Old 11-14-2004, 08:07 PM   #1 (permalink)
MPG, Excursion vs. F250/350
I made a post similar to this on the general forum and received many replies however none of them were from Excursion drivers. What in the heck are you seeing for fuel economy?? Mine is so bad it's pissing me off!! (sorry) I'm getting 12-13 city, 13-14 Highway at 85 and 8-10 while towing an 11,000 lb. travel trailer at 75 mph. This is all in south Florida where there are no hills. People with pickups SAY they are getting 5 mpg more all around than me. What about you guys?????
I also have a lot of goodies that should improve my mpg.......
FullThrottle is offline
Old 11-14-2004, 08:54 PM   #2 (permalink)
Re: MPG, Excursion vs. F250/350
um those mods (diablo sport)and 36inch tires will lower your mileage plus your truck weighs at least 750lbs more than a pickup
You are getting only 1-2mpg lower than me... but I live at 10k feet
01X x-codes, swapped in Dana 60, rear add a leaf and air bags. Blizzard 810 power plow (expands to 10') The WORK truck.
05 GMC topkick 5500 4x4 152" wheelbase Duramax/Allison 11' steel flatbed Swenson stainless spreader, central hydros, Boss 10'V Leds Strobes
77 Bronco 302, stock looking except for the chameleon paint
BoomtownBrewpub is offline
Old 11-14-2004, 09:25 PM   #3 (permalink)
Had a 2001 Excursion 7.3l, now have an 05 F350 (in sig). looks like both are getting the same mileage- 15 around town 18+ freewaw 11+ towing 7,000lb horse trailer. All hand calculated.
2005 F350 CC Lariat LB DRW PSD 4.10ls, Dual Alt. Tow Command, Upfitter Switches, ESOF, Moonroof, BW Turnover Ball, LineX, Chrome Tow Hooks, Hadley Air Horns, Optima Batteries, JackRabbit & ToolTop, hooked to a 4 star 3horse trailer, to pull our 8 very spoiled horses. <font color="blue">Truck Pics
karmikacres is offline
Old 11-14-2004, 09:44 PM   #4 (permalink)
EBX
Do you actually think you deserve better mpg at those speeds?
'03 Eddie Bauer, Excursion 6.0 PSD, 4WD, 3:73 Limited Slip. 6.0 build date March '03, Premier group, video pkg, roof-rack (lighted), 3 pillar pod, Timbrens-on back, Hensley Arrow.
'04 TT Dutchmen 35ES-DSL, laminate sides, 3 slides, w/ Hensley.
'06 28' Enclosed Car Hauler, Dual Cam HP setup.
Check link for pics. & info.
http://community.webshots.com/user/ebx03
EBX is offline
Old 11-14-2004, 09:50 PM   #5 (permalink)
Ok I think I know other than the tires one thing is killing you
SPEED
I know, have the same problem
I can get 12.7 in the winter loaded but no trailer at about 10K+ and some hills driving fast.
I can get 21 OBSERVING THE SPEED LIMIT
Speed will kill your MPGs
Speed while towing will destroy it
I wish some one who drives fast would put on a gear vendors over drive
1795 RPM at 85 sounds perfect to me Like 17 MPG??????????????? [img]/ubbthreads/images/graemlins/smile.gif[/img]
See sig for mods
Bruce
2005 X PSD Limited Mineral Grey, 4X4 Has Second row bench then Every other factory option available.
Under Construction
4x2 Lift Gate Lifts,
Tekonsha Prodigy
Ford 30MM Rear Bar
Catch All Linners
750 W Inverter
06 Chrome Package Grill,bumpers and hooks. After an encounter with a Honda, (She got the ticket)
2005 Ex and Specs and Pictures of 2002 X
Bruce1954 is offline
Old 11-14-2004, 10:24 PM   #6 (permalink)
CHPMustang's Avatar
85 in an Excursion [img]/ubbthreads/images/graemlins/eek.gif[/img] I'd only attempt that speed and then some in my Mustang [img]/ubbthreads/images/graemlins/smokin.gif[/img]
Around town we get 15-18 and 18-21+ @ 60-71 Mph depending on headwind and grade%
I have my list of mods as well.
