On a 2002 Excursion Limited, can the standard mirrors be replaced with the Telescopic power htd mirrors? If so what would be involved? Does anyone know if the wiring matches up? Thanks
2002 Excursion 4x4 Limited Catch All Floor Mats with Cargo Liner,Pre Tank Mod, In Tank Mod, AIC with ITP Bracket, A-Pillar with Isspro EV Gauges with Red Pointer, TTM and Twin drop down Video Screens with overhead console. DVD, VCP and XBOX.
I know you can on the 2000 and 2001, so I'd assume that the 2002 is the same. I understand it's a simple switch out and the wiring does match up. Several on here have done it. I was going to do it, but I'm able to see around my camper without any trouble.
I have an '02 Ltd. Ult. It was a piece of cake to swap out the mirrors. If you get the TT mirrors, make sure you get the heated ones as the connectors are different than the others. It takes about 30 minutes to do it. I just did it last night.
Best of luck!
-Tim
'02 X with just about everything from the factory, BTS Tranny, Finally got David Lott's flip chip, Cyclone Fan, Tank mod, dual circuit mod, pre-pump mod, Magnaflow Stainless Tuner Exhaust, Gauges, Rancho RS9000's all around, Hellwig sway bar, Timbren Load booster (to help with the crappy front springs), Weather Tech vent guards and bug deflector, Garmin color GPS and a bunch of other things... but other than that totally STOCK!
If you don't mind me asking what did the mirrors run you price wise? Thanks again.
