leveling kit and driveshaft growl
Today I picked up my Jackit 2.5" leveling kit which includes front spring packs plus rear add-a-leafs. The product manual states I will have a problem with driveshaft growl as a result of the lift (change in pinion angle?). Apparently the only remedy is to change the driveshaft (probably very costly).
Has anyone else had experience with lifted X's and drifeshaft noise? How bad is it, and at what speeds is it most prevalent? I would appreciate your feedback since I am having some reservations about the install if I'm going to have problems.
2000 PSD X Ltd Black/Tan.
1998.5 Dodge Ram QC 24V Cummins, Boost and Pyro (pt), 275 injectors, VA, PE, DTT TC and VB, 4 exhaust, Psychotty air, espar heater, 255/85 Dunlops.
