Old 09-28-2000, 02:33 PM   #1 (permalink)
Middle Seat Flip Down Armrest Upholstery Separation
My upholstery came apart on the flip down armrest in the center of the middle seat. Seems that it was held together with some sort of plastic joint thing. I cannot see anything that is broken, but I also cannot determine the “trick” to get it back together. One part has kind of a hooked over trough in it, and the other is basically flat with a slight ridge. Anyone know how this goes together? Is there some part missing? Am I stuck making my first visit back to the dealer to have it fixed?
Thanks!
4X2 Estate Green Limited PSD Excursion. CD Changer, L/S 3.73, PSD Badging,Stull Grille. Plate # 4TRESS. Pillar mount Pyro, Boost & Trans Temp. Fumoto Drain valve. K&N Air. F-D Hitch cover. Truck Born 3/17/00; Took Delivery 3/31/00!
John_M is offline
Old 09-28-2000, 05:06 PM   #2 (permalink)
My Photos: (16)
Re: Middle Seat Flip Down Armrest Upholstery Separation
John
step 1
First the bad news. After you have struggled with this and almost got it together ( for the Nth time ) you succeed, only to watch it
come apart in spite of you.
Pull down hard and streeeeetch it, as you bring it up ,fold it over and insert it
down into the other plastic rod. They will
lock together. As you let it go, it will unwind and the two will be locked together again....hopefully.
repeat step 1
repeat step 1
step 2
REPEAT STEP 1 VERY SOON AFTER FIX.
Y2K X Ltd 4X4 PSD.Estate Green all options. DI 4 POS CHIP 50-75-100-140HP/K&N,Ram air,Regulated turbo vacume,Zoodad,Banks s/s 4" dwn pipe/exhaust,5" tip. Pre pump,tank mod, 203Thermostat and billet housing, Racor 460 filter-heater-water sensor,coolant filter,shift kit,exhaust brake, T/Q lock up,4X4 Front wheel lockout,High output alt with low rmp curve for max amps,Hellwig sway bar,4X2 Hatch Struts,Air horns,Viar 450 compressor,cab/Runningboard lights(Euro flash),Monroe Reflex,V Springs front,F springs modified rear,PowerSlot Cyro F/R, Hawk LTS F/R,Dueler Revo A/T 285/75/16,PSD badging, Isspro guages.C.B ,APCM, Locking Fuel Cap, Mud Guards, Door Edge, Bug Deflector, Window vents, Custom made Excursion leather jacket, General Coach Y2K 30' Citation T/T, Reese Dual-Cam Sway Bar, Reese Brakeman Digital control,Running light momentary switch.Back-up Camera.
DUNC is offline
Old 10-02-2000, 08:32 AM   #3 (permalink)
Thanks DUNC! It seems to have worked. Hopefully it will stay put.
4X2 Estate Green Limited PSD Excursion. CD Changer, L/S 3.73, PSD Badging,Stull Grille. Plate # "4TRESS". Pillar mount Pyro, Boost & Trans Temp. Fumoto Drain valve. F-D Hitch cover. Truck ordered 2/21; Born 3/17; Arrived at Dealer 3/27; Took Delivery 3/31!
John_M is offline
» Sponsor Links
»Garage Storage and Cabinets
