Old 03-07-2005, 07:50 PM   #1 (permalink)
Moog ball joints-Greasing
I had moog ball joints installed on my excursion. Well I went to grease them this last weekend and it was easy to get at the zirks on the bottom ball joint....however the top one was shall we say tricky. The zirk points straight down toward the knuckle joint. In order to be able to even remotely get at it with my grease gun and flexible hose was to turn the wheels all the way to one direction then engage the 4 wheel drive and back the vechicle up until the joint rotated to a point that I could get at it.
Is there a better way or easier way. If I had a small 90 degree angle end for my grease gun that might work...but I have been unable to find something like that.
So I give....what is the trick???
Ken Fanta
2000X PSD Bilsteins, Rear Helliwig, Rancho Steering Stablizer, Dual remote bypass oil filter, K&N air filter
kfanta is offline
Old 03-07-2005, 09:00 PM   #2 (permalink)
Re: Moog ball joints-Greasing
Remove the straight fittings and replace them with some 90 degree ones.
Excursion Pics
2000 Excursion Limited 4x4 Dark Satin Green Arizona Beige 7.3 DIT, AXDO, 3.73 LS, DP Tuner F5, TERMINATOR II w R-IPR, Adjustable Boost Regulator, Turbomaster, EBPV Delete, Air Dog, ITP Regulated Fuel Return, Fuel Cooler, Tags 1&2, Harpooned Tank, Magnaflow XL Exhaust w Aeroturbine 4040L, Sonnax/Tricumulator, 8 Autometer Sport Comp 4 Gauge A Pillar 4 Gauge Overhead, Ford APCM, Crimestopper Remote Starter With Remote Fast Idle, Ford AIS w Zoodad, W Code Front Modified B Code Rear springs, Rancho RS9000X, Rancho 5406 Stabilizer, Hellwig Rear Sway Bar, BFG Rugged Trail TA, V10 Trans Cooler w Dual Electric Pusher Fans, Coolant Filter, IAH Delete, (((XM))) Line Of Fire Light, Ford Cab Lights, 05 Headlights w GOS Conversion Harness, Jimmi Jammers, 03 Lighted Painted Tow Mirrors w C-BETR, PSD Badges, Pullrite Hitch, Prodigy Brake Controller, Born 01/29/00
fordmastertech is offline
Old 03-07-2005, 09:56 PM   #3 (permalink)
That is what I was thinking...but how much do I have to take apart to be able to remove the old zirks and put in new ones?
Or should I go back to the mechanic that put them in and say "what were you thinkin...would like to show me how I am supposed to grease that zirk?"
Ken Fanta
kfanta is offline
Old 03-07-2005, 11:01 PM   #4 (permalink)
Personally I would bring it back. I thought the fittings that Moog suppled were the 90 degree type for the uppers but I could be wrong, I work on too many vehicles to keep them all straight in my mind. If you want to do it get some of the shortest 90 degree fittings you can find and just put them in. You will have to rotate the axle around to gain the clearance you need to get them installed. There is not too much room in that area as you have already found out. Moog may have changed this since the last time I have used their parts. A long time ago they used to give you the 90 degree fittings to lube the joints and then you had to install plugs because the axle joints were just too close, this was on the Dana 44 axles if I remember correctly.
[img]/ubbthreads/images/graemlins/shrug.gif[/img]
Excursion Pics
Old 03-09-2005, 11:27 AM   #5 (permalink)
How are they removed...do they just screw into place and then I can screw in the new ones. I have seen zirks with threads. Do I just use a pair of "good" pliers and unscrew the old ones and then screw in the new ones? Or is it more complicated than that? I have seen some that are "pounded" into place?
Thanks.
Ken Fanta
kfanta is offline
Old 03-09-2005, 12:05 PM   #6 (permalink)
They should just screw in. I would use a small open ended wrench. If the pliers fit use them.
Excursion Pics
Old 03-09-2005, 01:24 PM   #7 (permalink)
Check out the pictures of my new ball joints and zerk fittings. I installed a 90 deg. fitting in my lower ball joints. It was very close!!!!Actually TOOOOO close!!! SOOOO I bought several zerk 90's and "practiced" grinding the little nipple end down. Went through two and then got the right depth and installed the modified fitting. I've pumped grease in several times and no leaks.
Again check the pics!!!
tginz
2001 PSD Excursion Limited, 3.73LS - White/Beige, minus the roof rack crossmembers, Door Badged, Quad Pod - 4 Autometers (EGT, Eng Oil, Trans Oil, & Coolant Temps. on the A-pillar), Turbo Temp Monitor, Firestone Ride-Rite Rears, Edelbrook IAS Shocks, X-pel Light Protection, Weather-Tech Window Deflectors, Grill Guard, GoRhino Hitch Step, Bob Riley's Coolant Filter System, Magnefine Tranny Filter, Garmin Street Pilot III GPS. Fumoto Drain Valve, Gofia Bug Screen, Custom Built Wheel-less Trailer, XM Radio - Always detailed body, undercarriage, & engine.
SEE MY TRUCK PICS. http://community.webshots.com/user/tginz
tginz is offline
Old 03-09-2005, 01:35 PM   #8 (permalink)
Thanks for the information...by nipple end I am not sure what end you are refering to. The end that goes up into the ball joint, or the rounded 90 part so it is shorter or the end that the grease guns connects to??
Thanks,
Ken Fanta
kfanta is offline
Old 03-09-2005, 07:12 PM   #9 (permalink)
nipple end is the end the grease gun goes on
04 Excursion
01 Dodge 3500
99 Corvette Road Race
96 Corvette Grand Sport
84 GMC 7000
DOGdiesel316 is offline
Old 03-10-2005, 07:48 AM   #10 (permalink)
Sorry I was off line for a while - I guess we gotta work sometime. By the nipple I mean the "ball" on the 90 deg turn. NOT the threaded end and NOT the fitting end. The ball on the 90.
You'll notice mine are ground down to clear.
tginz
tginz is offline
Old 03-10-2005, 10:08 AM   #11 (permalink)
When I did mine, the 90's were too close also. You can get a 90 degree grease head attachment (not the swivel attachment) for your grease gun that will do the job. Most good farm stores and auto parts stores have them. The attachment plugs into your straight gun fitting just like a zerk fitting. It's easy to put on and take off. Dale
7.3 Excursion, it's a diesel thing.
Chicago MOB member.
shamuex2000 is offline
» Sponsor Links
»Garage Storage and Cabinets
