Old 05-02-2004, 01:10 PM   #1 (permalink)
Looking into a set of summer tires for the X
We bought a set of Goodyear MT/R's last Thanksgiving and have been really satisfied with them. That being said, they are obviously not the best highway tire in the world and we are going to be doing a lot of traveling this summer(my brothers are going to be seniors in high school and they are being recruited pretty heavily by D1 schools to play football). There are a bunch of camps this summer that my mom is going to be driving them to and we decided to get a set of summer tires so that the MT/R's last a bit longer. We just bought a set of the XLT aluminum rims and a set of Limited rims.
Were were looking at another set of Goodyears and want to stay away from Bridgestone\Firestones because of the whole tire fiasco if possible. In particular we were looking at the Goodyear AT/S tire. From what I have read they give a good on road ride, are quiet, and give decent off road traction as well. The only major downside I have read about is that some are very hard to balance. What tires do you guys suggest?
Also, what about putting 285's on the stock rims? My dad is worried about how 285's will affect the speedo as well as how 285's will handle and wear on a stock 7 inch wide rim.
If we do choose to go to 285's, which is what I hope we end up doing,what is the most cost effective way to adjust the speedo for 285's? The MT/R's are 265's so we will need to be able to change the speedo settings every time we swap sets of tires.
Thanks for any help you guys can give.
John
2000 Excursion Limited 4x4
265 Goodyear Wrangler MT/R's for winter
285 Bridgestone Revo's for the summer
X-codes and F-350 B-code rears
Polyurathane bushing kit
4" exhaust, intake, and gauges in the future if the price is right.
twoodballa is offline
Old 05-03-2004, 10:15 AM   #2 (permalink)
My Photos: (16)
Re: Looking into a set of summer tires for the X
Don't worry about Bridgstone tires,they are a good tire and you will not be disappointed if you buy the Revo's. I run 285,s as do a lot of other members. There are plenty of posts about the Revos if you do a search. I wouldn't run with any other tire now that I have them.
DUNC [img]/ubbthreads/images/graemlins/warmsmile.gif[/img]
EDIT: 7 inch rim/wear, no problem. Speedo will be off by 2-3 mph @ 70mph. If you want to change the speedo ,dealer can and should do it for free,they just plug in and change the settings. I havn't done this and don't really see a need for it because I know of the 2-3 mph difference.
Y2K X Ltd 4X4 PSD.Estate Green all options. DI 4 POS CHIP 50-75-100-140HP/K&N,Ram air,Regulated turbo vacume,Zoodad,Banks s/s 4" dwn pipe/exhaust,5" tip. Pre pump,tank mod, 203Thermostat and billet housing, Racor 460 filter-heater-water sensor,coolant filter,shift kit,exhaust brake, T/Q lock up,4X4 Front wheel lockout,High output alt with low rmp curve for max amps,Hellwig sway bar,4X2 Hatch Struts,Air horns,Viar 450 compressor,cab/Runningboard lights(Euro flash),Monroe Reflex,V Springs front,F springs modified rear,PowerSlot Cyro F/R, Hawk LTS F/R,Dueler Revo A/T 285/75/16,PSD badging, Isspro guages.C.B ,APCM, Locking Fuel Cap, Mud Guards, Door Edge, Bug Deflector, Window vents, Custom made Excursion leather jacket, General Coach Y2K 30' Citation T/T, Reese Dual-Cam Sway Bar, Reese Brakeman Digital control,Running light momentary switch.Back-up Camera.
DUNC is offline
Old 05-03-2004, 10:35 AM   #3 (permalink)
Location: Imperial, MO - 20 miles south of St. Louis, MO
I just bought a 2000 X Limited a few weeks ago and it already has 305/70/16 Good Year Wrangler AT/S's on it. They are pretty worn...probably about 10,000 miles left on them...but they are worn even and still ride very good! They look very meaty and tough but ride very smooth. They have not presented any problems for me and I'm thinking about buying the same tire when they are worn out. I'm going to be posting some pictures of my new rig this week.
2000 X ltd.,white/parchment 4X4 loaded,285/75/16 BFG's,dvd,converted 06 oem grill,Xtint,New style clear headlights & clear corners w/ Plasma white bulbs,Fumoto,cut front bumps,Bilstein's,ass'd X badges & ass'd door PSD badges,ISSPRO EV gauges,clear cab lights, Wet Okole front seat covers, Weathertech visors,Pro-Comp steer stab.,Tymar Perf.intake, AIH removal mod w/boost tap,muffler delete turbo back Magnaflow 4" SS exhaust,WW,ATS Housing,Turbomaster controller,CCV Bypass,Edge Evolution Programmer(Extreme every day tow heavy in 80HP Mode),Power Slot rotors all around w/Hawk LTS pads,Duralast Gold Batteries, etc.); BTS tranny & new programming if oem ever dies.
In betweeen boats so now I have a custom 2003 HD Heritage Softtail I Love! Will return to boating when sons get older at 2mm LOTO, MO! Ride with friends now...Harley much cheaper on fuel!
http://community.webshots.com/user/jweiler27
Work hard, play hard; strive to be the best at whatever you are doing!
Jeff27 is offline
Old 05-03-2004, 10:43 AM   #4 (permalink)
FamilyRide's Avatar
I've got 285 Revo's and by GPS the speedo is right on. Several people have found that to the the case. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
2004 EB Excursion, 4x4, 6.0, everything but step tubes and 2nd row chairs, Magnaflow Exhaust, Isspro Gauges in an under cubby pod, Fumoto sitting on V Codes and Revo 285's.
