Old 12-21-2004, 03:21 PM   #1 (permalink)
Limited Slip Differential
Would the Ex. in my Signature have limited Slip standard. If not can you tell from the VIN #. Thanks for the help....I really don't want to have to Jack it up to find out.
[img]/ubbthreads/images/graemlins/phoney.gif[/img] <font color="blue"> </font>
PSD4RBOYS
03 EXCURSION 6.0 PSD,XMRADIO,REMOTE START,ALL STOCK FOR NOW
MISSOULA, MONTANA
The person who has nothing for which he is willing to fight is a miserable creature and has no chance of being free unless made and kept so by the exertions of better men than himself
-John Stuart Mill
rsusott is offline
Old 12-21-2004, 03:38 PM   #2 (permalink)
Re: Limited Slip Differential
Think we will need vin ##
Cary
1971 EB Hard Core Crawler
2006 Yamaha FJR1300
2005 Suzuki King Quad
caryt is offline
Old 12-21-2004, 03:43 PM   #3 (permalink)
The easyest way to check is to get under your X and look at the tag on the rar end, there are a set of numbers that states the axle ratio example 3.73 or 3.L3 if it has the L where the 7 should be then you have a limited slip rear end if it has the 7 and not the L the you have an open rear end . I hope I helped . Roger
Y2K EXCAR lmd 4x4 psd:
H2E W/Comp. Mod, Tapercore, Afe stg. II, Mini Me's, John Woods Trans, DI fuel system and Jody's tunes.
rogerr is offline
Old 12-21-2004, 03:46 PM   #4 (permalink)
CHPMustang's Avatar
On the white door jamb decal look for "axle" and under it will be the code.
If it begins with a C it's limited slip,if it's a 31,32 or 33 you have open differential.
Hope this helps some.
Bill
2002 Ford Excursion 7.3L 4x4 XLT
9th Annual Powerstroke Rally this Oct 3-5 2008 in Caddo Mills,Texas
CLICK HERE for more Information & Register Here
CHPMustang is offline
Old 12-21-2004, 04:16 PM   #5 (permalink)
Thanks for the help...I check it out when my wife gets home
Happy Holidays
PSD4RBOYS
MISSOULA, MONTANA
-John Stuart Mill
rsusott is offline
Old 12-21-2004, 04:31 PM   #6 (permalink)
CHPMustang's Avatar
Most of the Diesel Excursions I've come across have the LS and the Gassers have open diffs but best check when the better half gets in [img]/ubbthreads/images/graemlins/wink.gif[/img]
Old 12-21-2004, 04:57 PM   #7 (permalink)
I don't think the LS was ever part of any package
It has always been a line item on every ford I have ordered
So unless you ask for it or they ordered it you will not get it.
Bruce
2005 X PSD Limited Mineral Grey, 4X4 Has Second row bench then Every other factory option available.
Under Construction
4x2 Lift Gate Lifts,
Tekonsha Prodigy
Ford 30MM Rear Bar
Catch All Linners
750 W Inverter
06 Chrome Package Grill,bumpers and hooks. After an encounter with a Honda, (She got the ticket)
2005 Ex and Specs and Pictures of 2002 X
Bruce1954 is offline
Old 12-21-2004, 05:08 PM   #8 (permalink)
CHPMustang's Avatar
My selling dealer has 10(in stock)3(on order) 2005 4x4 Excursions all with Diesels and 3.73 LS Axle [img]/ubbthreads/images/graemlins/cool.gif[/img]
I think they order them all the same as far as Diesel 4x4's go with the LS.
Old 12-21-2004, 05:10 PM   #9 (permalink)
Yes, if you ask you shall receive, otherwise you have 2 wheel 4 wheel drive. [img]/ubbthreads/images/graemlins/cool.gif[/img] There is a LS for the front also.
Some people are like Slinkys. They are good for nothing but still put a smile on your face when you push them down a flight of stairs. 2003 X Limited Ultimate, Mineral Grey Metalic. DVD, Limited Slip, Badged, Cab Lights, Magnaflow, Thule Rack, 3" Lift, T Prodigy, Air Bags, Edge Programer, XM Radio, Extreme sound system. 315/70/17s on AR Chrome/Aluminium.http://community.webshots.com/user/stellinm
MotionMan is offline
Old 12-22-2004, 04:44 AM   #10 (permalink)
I don't think Ford has offered a LS on a front diff since the 1980's. I believe we can thank the Trial Lawyers for that change.
2007 F350 4x4 Dually, CC, 6.0, Auto.
ThePawnbroker is offline
Old 12-22-2004, 02:59 PM   #11 (permalink)
CHPMustang's Avatar
Are they available aftermarket wise if we wanted LS on the front axle?
Old 12-23-2004, 12:28 AM   #12 (permalink)
Yes they are. The best idea for the front is an air locker. ARB makes the top rated one. The only problem at all with having a LS front differential is that you have to know how to drive with it and be "smart". If you punch the go pedal too hard on a curve for instance, you could get the whole vehicle sliding sideways. The thing to do is to shift out of 4 wheel drive (using the transfer case) when driving at higher speeds. Or if you have an air locker, just turn off the switch converting you back to "three wheel drive". The reason they quit putting them in from the factory is the age old (nowadays anyway) practice of making everything as safe as possible for the "masses". Those of us who either take the time to learn, have more common sense, have a higher IQ, or have good mechanical ability, don't get to have our toys/tools as a result.
ARB Website
Old 12-23-2004, 09:06 AM   #13 (permalink)
CHPMustang's Avatar
Most of us that are savvy 4x4'ers have probably heard of ARB,just haven't heard of one installed on an Excursion (yet) [img]/ubbthreads/images/graemlins/grin.gif[/img]
It's a good thought putting a locker on the front but as Pawnbroker said you gotta know when,where and how much [img]/ubbthreads/images/graemlins/cool.gif[/img]
I may look into one in the near future as something else to add on to the Excursion [img]/ubbthreads/images/graemlins/smile.gif[/img]
Old 12-31-2004, 08:58 AM   #14 (permalink)
I bought a new F150 in 1995 and was able to get the LS front axle, but the dealer said 96 was the last model year (and 96 was really only a half-year for the F150 as the 97 was released very early.) You are right in that it drove very funny, always pulling you straight... but I never worried about being stuck!
To that, I once pulled a buddy with a lifted 4x4 F250 out of a ditch with a 77 Mustang 4cyl. Now the Mustang was not my idea, it was a company car, but the buddy had slipped off the road and had his front tire extended over a ditch and the rear on ice on the road. The Mustang only had to give enough pull to get the one front tire onto some solid ground and he was free, but that is the penalty (a 4 cyl mustang as a savior!) for no LS on either end.
dderocco is offline