2002 Ford Excursion 7.3L 4x4 XLT
9th Annual Powerstroke Rally this Oct 3-5 2008 in Caddo Mills,Texas
CLICK HERE for more Information & Register Here
CHPMustang is offline
Old 11-15-2004, 05:45 AM   #7 (permalink)
My 01 "X" has averaged 15.08 mpg for 126.5K
2006 Lariat Chrome Edtion Red F350 CC 4X4 Dually w/4:10 Gears Born 04/26/06 w/ color matching speedliner, PCM Reprogramed to Level "L",@ 24,535 miles AMSOIL Front to Back, AMSOIL By Pass Filter BMK-11, Amsoil Coolant Nitrogen in all 6 tires @ 75 PSI W/ 34.2 x 102" wide Coachman Royal TT.
Gone but not forgotten 2001 “X” 7 years / 218K w7.3
Ken1 is offline
Old 11-15-2004, 06:13 AM   #8 (permalink)
Send a message via ICQ to coldair
11 mpg
2002 Excursion LTD(PCM:NQW5)Pheltech Tru-Cowl Induction Hood BTS transmission ITP fuel system, 38/15.5/20 Toyo's on Weld 12" wide wheels,15k warn and warn 9.5k rear 4:56's ARB air lockers front and rear. Trail ready front bumper,Road Armor rear bumper light force driving lights, PIAA backup lights,Dakota digital gages, F5 DP tuner chip,Hypermax stage 2 injectors,4" exhaust, 11" Edge lift, King shocks, edge crossover steering, ORU ram assist steering
Fabtech ladder bars,TN turbo, Dynatrac conversion kit. Alpine F1, Zapco amps. two dc1100.1, three dc1000.4, 1 dc750.2, driving seas reference series front stage and Zapco competition rear fill and 2 Jl audio 13w7 subs
AP Racing big brakes, Amp Research running boards
coldair is offline
Old 11-15-2004, 06:31 AM   #9 (permalink)
Once the engine got broke in (30,000 miles) I have been gotten 19.4 MPG all driving. This is calculated in an excel spread sheet for all fillups.
Slow down to 70 on one road trip and see what it does, your 4X4, lift and big tires are not helping any.
RoyC
2005 Limited, 6.0L PSD, 4X2, Mineral Gray, 3.73 LS. Excursion Build date 02-08-05 6.0L 2005MY Engine Build date 01-03-05 Huntsville, Ala.
2005 50th anniversary Thunderbird Red with all
options except hardtop.
Old Ride: 2003 Excursion 6.0 L March 2003 Build 73,000 with no significant issues.
RoyC is offline
Old 11-15-2004, 08:24 AM   #10 (permalink)
13-14 mpg @85mph isn't far off. On my trips to and from school in Michigan turned out about like that. From Dayton, OH to the Michigan border I would do 65-70mph because the ohio cops are everywhere. I would get at least 18mpg on that part of the trip. As soon as you hit the michigan border going up 23N, the speed limit jumps to 70, but there are hardly ever a cop on that road so 85-90 is the normal flow of traffic. That part of the trip mpg drop like a rock. 13-14 is very normal for that speed. Remember X's are bricks and with your lift and tires you have a larger brick than most.
John
2000 Excursion Limited 4x4
265 Goodyear Wrangler MT/R's for winter
285 Bridgestone Revo's for the summer
X-codes and F-350 B-code rears
Polyurathane bushing kit
4" exhaust, intake, and gauges in the future if the price is right.
twoodballa is offline
Old 11-15-2004, 08:57 AM   #11 (permalink)
Dude, unless your 85 years old and can't see that far ahead, 85 mph in anything isn't fast especially if you live in Florida where every road you drive on, you can see the horizon. Hell, the speed limit in some areas is 75. Second, if you own a Mustang and still think 85 is fast, get rid of it. [img]/ubbthreads/images/graemlins/grin.gif[/img]My truck purrrrrs....... at 85. Hell, I still get passed by Semi's!!
I guess my point is, speed is not the problem here. Guys with F250/350's are saying 17 mpg at the same speeds with as many or more mods than me and they live in the hills. 3-4 miles per gallon difference is more than a little. .5-.7 mpg on these diesels is a little.............Everyone I know with 6.0's say my fuel consumption sucks however, I'm the only one with the Excursion. BTW, on my truck, slowing down to 70 only saves .2-.4 mpg depending on the head wind. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Old 11-15-2004, 09:00 AM   #12 (permalink)
Speed is killing you mileage. It takes fuel to run at that speed. [img]/ubbthreads/images/graemlins/shocked.gif[/img]
Enjoy the ride but you are going to use a large amount of fuel at that speed.
