Old 07-10-2004, 11:42 PM   #1 (permalink)
Might buy a 00 or 01 X-some basic questions
Seems to be tons of V10s out there but few diesels. What letter in the VIN indicates a diesel? Some dealers leave diesel out of the description. I am familiar with the powerstrokes but not the Excursion. Currently have a Expedition but looking for better fuel mileage from the diesel, heated seats for the wife, cheaper tires than those 17" on the Exp and possible lowering the monthly payment through better interest rates. Was the 3.73 axle ratio standard on diesels? What was optional for the diesels? I can't believe they have a 44 gal tank!
Kelly
95 F250 4x4 SC, Alloy wheels, Catectomy, 3.55's, E4OD, Dark Green, Ground effects package, Warn manual hubs, 12k mod, Redline Oil throughout, Big Hayden cooler, Factory AIC, Fuel shimmed, TYMAR air filter & HX mod, Ceramic Hypermax dp BD 5/95, TEE5 code, Timbrens, SCMT, boost, tranny, and pyro in Rocky's overhead pod
90 F350 SRW with Loral Sprayer setup, 38.5" Super Swampers, 4wd, 5 spd, 7.3 IDI, 93 factory turbo motor with Luk clutch, homemade air intake, 3" "99" downpipe, 3.5" straight pipe exhaust
Autometer boost, pyro
01 Excursion Limited 4x4, V10 box stock, Firestone Steeltex AT tires-Thanks Firestone! Axle code C1
Kelro is offline
Old 07-11-2004, 12:36 AM   #2 (permalink)
Re: Might buy a 00 or 01 X-some basic questions
when I was looking I noticed that as well, but I'm sure if its a PSD thats a major big plus, and would usually be noted! I found a 01 XLT Premium with 40K miles for $26 very nice with leather and other cool stuff just no wood trim!?
06 Mega Cab CTD
06 F150 KR
08 Polaris Ranger RZR
06 Buell Ulysses
00 XR650L
damodt is offline
Old 07-11-2004, 07:01 AM   #3 (permalink)
Kelly
The eighth digit is the engine code. "F" is what you're looking for. I recently acquired an '01 EX. Limited. I believe the 3.73 was standard and yes they do have a 44 gal. tank. Mine does not have heated seats.
[img]/ubbthreads/images/graemlins/cool.gif[/img]
Clyde
2001 Excursion Limited 4x2, Born 8/20/00, Engine 8/10/00, Magnaflow + Aeroturbine for drone control, Isspro, DP Tuner, 60T, 80E, 120Play, Hellwig, AFE Stage II, Ride Rites, Bilsteins, blah, blah.
Clydeglide is offline
Old 07-12-2004, 10:48 AM   #4 (permalink)
3.73 rear end ratio was standard and no optional ratios from the factory. The only choice was a standard open rear or an optional limited slip rear.
Hope this helps,
John [img]/ubbthreads/images/graemlins/smile.gif[/img]
2000 Excursion Limited PSD 4X4 Dark Satin Green/Medium Parchmant Born 7/00 In-Service 10/00 All Factory Options except Transfer Skid Plate
JADFPE is offline
Old 07-12-2004, 11:00 AM   #5 (permalink)
Location: Imperial, MO - 20 miles south of St. Louis, MO
I recently made the jump from an Expedition to the X as well. Best thing I ever did...it is much more vehicle and the diesel definitely gets better mileage especially towing. I love the room and the look of it. [img]/ubbthreads/images/graemlins/grin.gif[/img]
2000 X ltd.,white/parchment 4X4 loaded,285/75/16 BFG's,dvd,converted 06 oem grill,Xtint,New style clear headlights & clear corners w/ Plasma white bulbs,Fumoto,cut front bumps,Bilstein's,ass'd X badges & ass'd door PSD badges,ISSPRO EV gauges,clear cab lights, Wet Okole front seat covers, Weathertech visors,Pro-Comp steer stab.,Tymar Perf.intake, AIH removal mod w/boost tap,muffler delete turbo back Magnaflow 4" SS exhaust,WW,ATS Housing,Turbomaster controller,CCV Bypass,Edge Evolution Programmer(Extreme every day tow heavy in 80HP Mode),Power Slot rotors all around w/Hawk LTS pads,Duralast Gold Batteries, etc.); BTS tranny & new programming if oem ever dies.
In betweeen boats so now I have a custom 2003 HD Heritage Softtail I Love! Will return to boating when sons get older at 2mm LOTO, MO! Ride with friends now...Harley much cheaper on fuel!
http://community.webshots.com/user/jweiler27
Work hard, play hard; strive to be the best at whatever you are doing!
