modified F code rear leaf springs???? - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Power Stroke Excursions
Old 04-09-2009, 02:20 PM   #1 (permalink)
I just installed the v-codes on the front, and am thinking about doing the rears right away.
I snapped a front so HAD to get it done asap...
what's a modified F?
please explain what to get and what to do?
gratzi gents
2001 Ford Excursion Limited 7.3 Turbonetics Ballbuster Turbo Spearco Intercooler AFE Stage 2 intake 4" Exhaust Stacked Tuners V code front leaf springs
tnuottila is offline
Old 04-09-2009, 06:16 PM   #2 (permalink)
gratzi gents
Look under "caryt" "Pharmer" and my self and search by rear springs and these user names. We all did it a bit different but with similar results.
That is to say we got the results we wanted.
I originally used the middle (third from the bottom) and the second from the bottom leaf from the original G codes. It was more than I needed so I removed the second from the bottom and only have the one added leaf that must be shortened on one end. To shorten this leaf I cut it off at the plastic pad hole and drilled out the rivit hole from the bail or loop around the original G code to fit the plastic pad.
I did not use the F code variable rate bottom leaf but do have the original G code anti-wrap half leafs installed.
Modified F code might be a tad misleading:
What you do is disassembled the original g codes modify the mid leaf if you are using it and ADD one or more leafs to the new F code pack.
I think Pharmer used the bottom two leafs added to the F code and then the new variable rate but take a look at his pictures.
CaryT used B codes and I think the same set up he has pictures also.
I did some the original work on the V code swap in early 02 but these guys and others worked out the rears.
2005 X PSD Limited Mineral Grey, 4X4 Has Second row bench then Every other factory option available.
Just about finished!(never tell the wife you are done)
4x2 Lift Gate Lifts,
Tekonsha Prodigy
Ford 30MM Rear Bar
Catch All Linners
750 W Inverter
06 Chrome Package Grill,bumpers and hooks. After an encounter with a Honda, (She got the ticket)
2005 Ex and Specs and Pictures of 2002 X
Bruce1954 is offline
Old 04-09-2009, 06:44 PM   #3 (permalink)
therabbittree's Avatar
what are the f codes used in stock? how do they differ from b codes ? how is the ride with either?... Since I have the cummins swapped in my ex..I was debating going with a x code front spring instead of v codes, for the added weight.. the cummins only weight 1-200 lbs more then the 7.3. do you have the f code part #? If I go with a rear anti sway bar? I already know to upgrade to the 30mm bar..how do the Hellwig aftermarket bars differ from the ford bar?
Deo
2000 Excursion XLT 4x4, 12V P Pump Cummins, 0-ringed head, AE G56 6 spd, southbend FE clutch, guages, lazer dv, 370's, Black Vinyl floor, 285 Nitto Dura Grapplers, 4" remote BD Exhaust Brake, 4" exhaust, Working on Twin turbos HX50 9cm and BHT3E 20cm with tial external wastegate, looking for 2008 XL front clip
http://picasaweb.google.com/therabbittree/Excursion02#
2005 Excursion Eddie Bauer 4x4, 6.0L, Rear Capts. Dark Green
1992 W350, srw, dump flat, 5sp, pods
1996 Passat TDI Wagon, worked
therabbittree is offline
Old 04-09-2009, 08:19 PM   #4 (permalink)
isn't there a buy and bolt on heavy duty rear spring for the excursion??? anybody?
Old 04-09-2009, 10:35 PM   #5 (permalink)
Shure
I am sure there are aftermarket solutions
As far as ford parts use F code add bottom two leafs from old X g codes
It is all bolt together
BTW Fs replaced the Bs they have similar specs but not the same
If you will do the searches all the information is right here on this site
F codes are used on 250s and possibly 350 SRW
Old 04-10-2009, 09:01 AM   #6 (permalink)
Pharmer's Avatar
I added last two leafs from Excursion spring pack to the F-codes. F-codes are from 05-06 SD without the lower helper spring. I did not use the Excursion anti-wrap add on. If you don't add to the F-codes it will ride worse because the Ex is heavier in the rear. You also need the extra leafs to maintain ride height in the rear relative to the front end. There are pictures in my sig.
03 Excursion Eddie Bauer 4WD 7.3L, 265 REVOS, U's and F's(mod), 3rd row headrests
68 Cougar xr7 390GT, 05 E320 CDI http://www.supermotors.net/vehicles/registry/3724
Pharmer is offline
Old 04-10-2009, 09:23 AM   #7 (permalink)
I checked you pictures.. looks nice ! Do the stock u bolts work fine?.. I have to order some stock u bolts front and rear any how..just wondering before I order them etc. Smentioned longer threaded factory u bolts etc...
Deo
Old 04-10-2009, 09:35 AM   #8 (permalink)
Pharmer's Avatar
Yes, stock U-bolts.
Pharmer is offline
Old 04-10-2009, 10:12 AM   #9 (permalink)
boertje's Avatar
My Photos: (29)
I did this 2 years ago and it works great. Here is the link to the post where I describe the modified F code. F-code modifications-another way.
There are pictures in my gallery that show what I did too.
2001 VW NB TDI speed.
SOLD: '02 PSD Excursion LTD Ultimate 4X4 Mineral Gray, PSD badges, Banks Exhaust, AIS air filter, DP-Tuner, Fuel mods, V code (2C3Z-5310-HA, AKA 3C34-5310-ADA) and modified F code (6C34-5560-F aka 5C32-5560-FA) springs with Timbren rear overloads, Bilstein shocks, hellwig sway bar, Powerslot Cyro rotors with Hawk LTS pads, IH CPS part # 1826899C93 (original CPS).
boertje is offline
Old 04-10-2009, 11:27 AM   #10 (permalink)
Feedback Score: 3 reviews
I only have experence with my modded B codes and they ride great and tow very well. I have helped many over the years do this mod and can get you instructions and pics, PM me with your email.
Since the price for a 30mm factory bar is so reasonable thats my choice.
Correct shock valving is a key factor in the ride comfort and handling...Bilsteins.
The perfect setup IMO is a 3" hanger kit V and B codes a 30mm bar and dual Bilsteins in front. The Ex needs wider rims..9" min with 12.5" wide tires to get a stable base under it. These mods will turn the unsafe handling EX into a canyon carving joy to drive.
Cary
Cary
caryt is offline
Old 04-10-2009, 02:48 PM   #11 (permalink)
I could not remember who used the middle leaf, thanks for the post.
Using the middle leaf you hav to do a little cutting and modding but it can be done.
My springs look like these Modified F code new leaf. - TheDieselStop.Com Photo Hosting
EXCEPT I have the anti-wrap and not the thick variable rate on the bottom.
As has been said if you don't add the leafs you will be on that variable rate all the time and the rear end will kick you in the tail.
I did not want to ever feel the varable rate so I did not use it.
I have had some very heavy loads on the back of the X and the one extra leaf is more than enough. If it is not; go slow you are way overloaded.
Tekonsha Prodigy
Ford 30MM Rear Bar
Catch All Linners
750 W Inverter
Old 04-10-2009, 09:58 PM   #12 (permalink)
what do you estimate these modified springs weight rating to be?
