Old 12-26-2002, 05:31 PM   #1 (permalink)
Middle Seat Down for Good??
My son folded the passenger middle seat down to set his TV as always while traveling. Got home and seatback will not unlock so that I can fold it back to upright position. Any suggestions?
2000 Excursion Limited 2x4, 3.73 LS,PSD/Auto,ATS turbo shroud,Badging,BullyDog 4" exhaust,AIS,HX crossover,ISSPRO gauges/A-Pillar,SuperChip 1705, Pre-Pump & In-Tank Mod,Banks TransCommand, ZooDad, Baldwin Oil ByPass,Ford AIC, F350 rear springs, Helwig Rear Sway Bar,Michelin's LTX MS
2003 Sunnybrook/Mobile Scout & Hensley Arrow
sail684 is offline
Old 12-26-2002, 07:04 PM   #2 (permalink)
Re: Middle Seat Down for Good??
Did you try sitting on the seatback to see if it would relieve the pressure off the handle?
Y2K Excursion
monsta is offline
Old 12-27-2002, 07:18 AM   #3 (permalink)
03X
1st time posting here......Same thing happened to mine at the dealer when they were showing it to me. The shop guy said the floor mat got stuck???? Not sure what he ment by that, but its worth a look....
03 "X" XLT Prem. PSD 7.3L, X-codes, 295 BFG AT/KO's, Helwig rear anti-sway bar, S/D Grill, Badged, Rear Entertainment W/ 7" monitors in Headrests
03X is offline
Old 12-27-2002, 10:45 AM   #4 (permalink)
I doubt you broke anything. I loaded my X with 2000 lbs of concrete a while back and 1000 lbs of that was on the back of the middle row folded down.
I had about 10 4x4 posts that the concrete was sitting on so half the weight was entirely supported on the seatback.
2001 Black Excursion, 4x4, XLT, PSD, LS, (EBM2), Super-Duty grill, 4" MBRP exhaust, Bilsteins, X-springs, OilGuard bypass filter, 295's, Badges, Suvlights harness, APC headlights, Weatherboots, Centramatics, Clear corners, AIC w/ITP mount, ISSPRO EVs, BTS trans, Open element intake, ATS compressor housing, Thule rack, BD Torqloc, F350 rear blocks, Randy Ellis lightbar with a couple of Lightforce 170s, Front receiver hitch, DP Tuner chip
1975 Ford Bronco, neglected since I bought the Excursion
AJ'sDad is offline
Old 12-27-2002, 11:09 AM   #5 (permalink)
Glad to hear I'm not the only one who has (or had) this problem........ I thought I would never get mine upright again, but I ended up just pushing down while pulling on the lever and then pulling up really hard several times before it came up - have not had the problem since, so I don't know if I cured it or it is a problem lurking for a more inconvenient time....... [img]/ubbthreads/images/graemlins/smirk.gif[/img] I did it by myself - maybe you could get some help - don't be afraid to break it, it is useless until it is upright again as it is........ [img]/ubbthreads/images/graemlins/shrug.gif[/img]
2001 'X' Ltd 4x4 - 4" exhaust/TS Performance 3 position flip chip/Triple gauge pillar mount/K&N air filter/rebuilt and upgraded TC and transmission (local guru)/grill guard/front lighted logo/superduty grill/Lund screen front/clear corners/cowl induction hood/ Hella 550s / X code front springs / Add-a-leaf rear springs / Powershot 2000 / Evans NPG+ Coolant / Rancho RS9000X / http://www.webshots.com/search?query=beastdriver&new=1
A Rusch is offline
Old 12-27-2002, 12:00 PM   #6 (permalink)
Thanks. I'll go out and give it another try.
sail684 is offline
Old 12-27-2002, 03:00 PM   #7 (permalink)
I know what you mean about the middle seat....I've always had trouble determining which lever does what.....But there is also another factor to consider, and that is for me, because I'm tall, I have a tendency to push the FRONT seat back, and I find the rear seat hooks up on it and won't come UP...push the front seat forward a little just might give you the clearance you need....Try it, it just might work for you...
Brute-ute is offline
Old 12-29-2002, 12:53 PM   #8 (permalink)
I have had this happen a couple of times. The seat is actually jammed against the bottom cushion, which is jammed against one of the front seats. Move the front seat forward and then also push forward on the seat bottom to relieve the pressure. This should help. Good luck!
02 x limited ultimate, 8" fabtech lift, 38" swamper tsl radials, scmt, autometer ultralite guages, pioneer in dash dvd with 5.1 surround sound, xm radio
http://www.fordtruckworld.com/account-photos.asp
bigxcurs is offline
Old 12-29-2002, 05:07 PM   #9 (permalink)
Thanks to all. Went out and pushed down hard on folded down seat back then pulled the lever. It folded right back to upright position. Thanks for all the suggestions.
sail684 is offline
» Sponsor Links
»Garage Storage and Cabinets