Jeff27 is offline
Old 07-12-2004, 11:53 AM   #6 (permalink)
FamilyRide's Avatar
Actualy I think the 5.4 get's a 4:10 rear. Of course wiht a 5.4 in an Ex. you need every little bit of help you can get!! [img]/ubbthreads/images/graemlins/laugh.gif[/img]
2004 EB Excursion, 4x4, 6.0, everything but step tubes and 2nd row chairs, Magnaflow Exhaust, Isspro Gauges in an under cubby pod, Fumoto sitting on V Codes and Revo 285's.
FamilyRide is offline
Old 07-12-2004, 12:00 PM   #7 (permalink)
I believe he is talking about the Excursion; I do not believe a Expedition has an option for a diesel engine. [img]/ubbthreads/images/graemlins/cool.gif[/img] (At least not as of now. [img]/ubbthreads/images/graemlins/depressed.gif[/img])
John [img]/ubbthreads/images/graemlins/cool.gif[/img]
JADFPE is offline
Old 07-12-2004, 05:40 PM   #8 (permalink)
FamilyRide's Avatar
I was too. [img]/ubbthreads/images/graemlins/laugh.gif[/img] An Excursion with a 5.4 get's 4:10's I believe, not 3:73's which are standard with the V10 and PSD. Of course I don't know if anyone here cares about an Ex. with a 5.4. [img]/ubbthreads/images/graemlins/biggrin.gif[/img] That's just crazy (in that SNL Safari guy's best voice [img]/ubbthreads/images/graemlins/laugh.gif[/img])
Old 07-12-2004, 06:42 PM   #9 (permalink)
mike650's Avatar
Ok, the VIN number was answered already.
3.73 Limited Slip Rear Axle Ratio was and still is an option.
Heated seats was also an option that you could order with leather seats. If you purchased a Limited X, it came standard.
The wheels on the Limited were 16".
Here is a link for the 2001 model.
http://www.ford-trucks.com/specs/2001_excursion.html
Lots of specs for the 2001 model.
http://www.ford-trucks.com/specs/2001_excursion_1.html
Here is a link of the 2004 options:
http://www.fordvehicles.com/suvs/exc...;consp=1194901
Good Luck!!
2002 Excursion ~ Limited Ultimate ~ 7.3L PSD ~ 4x4
Mineral Gray, Limited Premier Group & Monochrome Package, two tone leather interior (pre-Eddie Bauer), TTT Mirrors, 3.73 Limited Slip, F250 Lariat wheels.
Kentucky Born: 4/9/2002
Improvements: 2002 PSD Badges, and lot's more!!
mike650 is offline
Old 07-13-2004, 12:43 AM   #10 (permalink)
Thanks for all of your replies. I have seen very few advertised with the 5.4 motor. I have that in my Expedition with 3.73 gears and 17" tires. It shifts out of OD on too many hills in my opinion so I am sure it would be inadequate for an Excursion. My 95 diesel pickup can take any hill empty without dropping any speed and never shift out of OD even with 3.55 gears. I am looking mainly at the Limiteds because of the heated seats were most common on them. Current ratio is about 15 V10s for every diesel. I don't care about the year or miles too much but I don't want a white one which seems to rule out about 1/3 of the diesels. I suppose I am too cheap but I was hoping to get a diesel 4x4 limited for the low $20s with miles under 125000. I doubt if the diesel will pay for itself when all things are considered but I would rather have a higher payment on the loan rather than look at eaking 12 mpg out of it which is what I assume the best all around mileage would be on a V10.
For the guy that jumped from the Exp to the X, are the seats any more comfortable. My wife has a bad back and the seats are very important. Our Exp seats are the leather Eddie Baurer edition with power adjustments.
Thanks for any help or advice you can give
I love these diesels and this forum!
Kelly
PS-Do all diesel X's have cats on them or were there just certain years that has them? Probably a mute question as if it did have one it would get gutted.
Kelro is offline
Old 07-13-2004, 09:44 AM   #11 (permalink)
Thanks for any help or advice you can givePS-Do all diesel X's have cats on them or were there just certain years that has them? Probably a mute question as if it did have one it would get gutted.
Seats - I came from an Expedition. Both set of seats were okay but not the best I have every been it. It took me a little to get the seats adjusted for me. Saying that, I am a big guy that needs some room.
Cat - My Excursion never had a cat. (Except when my daughters brings her inside the Excursion to watch a movie. [img]/ubbthreads/images/graemlins/shrug.gif[/img])
Have a good one,
John
JADFPE is offline
Old 07-13-2004, 12:17 PM   #12 (permalink)
My Expy seats I thought were pretty comfy...but I do think the X seata are moe comfy. When my brother took a ride in 2000 X for the first time he said it was like sitting in a lazy boy. My wife has not complained after to trips towing the boat! The extra room is great especially if you have kids! Finally, you should be able to find a X Limited in that price range. I bought mine with 78,000 miles on it for $21,900. There are many colored V-10's here in the St. Louis area for $18,000 - $21,000 range...even though I would personally not by an X without the Powerstroke!!
Jeff27 is offline
» Sponsor Links
»Garage Storage and Cabinets
