Old 11-16-2004, 05:01 PM   #1 (permalink)
More pics of my 2002 Excursion Limited Ultra with Z-Link
These are some updated pics of my X since I had gotten it all cleaned up.
Underneath
Close up on front wheel well
Another front wheel close up.
Posing
Front
Posing again
Getting Twisted
Getting Twisted2
Getting Twisted3
10.5" Skyjacker Z-link, 38x15.50x18 Nitto Mud Grapplers, American Racing Mojave Teflon 18" wheels, Banks 4" exhuast w/Power Elbow, Garrett Powermax BB Turbo, Semi Hidden Warn 16.500lb winch, K&N FIPK, Dayco Converter, 4 pos 150hp max custom chip by Garmon Diesel, Too many stereo DVD goodies to list.....
rab986 is offline
Old 11-16-2004, 05:58 PM   #2 (permalink)
Re: More pics of my 2002 Excursion Limited Ultra with Z-Link
The 3 "twisted" ones do not work ...
volzalum is offline
Old 11-16-2004, 06:19 PM   #3 (permalink)
The twisted ones need the file name in all lower case, such as:
Some great examples of EXTREME articulation.
If I am looking at it correctly, the front axle is supported by a coilover spring on top of the shock, the leaf spring has been eliminated, is that correct?
Also, is there much bump steer when the right side front compresses due to a large bump or obstacle?
2000 Excursion Limited born 11/99 4x4 Toreador Red ext./gray int. 7.3PSD, 3.73LS, Skidplates, Pwr/Htd TeleMirrors, 6CDchanger, HtdBuckets, LT265/75R16E Bridgestone Dueler A/T Revo, Ford Wraparound deflector, PSDV8 badging, RoofMarkerLights, Tekonsha Sentinel brake cntrlr, PCM=AXD0, Edge Evolution II, WalkerBigTruck Muffler, RS9000, RS5410, Performance Friction 2 piece rotors/pads, Sylvania SilverStars, Landyot Gen III, Air Lift rear air bag system, Amsoil from MAXoil.com in diffs/trans/transfer 251k miles.
ExcursionPSD is offline
Old 11-16-2004, 09:18 PM   #4 (permalink)
WOW THAT IS A NICE EXCURSION!!!!!!!!!!!!
**DADS**2003 Ford F-350, Larait, CrewCab,(((XM))), 6.0 PSD, 4X4
**MOMS**2004 Ford Excursion, 6.0 Powerstroke Diesel, 4X4
**MINE**2003 Ford Mustang, Cobra R Red
1998 Saturn Gl Wagon
1998 Contry Coach Allure 36ft. Motorhome 8.3L 330hp. Cummins
1997 Kenworth W-900L Show-Truck, 1 Million Miles, 3406-E 550 Cat Tweaked&Tuned to perfection(original engine),
15 Company Trucks
Toy Pics
Truck Pics
rubberbandman is offline
Old 11-16-2004, 10:10 PM   #5 (permalink)
Ok...sometimes I get a little too confident and don't check my work...LOL See what happens. I did manage to get all of the links working though.
Yes...you are correct, The front end is now supported buy the new King Coilover Shock. The ride is still very good, more plush than the 8" lift I had before this and I am able to adjust the ride height very easily. So far I am very happy with this setup and love the ride. I never really noticed how you get the spring feedback reverberation, from a leafspring. That is totally gone now. I just want to go ramp it. LOL [img]/ubbthreads/images/graemlins/warmsmile.gif[/img]
Bump steer? Not bad. I have an extreme drop pitman arm which you can see pretty much paralled the steering arm with the Track bar. Plus the dual stabalizer helps tremendously. It is noticable but not like you would expect from such a big truck. I am working on a highsteer setup that will work with the coil overs but that is coming slowly. All I have so far are the spindles.
rab986 is offline
Old 11-17-2004, 09:31 AM   #6 (permalink)
CHPMustang's Avatar
That is some clean work rab986 [img]/ubbthreads/images/graemlins/smokin.gif[/img]
Bill
2002 Ford Excursion 7.3L 4x4 XLT
9th Annual Powerstroke Rally this Oct 3-5 2008 in Caddo Mills,Texas
CLICK HERE for more Information & Register Here
CHPMustang is offline
Old 11-22-2004, 01:45 AM   #7 (permalink)
Thanx.....I'm proud of my X and the work I put into it (anal really) so I try not to cut any corners.
rab986 is offline
Old 11-22-2004, 06:29 AM   #8 (permalink)
Very Very clean truck...what kind of brushguard/winch combo is that? Link?pics? info?
How do you like the black (teflon?) wheels?
Lets see some muddy pics...I want roostertails at least 25feet!!
2004 6.0L 4wd Limited Mineral Gray 3.73 2nd Row Buckets
Mods: Remote start alarm, strobes front+rear, extensive stereo (JL Stealthbox,Sirius Sportster), 2wd rear hatch mod, bfg at 295's,
Bones04EX is offline
Old 11-23-2004, 12:50 AM   #9 (permalink)
Very nice. I was at Skyjacker last month and took a look at the Dually that they have the Z link installed on. It's a clean set-up. Also very $$$. I thought that it only came in a 6" or 8" version. How did you get 10.5"? Also yours is very flexy in the rear. What are you running in the back?
Again sweet X.
Laters, Ryan
A1980GMC is offline
Old 11-23-2004, 10:31 PM   #10 (permalink)
clamgulch's Avatar
Beautiful work! Congrats on a job well done!
clam the powerstroke grinch
2000 Excursion LTD 4x4
Slightly tweaked HPCR 5.9 Cummins
Allison 1000 5 speed auto
clamgulch is offline
Old 12-05-2004, 12:00 AM   #11 (permalink)
Rab, great looking X you got there! [img]/ubbthreads/images/graemlins/smokin.gif[/img] Can someone explain this suspension setup to me? It seems to me that the rear links and the front links are working against each other. Wouldn't you get more wheel travel if you had a traditional 4 link setup like the monster trucks run? In my head, the two arcs that the two links create, are working against each other, thus not maximizing wheel travel It would only go to a certain point, then begin to bind...[img]/ubbthreads/images/graemlins/shrug.gif[/img]
'01 PSD 7.3L Excursion Limited EBM1, 8.5" lift, rear Deavers, 37" PJs, 16x10 Black Rockcrawlers, ORU dual shock hoops, Rancho 9ks all around, Magnaflow T304 system w/5" tip, FTVB w/50/50 mix regular Mercon/Mobil 1 in trans, Mobil 1 PS flush, Tri-pillar loaded w/Di PriCols (EGT,trans, boost), TS 4 pos. switch chip, ConFerr Rack, Cobra CB, TT/sig mirror conversion, 170 hi-amp alt, Hi Lift equipped, UltraDuty rearend cover w/Mobil 1 syn. w/OE friction modifier, Hutch/ITP intank mod, 2 Micron Dahl PrePump, FPR Jack shim mod@ 70psi, 203 deg T-stat & billet housing, Hawk pads, Centric rotors, Valvoline synthetic brake fluid 105.5k so far...
Recent mod: Dieselsite Coolant filter 4/21/05 @ 1100 @72 degs. F ambient temp ;P
Currently sittign in the driveway with a blown up tranny
Dirty X
Clean X
Vindicator is offline
» Sponsor Links
»Garage Storage and Cabinets
