loss of mileage, loss of power and exhaust smell... - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Power Stroke Excursions
Old 10-13-2009, 06:36 PM   #1 (permalink)
Send a message via Yahoo to keith_1963
Ok, I feel like my truck has lost some of its oompfh, plus I notice about a 3 mpg reduction in mileage, and now I notice a faint exhaust smell in the cab that was never there before, It may be worse when the heat is on, but not sure.
My guess is an exhaust leak (genius huh?) My question is: Is there a likely spot?
Keith
2001 Excursion Limited. Tymar air filter. Marineco Mod, Oil change ball valve. FOR SALE.
keith_1963 is offline
Old 10-14-2009, 10:14 AM   #2 (permalink)
One more thing, I'd say the exhaust smells sort of "rich" or maybe describe it as a "sooty" smell, not what it used to smell like.
Old 10-14-2009, 10:49 AM   #3 (permalink)
up pipe would be my guess. get a bright flashlight and trace the exhaust plumbing looking for SOOT (Black). It will take 10 minutes.
2001 X, 4x4, White, Limited, PSD,. Oil Guard, Stull 6099 Grille, AFE Intake, X Monitor, Sonnax/Tricumulator, Mobil 1 ATF w/Racor tranny filter, PHP Custom Burn Chip, Walker BTM, W Code Frt Springs, Procomp Add-a-Leaf Rear, Rancho 9000XL's w/5406 SS. Pics @ http://community.webshots.com/user/txangler32
TXANGLER is offline
Old 10-14-2009, 02:02 PM   #4 (permalink)
i'm also thinking up pipe.... It's a common thing for the gaskets to wear out and leak. I think it was someone on here that said replace every 100,000 to aviod problems. And yes easy to check. Either from the top looking down behind the turbo or from the bottom looking up at the turbor. I had mine replaced at about 75,000, I think, with the international ones that get ride of the leaking gaskets.
2003 EXCURSION EDDIE B, 7.3 PS, 4" Magnaflow Turbo Back exhaust with International up-pipes. BD-Power X Monitor, AFE Stage 2 and Edge Evolution. 6.0L Trans Cooler. JVC DVD head unit with 6 Boston Pro series speakers, Rockford Fosgate 12" sub and amps. Oh ya, AC power for the Blender.
scrmn6guns is offline
Old 10-15-2009, 09:55 PM   #5 (permalink)
knoweigh's Avatar
another vote for the up pipes; the drivers side is easiest to see; down just behind,under turbo against firewall, looking in from around air intake area.
Should see some black soot on the flange.,....if it's real bad, there'll be alot of soot and maybe even on firewall.
pass side you'll need to check from under truck I believe.
I put the bellowed pipes on mine. All set now.
Yes, if you're gonna do it or have it done, it's WELL worth the extra $300 or so to go with the bellowed pipes. It's the last time it'll need done and if/when you go to sell it, that'll make a big difference to those who know this engines.
It's a PIA though if you have rusty bolts!
good luck
y2k F250 7.3 psd Calif emissions, ext cab long bed 265/75/R16 E rated tires, 190k miles 4x4 (nv271 manual t-case) 7.3 #1247981 1/18/00 (forged rods), 3.73LSD, non-diode 4R100, Dp tuner stock, 60t 60e 80t 80e, high idle. DIY 6637 air filter, wicked wheel, turbo master WG controller, turbo lifesaver, bellowed uppies, 4" downpipe & exhaust, 203t-stat, triple pod glowshift gauges (egt, tranny, boost), Ride-rite 2330 air bags, BTS VB, Sports a Western plow when the white stuff flies.
Trailers:
I'm usually towing 1 of several trailers I've built.
15ft car hauler (1000lbs empty; 5500lbs loaded)
26ft deck over car hauler (2000lbs empty; 7k loaded)
36ft car hauler (Was tongue pull; have since converted into 5er'. 4500lbs empty; 14k loaded)
https://lh5.googleusercontent.com/-g...0/IMG_4130.JPG
knoweigh is offline
Old 10-19-2009, 10:27 PM   #6 (permalink)
Dunbar's Avatar
Mine just started leaking too. I bought the bellowed up pipes from DI here in Houston. Spent $70 extra for the ceramic coated ones. Would have been 5 hours or so labor so I going to install it myself. Any tips from those who have done the job?
David Dunbar
2003 4x4 7.3 Excursion Ltd
4" exhaust, Tymar DIY, Vcode & modified Fcode, Helwig, Inappropriately valved Bilsteins, Isspro 3 gauge w/ windshield mount, DP tuner 80-60tow-40tow-HI, 6.0 31-row ATF cooler,
BTS Transmission, DI Up pipes
Tomball Texas
Dunbar is offline
Old 10-20-2009, 04:00 PM   #7 (permalink)
MotionMan's Avatar
Sounds like someone slipped in a Duramax.......better check the tag, it may be a huge ripoff swap...
2003 7.3 Excursion Limited Ultimate, Mineral Grey Metalic. DVD, Limited Slip, Badged, Cab Lights, Magnaflow, Thule Rack, Top Gun Bumper, 3" Lift, T Prodigy, Air Bags, Edge Programer, XM Radio, Extreme sound system. PIAA Lights, Toyo 325/60/18s on Chrome Alum rims.http://community.webshots.com/user/stellinm
MotionMan is offline
Old 10-20-2009, 08:02 PM   #8 (permalink)
boertje's Avatar
My Photos: (29)
Had my up pipes done at 120K as they too were leaking. My vote is up pipes.
2001 VW NB TDI speed.
SOLD: '02 PSD Excursion LTD Ultimate 4X4 Mineral Gray, PSD badges, Banks Exhaust, AIS air filter, DP-Tuner, Fuel mods, V code (2C3Z-5310-HA, AKA 3C34-5310-ADA) and modified F code (6C34-5560-F aka 5C32-5560-FA) springs with Timbren rear overloads, Bilstein shocks, hellwig sway bar, Powerslot Cyro rotors with Hawk LTS pads, IH CPS part # 1826899C93 (original CPS).
boertje is offline
