Old 09-10-2005, 01:54 PM   #1 (permalink)
Leaf spring bushings..cause of looseness???
i have searched high and low through the forums and about wandering "X".
I have replaced ball joints, pitman arm, shocks, re-alingment and fluid change in stearing gearbox.......now it comes to bushings or the stearing gear box its self.
My question could it be the leaf spring bushing?
and
is there an aftermarket stearing gearbox avaible??
thanks
2000 X with 4"straight pipes, Tymar style intake, guages AND Saving for the Kelderman Airride(dont tell the wife)
mybimota is offline
Old 09-10-2005, 03:51 PM   #2 (permalink)
Re: Leaf spring bushings..cause of looseness???
Did you read this article?
http://www.supermotors.org/clubs/for...le_1/index.php
Hoowasat is offline
Old 09-10-2005, 06:15 PM   #3 (permalink)
FamilyRide's Avatar
Have you adjusted the steering gearbox?
2004 EB Excursion, 4x4, 6.0, everything but step tubes and 2nd row chairs, Magnaflow Exhaust, Isspro Gauges in an under cubby pod, Fumoto sitting on V Codes and Revo 285's.
FamilyRide is offline
Old 09-11-2005, 06:06 PM   #4 (permalink)
i did adjust the steering gearbox and got it tested to be sure also.....but she's like brand new!!.
ok i did some experinmenting by putting the truck frame on jack stands and pushed on the front passenger wheel...and i could move the leaf spring at the frame(back bushing)
I had probly 1/4" of slop. I also did it to the drivers side and my front leaf spring mount was moving a little less then 1/4". and i have squeeking from the mounts also
my truck has over 100K miles on and the suspension is stock beside new rancho shocks and swaybar bushing(the cause of the clunking noise).
I bet that this is the cause of the Wandering X's... people with over 90k miles on it
I am ordering a bushing kit from Energy Suspension to see if this is the problem.
If you are under your "X" and get some one to rock the truck back and forth using the bumper and see if you have movement also....i also could see movement and feel it this way with the tires on the ground.
thanks
mybimota is offline
Old 09-12-2005, 12:24 AM   #5 (permalink)
Hey do you have a photo of the "clunking" sway bar bushing? thats gotta be whats driving me nuts!
and PLEASE inform me of the energy suspension upgrade..I am seriously considering that. I have a friend here in town that swears its the best thing he's ever done to his truck...
Tom [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
CTFD
Contact Info.. tom@reynolds-excavation.com
512-762-1485
LATE 1999 F350 CC Dually 2WD,4" stainless Magnaflow.Highly Modified GT38 Turbo
DP-Tuner 4 Pos. chip, PS2000,4" intake with fleetguard filter ,Suncoast Tranny With Triple disc T/C, Lunar Guages
12 Speaker 770 watt Fosgate,Sony and Infinity system with (((XM))), Stull Billet,BFG's and acetoned badges.ART rotors, More to come. 8100lbs.
1/4 mile 14.80 @ 94.24 MPH
2000 Limited 4X4 Excursion Toreador red and tan,(((XM)))Rancho RSX's, Hellwig anti sway,V codes on front, skyjacker dual stabilizer, Edge Evolution AFE with PG7, Eddins House of Diesel 4" Exhaust with Polished 5" tip, Suncoast tranny with triple lock, 15.1" DVD monitor,now rolling Akuza Bounce 20's w/ Toyo 305/55/20 AT's
OUR TRUCKS and new ****350Z ****
EXCAV8TER is offline
Old 09-12-2005, 11:46 AM   #6 (permalink)
Tom,
I throught out the old swaybar bushing when i replaced them but here is the link for energy suspension part # Energy suspension
scroll done to excursion and I replaced it with the part # 4.5180 was about $15
I am buying the master kit today part # 4.18120 it about $175..
ill let you guys know what what feedback i get from that
thanks
mybimota is offline
Old 09-14-2005, 07:25 AM   #7 (permalink)
Send a message via ICQ to coldair
I have deaver springs that Incorporated the factory rubber spring bushings in their packs and I had 3 for them start to move around first I noticed a squeak coming from the front spring hanger, Deaver sent me all new bushings and after replacing them the truck was much tighter. the other things that need checking is the upper drag link ball joint at the pitman arm and the tracking arm bushings and bolt torque its is something like 387 ft lbs
2002 Excursion LTD(PCM:NQW5)Pheltech Tru-Cowl Induction Hood BTS transmission ITP fuel system, 38/15.5/20 Toyo's on Weld 12" wide wheels,15k warn and warn 9.5k rear 4:56's ARB air lockers front and rear. Trail ready front bumper,Road Armor rear bumper light force driving lights, PIAA backup lights,Dakota digital gages, F5 DP tuner chip,Hypermax stage 2 injectors,4" exhaust, 11" Edge lift, King shocks, edge crossover steering, ORU ram assist steering
Fabtech ladder bars,TN turbo, Dynatrac conversion kit. Alpine F1, Zapco amps. two dc1100.1, three dc1000.4, 1 dc750.2, driving seas reference series front stage and Zapco competition rear fill and 2 Jl audio 13w7 subs
AP Racing big brakes, Amp Research running boards
coldair is offline
Old 09-15-2005, 10:28 PM   #8 (permalink)
clamgulch's Avatar
There is a local shop that replaces track bars all the time. The owner swears the factory ones are junk and wear out in 24,000 miles, sometimes less. I have an adjustable trac bar on mine and it helped a little bit, but with my lift, I think the only thing that's going to really help is ladder traction bars on all 4 corners. [img]/ubbthreads/images/graemlins/confused.gif[/img]
clam the powerstroke grinch
2000 Excursion LTD 4x4
Slightly tweaked HPCR 5.9 Cummins
Allison 1000 5 speed auto
clamgulch is offline
» Sponsor Links
»Garage Storage and Cabinets
