Manual Locking selector frozen - Help Please - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Power Stroke Excursions
Old 07-09-2007, 05:56 PM   #1 (permalink)
Went to manually turn the hub selector from Auto to Manual just to keep it free, but right side is frozen. Won't budge from Auto. Any thoughts on this? Need to lube? Left side is a little sticky, but does move. Thanks.
2002 4x4 7.3PSD Excursion, U-Codes, '03 Jounce Bumpers, Hellwig Sway Bar, Rancho 9000 shocks, Rancho Steering Stabilizer, Air-Lift rear air bags, Factory DVD, Driver side A-Pillar grab handle added, Rain-X wipersfront-24", rear-17"), riding on 285/75/R16 Bridgestone Revos.
IMartin is offline
Old 07-11-2007, 11:55 AM   #2 (permalink)
Re: Manual Locking selector frozen - Help Please
check your PMs
01 Excursion, Ltd. PSD, EBM2, 4x4,arrived 11/22/00. Adds:TRUCK VAULT,Automate Alarm,3 Autometer Carbon Fiber Gauges on A Pillar,TTM.
Tecate Virgin is offline
Old 07-12-2007, 07:01 PM   #3 (permalink)
could you let me in on this too, I have the same problem with my x. I have to use a set of plyers to lock one side in
01 Excursion Limited, PSD, 4wd, auto
Volant cold air intake, straight pipe
sker is offline
Old 07-13-2007, 11:43 AM   #4 (permalink)
if you go back in time there are threads on this subject.
look at the hub. there is a stone in the center of the hub about 1/8 in wide and couple inches long. that stone will absorb a penetrating oil. spray the oil several times on the stone till it quits absorbing the oil and then let it sit for awhile. then go back and try moving the hub. it may take a pair of plyers the first time to get the hub moving but you will feel it freeing up with each rotation. I'm by no means an expert on this but thats what the threads of the past said. Apparently, the stone absorbs the oil and delivers it to the mechanism. Hope someone can verify this and you guys don't shoot this messenger. lol It seems to work on mine.
Old 07-14-2007, 01:52 AM   #5 (permalink)
Thanks abunch. I recall that thread and will try that remedy.
IMartin is offline
Old 07-16-2007, 03:34 PM   #6 (permalink)
The stone is to let air in and out to operate the hub. However, it also allows dirt and oils to get.
John
2000 Excursion Limited PSD 4X4 Dark Satin Green/Medium Parchmant Born 7/00 In-Service 10/00 All Factory Options except Transfer Skid Plate
JADFPE is offline
