propane tank - extends the range quite a bit I'm sure - haven't taken a long trip since it was installed. I guess you could mount a tank from a SD in the same place [img]/ubbthreads/images/graemlins/confused.gif[/img] You would just need to get a fuel selector switch and solenoid valve to switch between the two.........
2001 'X' Ltd 4x4 - 4" exhaust/TS Performance 3 position flip chip/Triple gauge pillar mount/K&N air filter/rebuilt and upgraded TC and transmission (local guru)/grill guard/front lighted logo/superduty grill/Lund screen front/clear corners/cowl induction hood/ Hella 550s / X code front springs / Add-a-leaf rear springs / Powershot 2000 / Evans NPG+ Coolant / Rancho RS9000X / http://www.webshots.com/search?query=beastdriver&new=1
Aero Tanks used to have and aux tank for the X advertised, but I don't see it on their pages now. You might give em a call.
Proud American
01 4WD PSD Ex - EBM2 - Autometer's on the A, Mag-Hytec Tran Pan, Front Hitch, Dome Light Override, TTM, CCV Re-route, Coolant Filter, Hellwig Bar, Walker BTM, BTS Trans, DP-Tuner, BIG SMILE!