FamilyRide is offline
Old 05-03-2004, 11:48 AM   #5 (permalink)
My Photos: (20)
I would get LT285/75R16D Michelin LTX M/S tires if I was not towing a 41 ft TT.
jogiba is offline
Old 05-03-2004, 01:40 PM   #6 (permalink)
I bought the Michelin LTX 265's this past fall. The most impressive tires I've run on the highway with snow/ice. I drove from N.C. to MI. in the storm we had in December. There was an impressive number of cars/trucks in the ditches on I77 and I80. The stroke was VERY controllable and steady. I should have bought these years ago. There supposed to have decent off road traction but, I only go on the dunes about once a year. [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
1997 F250 HD PSD 4x4 OR Auto 3.55LS CC SRW SWB 265x75x16 Michelin LTX DP 211K mi.; Ford AIC; Fuel milege; 20.3 mpg @ 70 mph. 12.5 mpg pulling my boat,12.5K, along two lane rural roads. A number of mods ordered from DaleI. Nice round replacement DP. FS2500 by-pass oil filter installed. Fumoto drain valve. Tymar Intake installed! HX mod from Tymar installed. TFI fillneck kits installed. Auto-Rx cleaner in engine & transmission done. Switched from Rotella dino to Rotella synthetic. Amsoil 5W-30 Series 3000 installed!
FS-2500 Bypass filter installed.
Velvet rides installed. Joe Servo IDM mod installed. Rear air lift springs.
Sparkydm is offline
Old 05-03-2004, 09:22 PM   #7 (permalink)
XME
Beware of BS Revo. See my post #1772801 in the towing and hauling forum.
web page
2005 F350, dulley, crewcab
32' Holiday Rambler Presidential 03
XME is offline
Old 05-03-2004, 10:24 PM   #8 (permalink)
FamilyRide's Avatar
I've seen a couple of posts about results as you mentioned but frankly I see far more positive posts. I only tow about 7500# and mine tows solid! After the last time I towed, I discovered my tires were under inflated from what I'd like to have them at towing. The only think I noticed was the rear would "swaggle" slightly during slow manuvers which is consistant with the rear tires being underinflated. I have 285 D load range too. I wonder is the 265 E load range have something different about them? I can say 2 posts I seem with "wandering" being described were both 265 E load range.
I may tow the boat again this week with the tires up closer to where they should be towing (there at about 60psi right now compared to the 48psi they were at) and I expect it to be even better. [img]/ubbthreads/images/graemlins/wink.gif[/img]
Old 05-03-2004, 11:46 PM   #9 (permalink)
XME
The more I increased the psi the more sensitive the tires became. You might be on to something with the tire size but I suspect the D vs E load range makes a difference too. They just made me nervous when I towed with them but I’m glad they worked for you.
XME is offline
Old 05-04-2004, 09:21 AM   #10 (permalink)
I love my Michelin LTX M/S in the stock size load range E tires. I might go to a larger size but I will stick with my Michelins. I have had great experience with all my Michelins tires over the years.
Hope this helps,
John [img]/ubbthreads/images/graemlins/cool.gif[/img]
2000 Excursion Limited PSD 4X4 Dark Satin Green/Medium Parchmant Born 7/00 In-Service 10/00 All Factory Options except Transfer Skid Plate
JADFPE is offline
Old 05-04-2004, 09:57 AM   #11 (permalink)
FamilyRide's Avatar
I'll let you know how it tows with higher psi. That is a good point. Although, mine have about 4800 miles on them now and they don't feel as sensitive as they did new. I also did tow with them when they were new.
BTW, could you go back and edit your post with the link and make it hyperlinked text versus the actual URL as the link? [img]/ubbthreads/images/graemlins/smile.gif[/img] It makes the screen about 6 feet wide. [img]/ubbthreads/images/graemlins/wink.gif[/img] [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
Old 05-04-2004, 12:54 PM   #12 (permalink)
I agree with you. I have had those tires on prior vehicles and liked them a bunch.
jward is offline
Old 05-04-2004, 02:55 PM   #13 (permalink)
Thanks for all the input so far. I would rather not have to go to the dealer every time we switch sets of tires, so is there any other cheap solution to being able to change the speedo yourself?
John
Old 05-04-2004, 05:46 PM   #14 (permalink)
Send a message via ICQ to coldair
why do you change tires from the winter to the summer?
2002 Excursion LTD(PCM:NQW5)Pheltech Tru-Cowl Induction Hood BTS transmission ITP fuel system, 38/15.5/20 Toyo's on Weld 12" wide wheels,15k warn and warn 9.5k rear 4:56's ARB air lockers front and rear. Trail ready front bumper,Road Armor rear bumper light force driving lights, PIAA backup lights,Dakota digital gages, F5 DP tuner chip,Hypermax stage 2 injectors,4" exhaust, 11" Edge lift, King shocks, edge crossover steering, ORU ram assist steering
Fabtech ladder bars,TN turbo, Dynatrac conversion kit. Alpine F1, Zapco amps. two dc1100.1, three dc1000.4, 1 dc750.2, driving seas reference series front stage and Zapco competition rear fill and 2 Jl audio 13w7 subs
AP Racing big brakes, Amp Research running boards
coldair is offline
Old 05-04-2004, 09:05 PM   #15 (permalink)
XME
My bad [img]/ubbthreads/images/graemlins/phoney.gif[/img]. Thanks for the hyperlink tip I'll have to remember that.
XME is offline
