Looking for Exhaust info - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Power Stroke Excursions
Old 05-01-2007, 11:09 PM   #1 (permalink)
I tried to search, but really did not locate what I was looking for. I know a few here have the Banks Monster and are happy with it, but I was wondering if anyone has any experience with Magnaflow and Gibson? The Banks seems to be the highest priced, with Magnaflow in the middle and Gibson the least expensive.
Can anyone give me some feeback regarding all the above exhausts and how the fit is related to the Ex.
Last bit of info - I'm leaning towards getting a turbo back system.
Thanks for the help,
J
04 Excursion Limited 6.0 PSD 4x2, Hellwig rear sway bar and Firestone bags.
08 VW R32
Cheetah DSR
Jaysom is offline
Old 05-02-2007, 12:04 AM   #2 (permalink)
Re: Looking for Exhaust info
Can't speak about the other brands but just put a turbo back MBRP system on my 03 and the install was a breeze and fit very well. Recently put one on a 99 CC F350 Dually as well.
I honestly believe that an exhaust is an exhaust is an exhaust. I don't think they have any diffeences other than the muffler if you choose to run it and down pipe width and the materials used to make it.
I may be wrong here and others may chime in but for as much money as some of the other stuff is I just don't see how a person can justify the added expense.
To each his own though.
I found that making the cuts in the stock system before taking it all apart was the easiest route. I wish I would have known that going into it the first time as i would have saved some time, but the second exhaust went on in about half the time.
2003 E350 7.3L Extended Cargo - No Windows - Dipricol Optix: Pyro, Trans, boost - Walker BTM - Bellowed Up-Pipes - DP Tuner No Start, Stock, 60T, 80E, 120 Tailgaters special - Spectra Premium Fuel Tank Hutched & Harpooned (Ford Tank delaminated), Dual CAT Pre-pump Filter Setup
2003 GMC Sierra 2500 6.6L LB7 - Cognito UCA's, Bilsteins, Powdercoated H2's on 315 BFG AT's, PPE Standard
1993 Ford F250 7.3L "Black Beauty" 278K miles & is used to take the dogs out to play. Mods: 8,000lbs of Dog Hair.
SOLD: 2003 Excursion Limited 7.3L Mineral Gray 4x4
SOLD 2003 F250 SC LB 4x4 Silver w/ the 6.0L
HEAVYHITTER is offline
Old 05-02-2007, 10:05 AM   #3 (permalink)
aklim's Avatar
I have MBRP and it was fine
01 Excursion 7.3L Powerstroke. Gauges with AIH Delete, AIS, CCV Mod, 4' MBRP, BTS Trans, 6.0L Trans Cooler and Intercooler, DP-Tuner F5 chip, ITP In Tank Mod and Boost Annihilator, Diesel Innovation's Regulated Fuel kit, BTS Big Oil system, GTP38R Turbo with 1.15 A/R housing and BPD Stage II AC injectors. Bilstein Shocks with U code front and A code Rear.
aklim is offline
Old 05-02-2007, 11:21 AM   #4 (permalink)
Thank you for the info on the MBRP, how does it sound (loudness) and who did you purchase it from?
Thanks again for the help,
J
08 VW R32
Cheetah DSR
Jaysom is offline
Old 05-02-2007, 11:34 AM   #5 (permalink)
FamilyRide's Avatar
I agree with CMinus. The biggest difference I think, is fitment. The big "manufactures" (could be sold under different brands) will likely fit better.
I have Magnaflow only because at the time that the '04 Excursion came out, they were the only ones that had made the hanger change. MBRP even told me to go with Magnaflow because they wouldn't be ready with theirs for a while. Plus I got the Magnaflow for a steal. If I were to do it today, I'd go with MBRP simply because they have their own delete/test pipes available, and I've heard that the mufflers sound better. Although, I might consider not using a muffler.
2004 EB Excursion, 4x4, 6.0, Magnaflow Exhaust, Isspro Gauges in an under cubby pod, Fumoto, V code front springs, Revo 285's and bubba lights
FamilyRide is offline
Old 05-02-2007, 02:15 PM   #6 (permalink)
BenBone's Avatar
I got mbrph here as well. It has a little lower sound. I went turbo back and kept the cat. My wife never noticed the sound and I have yet to tell her I got it installed (over 6 months ago) I bought mine from:
Diesel Performance Parts Inc.
411 Allied Drive
Nashville, TN 37211
Toll free number : 866-455-7788
http://www.dieselperformanceparts.com/contactus.cfm
Great price too. I am now thinking of getting a system for my pickup as well.
2004 6.0l 4WD Limted Excursion
Road Armor Stealth Bumper with Titan Guard, BFG AT 305's, AR Mojave Teflon's, Tint, Stereo, Remote Start Alarm, Strobes,MBRP Turbo Back T-409 Stainless Steel Exhaust System, AFE Pro Guard 7 Mega System, Edge Insight, Coolant Filter, ARP Studs, Hybrid Turbo, EGR delete
http://bbonepics.shutterfly.com/
1999 Ford F250 CC LB 4x4 7.3L
DP F5, MBRP 4", AFE Satge II,Garrett Power Max Ball-Bearing Turbo,80hp injectors DM 3 pod, 95 Gallon Transfer/Toolbox Chest, BGF AT 295's, AR Mojave Teflon's,Tint, Road Armor Stealth Base Front Bumper with Lonestar Guard
BenBone is offline
Old 05-02-2007, 05:34 PM   #7 (permalink)
I did a write up about a year or so ago when I put on the magnaflow XL system, and turbo back with CC welded in. Worked just fine see the write up for a few tips.
Bruce
Bruce1954 is offline
