Old 02-02-2003, 02:00 AM   #1 (permalink)
Leaf Spring ?
I know this a PSD forum but can you help me with my rear leafs? I had my truck lifted about 9 months ago and had leveling springs installed in the rear and they started sqeaking about a week ago...At first it wasn't bad but now it sounds like chit!!! Is it possible to slide those plastic/nylon isolators between the springs? My stock leaf's have the isolators but not the leveling leafs...A local shop said I'd need to have the springs fitted (a hole punched through them) so the isolator would fit but I'm guessing the springs won't need to since the u-bolts keep the springs tight and in place...Hope that makes sense [img]/ubbthreads/images/graemlins/shrug.gif[/img] Anyway's this is driving me crazy and I gotta get this fixed immediately!!! Please help me, my wife is driving me crazy about this - - Almost as much as that sound is [img]/ubbthreads/images/graemlins/grin.gif[/img] Thanks all
02 Mineral Grey Limited Ultimate Ford Excursion V10 - 6" Fabtech Lift, Dual Fox Shocks w/hoops, Fabtech Dual Shock Steering Stabalizer, 16x10 Chrome KMC Tanks, Cooper 315x75's - HERS (All 4'11" of her) [img]/ubbthreads/images/graemlins/smile.gif[/img]
98 Bright Atlantic Blue Mustang Cobra Vert - 4.10's, Kenny Brown Supersubs, Pro 5.0 shifter, C&L 80MM MAF, VRS X-pipe, 2 Chamber Flows - HIS
B Kennedy is offline
Old 02-02-2003, 02:27 AM   #2 (permalink)
Re: Leaf Spring ?
I hope someone posts a permanent solution. I did the leaf in the rear and followed the directions to lube the leafs and it started squeaking about 4 months ago. It really doesn't bother me since it can't be heard inside the truck but I would rather it not squeak.
Txangler
2001 X, 4x4, White, Limited, PSD,. Oil Guard, Stull 6099 Grille, AFE Intake, X Monitor, Sonnax/Tricumulator, Mobil 1 ATF w/Racor tranny filter, DieselPower Custom Burn Chip, Walker BTM, W Code Frt Springs, Procomp Add-a-Leaf Rear, Rancho 9000's w/5406 SS. Pics @ http://community.webshots.com/user/txangler32
TXANGLER is offline
Old 02-02-2003, 10:56 AM   #3 (permalink)
Re: Leaf Spring ?
Your shop is right; you will need to have the teflon pads installed to the add a leaf to prevent squeaks. I had lubed mine with grease but as TX Angler said that only works for a couple of weeks at best, and a good rain seems to wash it out.
When I took out my add a leaf, only the front and rear tip of the leaf rides againsed the spring pack. In other words, they will always squeak unless you have a teflon pad installed.
For some reason the procomp leaf did not have the pad. A tuff country leaf I had on my dodge did.
Hope this helps, Mike
05 Ram 2500 Cummins 4x4 G56
02 X Limited Ult PSD 4x4,Edge Juice-Evolution,325/60-18 Nitto's on Weld Cheyenne 8's,V Codes, mini spring pack,F350 rear springs,5" blocks,Helwig,AIC
'00 Ram 3500 4x4 6-speed Cummins 374/829 DFW Dyno Day (Sold)
Chaw is offline
Old 02-02-2003, 12:49 PM   #4 (permalink)
Re: Leaf Spring ?
Yes, you do need to drill holes and install the teflon pads. Also install a pad where the center bolt goes thru, similar to what is there from the factory. These are put there to keep the squeeks away.
2002 Limited Ultimate Premier No Boundries Excursion 7.3l 4X4 all black with every option Ford could come up with. X-code F550 front springs, full size leaf added in the rear, 265 Bridgestone Dueler Revos, Edge Juice with Attitude, Edge Evolution, Autometer sport comp guages, IDM mod, Walker BTM muffler, SPDiesel exhaust brake with t/c lock up control, Catch-All floor mats.
edunn69 is offline
Old 02-02-2003, 02:19 PM   #5 (permalink)
Re: Leaf Spring ?
Thanks for the insight everyone [img]/ubbthreads/images/graemlins/cool.gif[/img] Any guestimates on what this will run me? Better yet - - how many hours labor am I looking at with a competent mechanic? [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
Old 02-03-2003, 11:41 AM   #6 (permalink)
Re: Leaf Spring ?
Anyone? Any guesses?
Old 02-03-2003, 01:06 PM   #7 (permalink)
Re: Leaf Spring ?
Probably 2 hours, and the pads are only about $1.50 each
edunn69 is offline
Old 02-03-2003, 03:00 PM   #8 (permalink)
Re: Leaf Spring ?
Thanks Boss, I guess I'll find out the real deal tomorrow - -
Old 02-03-2003, 05:09 PM   #9 (permalink)
Re: Leaf Spring ?
Yes, it took me 2 hours with a few cold one's.
Chaw is offline
Old 02-03-2003, 10:29 PM   #10 (permalink)
Re: Leaf Spring ?
Right on...Hopefully that's all it'll take [img]/ubbthreads/images/graemlins/smile.gif[/img] Going to place out here called National Spring and from what I hear they do really good work and are nationally known...Any of you heard of them?
Old 02-03-2003, 10:39 PM   #11 (permalink)
Re: Leaf Spring ?
I have the ProComp add-a-leaf ready to install. New X will be here week of 2/10. Where can I get the pads? Do I just drill the spring!? Any help is greatly appreciated!
Paul
2008 F-350 4wd Crew Cab Long Bed
6.4 Diesel w/ Torqshift
finchturf is offline
Old 02-03-2003, 11:05 PM   #12 (permalink)
Re: Leaf Spring ?
Go to your local spring shop and they will have them, about $1.50 each (4) needed. Just drill a hole like on the stock springs and put them in. It's also a good idea to put some silicone on them to keep them in place while installing.
edunn69 is offline
Old 02-05-2003, 10:38 PM   #13 (permalink)
Re: Leaf Spring ?
Well, finally got everything back to normal with no squeaks [img]/ubbthreads/images/graemlins/biggrin.gif[/img] Replaced all the nylon leaf pads, leafs were diamond cut and reshaped so they all sit flush, new U bolt's and bolt clips - - $350 out the door...
» Sponsor Links
»Garage Storage and Cabinets
