There may already have been a post or two about this but just in case...
Last weekend I was reading a post from someone who wanted to buy an X and everyone gave their positive suggestions and what issues they have had with theirs so far. I noticed that one of us had an issue with their manual hubs and they had it repaired by the dealer under warranty. I had a '79 Bronco that had manual Warn hubs and the X is the first truck I have had with push button 4x4; I have used the X's push button 4x4 many times now but the last time I tried the manual way of locking the hubs on the X was when I bought her. What the heck, I decided to try them. [img]/ubbthreads/images/graemlins/eek.gif[/img] Both sides would not turn!! I brought it down to the Dealer and it was fixed under warranty no questions asked. I think they first tried a vacuum test before deciding to replace both hubs. Cool!! Guess I am going to have to check these more often.
Thanks Bruce1954 !!!
-Mike
__________________ 2002 Excursion ~ Limited Ultimate ~ 7.3L PSD ~ 4x4
Mineral Gray, Limited Premier Group & Monochrome Package, two tone leather interior (pre-Eddie Bauer), TTT Mirrors, 3.73 Limited Slip, F250 Lariat wheels.
Kentucky Born: 4/9/2002 Improvements: 2002 PSD Badges, and lot's more!!
Need to give mine the "twist" while filling up next time
My understaning is that if you do this oonce a month or so then no problems.
Bruce
2005 X PSD Limited Mineral Grey, 4X4 Has Second row bench then Every other factory option available. Under Construction
4x2 Lift Gate Lifts,
Tekonsha Prodigy
Ford 30MM Rear Bar
Catch All Linners
750 W Inverter
06 Chrome Package Grill,bumpers and hooks. After an encounter with a Honda, (She got the ticket) 2005 Ex and Specs and Pictures of 2002 X
Agree - mine were both replaced under warranty. I had to use pliers to turn them. There are posts on this site which describe how to take the hubs apart and clean, lube and reassemble them again.
I now turn the lever every fuel up, every wash and whenever I think about it and so far, so good. [img]/ubbthreads/images/graemlins/grin.gif[/img]
John [img]/ubbthreads/images/graemlins/cool.gif[/img]
2000 Excursion Limited PSD 4X4 Dark Satin Green/Medium Parchmant Born 7/00 In-Service 10/00 All Factory Options except Transfer Skid Plate
I'm glad you brought this up. When new, mine turned really easy but I haven't checked them since. I'm about to need to fuel up so I guess I'll try the same regiment since I have 15-20 minutes fo fueling time to kill!! [img]/ubbthreads/images/graemlins/smile.gif[/img]
I had to free mine up when purchased(used)I srayed silicone spay around the hub then give a couple turns. I'll do this every oil change .It keeps the rubber seal in the hub lubricated. It's been two years now and i'm still free. [img]/ubbthreads/images/graemlins/cool.gif[/img]FJF
2000 Excursion Limited 4X4, 5" Hypermax Exhaust,TS 4 Bank chip(D/P Tuner- stock,Tow,Econo,Race) A Pillar DiPricol Gauges (white face)Hellwig swaybar,Skyjacker stablizer,AFe Stage2, Slotted&cross drilled rotors,BB Turbo,Pioneer AVIC D2 <font color="RED"> *** ALL GAVE SOME, SOME GAVE ALL(FDNY 9/11/01)***
Great, I just tried mine and they are frozen solid. I was turning them but have not done so in a while. Anyone have the link to the cleaning these things out thread? It has 55k so no warranty.
Some people are like Slinkys. They are good for nothing but still put a smile on your face when you push them down a flight of stairs. 2003 X Limited Ultimate, Mineral Grey Metalic. DVD, Limited Slip, Badged, Cab Lights, Magnaflow, Thule Rack, 3" Lift, T Prodigy, Air Bags, Edge Programer, XM Radio, Extreme sound system. 315/70/17s on AR Chrome/Aluminium.http://community.webshots.com/user/stellinm
MotionMan, I had mine off when I redid all my front end seals and to my knowledge they can't be completely taken appart.I was only able to get most of the inners out of the hub but then reached a rubber seal ( it seals for the vaccume pump operation) and couldn't go any more into it with out damageing the seal.So i just kept spraying it with silicone spray and moving a little each way intill it would move freely in both directions.And no it is just a mater of maintaining it with a shot of silicone at my oil changes. [img]/ubbthreads/images/graemlins/laugh.gif[/img]FJF
Thanks, I will start the spraying right now. I hope it works. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
