Old 11-05-2004, 06:36 PM   #1 (permalink)
Lift For an 04 X
I am sure that all at this site have had plenty of lift questions before, but I have questions and after reding sone of the post I am sure that some of you have the ansewers.
First, I am only looking for about 3" of lift,and don't want to change the ride to somthing rougher. I see a couple of ways to go 1) is springs like the ones sold at 4wheel parts wholesale. 2) hangers like the Donhoe racing people sell. 3) X codes or something like them.
Second, if you lift the truck only 3" is it recomended to use a pitman arm and lower the pan hard bar.
Third, which one rides the best.
forth, if you have to lift the rear due you use a block or an add a leaf and due you loose the stock tracktion spring, I am not sure if that is the proper term for that thing.
2004 EB 4WD PSD X, AFE intake, Juice Chip, 285 NITTO'S, Weld Velociti 8's
kent65 is offline
Old 11-12-2004, 09:48 PM   #2 (permalink)
BDS
Re: Lift For an 04 X
Sorry it took so long for a reply! Welcome to the site and I'll try to give you options from my two pennies worth [img]/ubbthreads/images/graemlins/rolleyes.gif[/img]
I really didn't like the ride of my EX at all! I thought it was actually a little unsafe to drive and cornered like crap! I figured the problem was more than just crappy Ford shocks. Well Ford for some stupid reason doesn't even put V code ("medium duty") front springs under their HEAVIEST engine offered! SO I started out wanting to go with the snow plow springs (X codes) that where ONLY offered on the f250/f350-gas engines [img]/ubbthreads/images/graemlins/shrug.gif[/img] and F450/F550 [img]/ubbthreads/images/graemlins/shrug.gif[/img] as for the rear I was going to go with the 4" block and new u-bolts. Then I was going to install Donahoe shocks on all 4 corners and be done with some 33" tires and wheels. I know you said you didn't want to go with something rougher...but from what I've been hearing it really isn't close to being a harsh ride at all with the X springs.[img]/ubbthreads/images/graemlins/shrug.gif[/img]
So basically this is what you are looking at for option #3.... replacing the front springs with new X codes replace the rear 2" block with a 4" one. Add some new u-bolts and Donahoes shocks. Call them for the shocks...I thought they had some cheaper ones available. I only see the $95 dollar ones on their site.
For option #2....You may want to look into THEIR stuff since you don't want to stiffin her up a bit. But you have to buy shocks and rear blocks and u-bolts so you are around the same $$$ as X springs.
As for the rear add-a-leaf [img]/ubbthreads/images/graemlins/shrug.gif[/img] I never looked into it and I think someone here has done it and maybe they will see this topic. But remember...If you put leaves in your going to be looking into new u-bolts anyways so I would think it would be a little cheaper to go the blocks. Plus the blocks won't effect the rear sping pack at all.
I would either go X spring or hanger system rather than the 4 wheel parts stuff. Just my opinion! Their stuff will most likely give you a ride you won't like [img]/ubbthreads/images/graemlins/eek.gif[/img]
You don't have to go with the pitman arm but someone here may disagree with me. I would concider the panrod bar to keep the axle aligned perfectly under the truck.
All this crap is just my opinion so good luck with whatever you do!
Brent.
96' F350 XLT C/C PSD 4X4 LWB-Green...His, SOLD IT, Stupid Move, Found Another!
97' F350 XLT C/C PSD(for now) 4X4 LWB-White...His
01' Excursion PSD 4X4 Limited...Hers
Trucks
Sled Pull
BDS is offline
» Sponsor Links
»Garage Storage and Cabinets
