Has anyone installed guages yet? If so, how did you get the light switch assembly out of the dash, in order to connect to the dimmer switch for the background lights. The switch I have is different from the one described in the F250's. My switch does not have the pull out, so I can't remove using the recommended method described on the DIS page. Does anyone have a answer?
turn the headlight swith to the on pos and pull the knob. insert a thin tool to release the switch knob(you will see a little hole in the knob while in the on pos). turn the knob 180 degrees and put it back on. turn the knob untill the back of it is in the off position. turn the knob fully clockwise and pull out on the headlight switch.
STEPHEN 350 4X4 SILVER XLT TINTED WINDOWS AUTO BURLWOOD DASH FORD BED LINER BANKS AIR FILTER POWER/PKG COMP/TEMP MIRROR PINSTRIPED SPOT LIGHT LUND/VISER BFG 295`S Fisher plow my truck
STEPHEN 350 4X4 SILVER XLT TINTED WINDOWS AUTO BURLWOOD DASH & a burl wood AIC cover,heated mirrors with turn inder FORD BED LINER BANKS AIR FILTER POWER/PKG COMP/TEMP MIRROR PINSTRIPED SPOT LIGHT LUND/VISER BFG 295`S Fisher plow my truck Check Out My Burl Wood AIC Cover!
Ford may have changed the head light switch for the 2000 model ??
On my 2000 F250 I found it necessary to remove the dash trim panel.
This reqires removal of the radio, to expose 2 screws which must be removed to remove the dash panel.
After they are removed it is just a matter of pulling off the trim panel evenly and smoothly as the rest of the fastners are clips.
When the dash trim panel is pulled away from the dash , you will have to disconnect the head light switch from its wiring, to do this you must first release the red clip locks.
Then you wll find a lever on the back of the switch which must be pushed over to release the switch from the trim panel.
2000 F250 S/D 4x4 C.C. 7.3 PSD AUTO. XLT , Line-X bed liner, ARE cab high cap.
2000 F250 S/D 4x4 C.C. 7.3 PSD AUTO. XLT , Line-X bed liner, ARE cab high cap. / 2006.5 VW Jetta TDI my baby diesel.
I should be able to install my gauges this weekend as long as the paint finally gets here. I wanted to get this back up top, as I have this question also. It does not seem that the light switch pulls out in my Excursion. Is the solution to remove the trim as in the post above? Any alternative to hooking the lights to the dimmer on an Excursion?
Also, for those that have installed the trans temp gauge. Where do you access, and what color is, the "key on" wire for the gauge? Want to make sure I'm doing the right thing and would like to get feedback from someone who has done this on an Excursion.
4X2 Estate Green Limited PSD Excursion. CD Changer, L/S 3.73 Differential, PSD Badging, Stull Grille. Plate # "4TRESS". Pyro, Boost, Trans Temp & Pillar Mount ordered 5/02. Ordered 2/21; Born 3/17; Arrived at Dealer 3/27; Took Delivery 3/31!
The pigtail for the electric trailer brake controller (F81B-14K122-BA all Excursions have this pigtail, they all have the trailer tow package) contains five leads, and a white tag that explains them. Remove the fuse access panel below the steering column, on mine the pigtail was already plugged in to a gray connector on the right side of this area
Brown Illumination (dimmable gauges)
Dark Blue Trailer brake feed (to trailer)
Red trailer brake control feed
White Ground
Light green stop light to brake control
The Brown illumination wire carries the dimmable feed for dash panel lights and gauges! You don't need to mess with the light switch, instead access the wiring harness at a customer access point already provided.
2000 Excursion Limited born 11/99 4x4 Toreador Red ext./gray int. 7.3PSD, 3.73LS, Skidplates, Pwr/Htd TeleMirrors, 6CDchanger, Ford Wraparound deflector, PSDV8 badging, RoofMarkerLights
2000 Excursion Limited born 11/99 4x4 Toreador Red ext./gray int. 7.3PSD, 3.73LS, Skidplates, Pwr/Htd TeleMirrors, 6CDchanger, HtdBuckets, LT265/75R16E Bridgestone Dueler A/T Revo, Ford Wraparound deflector, PSDV8 badging, RoofMarkerLights, Tekonsha Sentinel brake cntrlr, PCM=AXD0, Edge Evolution II, WalkerBigTruck Muffler, RS9000, RS5410, Performance Friction 2 piece rotors/pads, Sylvania SilverStars, Landyot Gen III, Air Lift rear air bag system, Amsoil from MAXoil.com in diffs/trans/transfer 251k miles.