John [img]/ubbthreads/images/graemlins/smile.gif[/img]
2000 Excursion Limited PSD 4X4 Dark Satin Green/Medium Parchmant Born 7/00 In-Service 10/00 All Factory Options except Transfer Skid Plate
JADFPE is offline
Old 11-15-2004, 09:09 AM   #13 (permalink)
85 MPH isn't fast until something happens out of your control. I hope you have a good life insurance policy as well as your occupants. I have been sideways (RR tire hypdroplaned)at 50+ MPH in my X and would not like to duplicate it again.
BTW, once I slowed down to 65-70 I gained back 1-2 mpg. In town with 35's and a 100 hp chip I get 16-16.5.
If you still don't think 85 is fast we can set out some obstacles for you in texas to slalom around (ladders, wheel barrows, refridges) so you can practice ONCE!
Tx
2001 X, 4x4, White, Limited, PSD,. Oil Guard, Stull 6099 Grille, AFE Intake, X Monitor, Sonnax/Tricumulator, Mobil 1 ATF w/Racor tranny filter, DieselPower Custom Burn Chip, Walker BTM, W Code Frt Springs, Procomp Add-a-Leaf Rear, Rancho 9000's w/5406 SS. Pics @ http://community.webshots.com/user/txangler32
TXANGLER is offline
Old 11-15-2004, 09:20 AM   #14 (permalink)
LOL...that's the truth. You forgot the most important one, the Texas Speed Bump...ARMADILLOS.
Texas does seem to have a lot of road debris. I didn't realize it until I moved back to Houston after living in Los Angeles for 3 years. Houston, San Antonio, Austin, and Dallas all have a lot of road debris from some reason.
A local Houston radio station jokingly has a "Road Debris" game when the traffic announcer reports debris in the road. For some reason, mattresses and ladders are always a safe bet! I understand ladders, but mattresses?!?!?!
Tailgate
2000 X PSD Ltd, 4x2, 3.73 LS, DP Tuner 16 position chip, Autometer gauges, AIS intake w/ Zoodad, Tymar H/X, Walker BTM, Dahl 100 fuel filter, Coolant Filter, 203 Tstat, Billet Tstat Housing, AIH delete, Hellwig swaybar, KYB shocks, Amsoil all-around, PSD Badging, Extra Tint, Bridgestone Dueler Revo A/T tires
Tailgate is offline
Old 11-15-2004, 09:32 AM   #15 (permalink)
Location: Imperial, MO - 20 miles south of St. Louis, MO
I wouldn't necessarily believe everything you hear! Also, common sense should tell you that you are driving an almost 4 ton beast around at higher than normal speeds...and yours has larger tires and some performance enhancements. I can tell a noticeable difference in mpg when driving 55 - 60 mph. compared to 65 - 75mph let alone 85 mph [img]/ubbthreads/images/graemlins/eek.gif[/img]. I understand that general traffic tends to speed thus contributing to your/my delinquency trying to keep up and not get ran over. But, I do not complain to people about what mileage I'm getting when I do this. I avg. about 16 - 17 mpg all around driving for tank of gas (this includes city and highway). I get about 13 mpg towing about 7,000 lbs. of boat and trailer to LOTO where I do go up some pretty serious hills. Mine is pretty much stock for now. If you want good mileage do what I'm told to do any time I complain to people with "normal" size vehicles, "buy something smaller". Just my $0.02...Good Luck!
2000 X ltd.,white/parchment 4X4 loaded,285/75/16 BFG's,dvd,converted 06 oem grill,Xtint,New style clear headlights & clear corners w/ Plasma white bulbs,Fumoto,cut front bumps,Bilstein's,ass'd X badges & ass'd door PSD badges,ISSPRO EV gauges,clear cab lights, Wet Okole front seat covers, Weathertech visors,Pro-Comp steer stab.,Tymar Perf.intake, AIH removal mod w/boost tap,muffler delete turbo back Magnaflow 4" SS exhaust,WW,ATS Housing,Turbomaster controller,CCV Bypass,Edge Evolution Programmer(Extreme every day tow heavy in 80HP Mode),Power Slot rotors all around w/Hawk LTS pads,Duralast Gold Batteries, etc.); BTS tranny & new programming if oem ever dies.
In betweeen boats so now I have a custom 2003 HD Heritage Softtail I Love! Will return to boating when sons get older at 2mm LOTO, MO! Ride with friends now...Harley much cheaper on fuel!
http://community.webshots.com/user/jweiler27
Work hard, play hard; strive to be the best at whatever you are doing!
Jeff27 is offline
