Old 07-26-2001, 08:24 PM   #1 (permalink)
Muffler replacement
Has anyone replaced the existing muffler with a straight through muffler. Looking under the X the factory pipes inlet and outlet pipes are offset. Searching this site I noticed several pickups have done this but I dont know if those pipes are offset. I would prefer the muffler to be 409 stainles steel like the factory system. I would also like a 403 stainles steel 4" tip. Any information woould be greatly appreciated.
2000 Excursion Limited White 2WD 7.3 Diesel A Pilar 3 guages, PP III. Magnaflow 4 muffler, TURBO DIESEL badge. Cherry wood console extention. Bilstein shocks
Bob Braam is offline
Old 07-27-2001, 04:05 AM   #2 (permalink)
Re: Muffler replacement
I replaced the muffler with a straight DynoMax 17224 muffler.
Raise rear of vehicle about 3 feet (forklift). Loosen right rear shock absorber to facilitate removal of pipe.
Cut right in front and rear of the stock muffler, the new muffler had the same overall length.
Twist the front pipe 180 degrees, so that it goes down 3-4 inches into the muffler instead of up.
TIG weld to front and rear portion of piping.
Replace hangers from orig. muffler to pipe on bend in front of rear axle.
I also replaced the 90-degree outlet bend behind the rear wheel with a straight double 3" out the back. Nice touch...
Bjørnar Huse Ålesund, Norway
2000 PSD Excursion Limited - DynoMax - TurboLifeSaver - TorqLock - Luverne Guard - SuperChip - MileMarker Hydraulic winch, 1994 Escort 1.3i, 1947 Studebaker M15
bjornar is offline
Old 07-27-2001, 05:11 PM   #3 (permalink)
Bob:
If you want a "high quality" muffler, I would suggest a Flowmaster. It's not considered a straight-through muffler, but is designed in such a way that it has little to no resistance of airflow.
The problem with DynoMax mufflers is that they are made of tin (or seem to be). You can bend them with your hand in the shop. The Flowmasters are made of stainless steel and are extremely rugged. Call them for an exact model, but would suggest one of their mufflers that have 3.5" in, and 4" out.
I am wanting to put one on my X, but am thinking about also changing from 3.5" pipe to 4" all the way through the exhaust system.
Tailgate
2000 X PSD Ltd, 4x2, 3.73 LS, DP Tuner 16 position chip, Autometer gauges, AIS intake w/ Zoodad, Tymar H/X, Walker BTM, Dahl 100 fuel filter, Coolant Filter, 203 Tstat, Billet Tstat Housing, AIH delete, Hellwig swaybar, KYB shocks, Amsoil all-around, PSD Badging, Extra Tint, Bridgestone Dueler Revo A/T tires
Tailgate is offline
Old 07-28-2001, 01:03 AM   #4 (permalink)
Send a message via ICQ to ceferino
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by Tailgate:
... If you want a "high quality" muffler, I would suggest a Flowmaster. ... <HR></BLOCKQUOTE>
If'n you don't mind waking up napping children, rattling windows, and keeping decent folks next to you from hearing their own stereos. I've tried FMs twice now and they were way too loud [img]images/icons/mad.gif[/img] Never again. I use Walker Super Turbos and have never worn one out yet.
Not to mention how loud exhaust attracts the local constabulary... [img]images/icons/shocked.gif[/img]
[green]RenoHuskerDu!! 92-F350CCXLT-7.3IDI-4x4, pumped E4OD, LSD, 33s, skid plates. 00-XLTD-7.3TDI-4x4, 4 lift, Locker, LSD, 35s, SafariGard bumper, skid plates. F-350 & X Pictures...OINK, OINK....Bilge Rats! NRA lifer. Black belts for Jesus!
ceferino is offline
Old 07-28-2001, 02:08 AM   #5 (permalink)
The Dynomax Ultra is stainless steel, very heavy, and surprisingly quiet. I recently installed one on my CC expecting some overall increase in noise. In fact, there was no discernable increase at idle or normal running speed. It is only louder, and not by much, when you accelerate hard and the turbo is whining.
2000 Excursion LTD 4x4, Oxford White, PSD 3.73,K&N, PPIII, Dynomax, Ramsey Winch Mount/Grill/Brush Guard, Edelbrocks, Rancho SS, Hellwig Stabilizer, PIAA 90 PRO XT Lights, 295 BFG's, X springs, 2000 F350 CC PSD 4x4 Woodland Green, 3.73 K&N, PPIII, 295 BFG's, Edelbrocks
POLR BR is offline
Old 07-28-2001, 01:08 PM   #6 (permalink)
Ditto the Dynomax. Love this muffler. I programmed the engine with the Hypertech months before installing the Dynomax, so I got the opportunity to see how much difference the muffler alone made in power and mileage. A wonderful improvement in power and more mileage difference than the PPIII made, especially towing mileage (increased about 1.5 mpg).
Terry
2005 E-350 XLT Ext Passenger Van, 6.0 PSD, Power Seat, Keyless Entry, ScanGuage, Great Large Family Rig!
Sold:
2000 EXCURSION 7.3 PSD 4X4, K&N, Edelbrock IAS, ProComp SS, Superchips MT, Dynomax exhaust, Thule racks, Bridgestone Dueler AT Revo 285.
tlphlps is offline
Old 07-28-2001, 07:18 PM   #7 (permalink)
You have a part number on that Dynomax??? I have the Walker BTM and I'm thinking of going back to stock due to the noise.
Thanks!!!!
2000 Excursion Limited 2x4, 3.73 LS,PSD/Auto,ATS turbo shroud,Badging,BullyDog 4" exhaust,AIS,HX crossover,ISSPRO gauges/A-Pillar,SuperChip 1705, Pre-Pump & In-Tank Mod,Banks TransCommand, ZooDad, Baldwin Oil ByPass,Ford AIC, F350 rear springs, Helwig Rear Sway Bar,Michelin's LTX MS
2003 Sunnybrook/Mobile Scout & Hensley Arrow
sail684 is offline
Old 07-31-2001, 04:54 PM   #8 (permalink)
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by sail684:
Thanks!!!!
<HR></BLOCKQUOTE>
Myself and several others have the Walker Big Truck Muffler (#21470 3.5" in/out centered 7" diameter, 30" long body). I do not think mine is much louder than stock, except during cold warmups when the EBV is cycling, giving the 747 jet sound. I think you should check that they did a good job of using sound isolating muffler hangers and that no part of the exhaust system is touching the body or frame.
Good Luck!
2000 Excursion Limited born 11/99 4x4 Toreador Red ext./gray int. 7.3PSD, 3.73LS, Skidplates, Pwr/Htd TeleMirrors, 6CDchanger, HtdBuckets, LT265/75R16E Bridgestone Dueler A/T Revo, Ford Wraparound deflector, PSDV8 badging, RoofMarkerLights, Tekonsha Sentinel brake cntrlr, PCM=AXD0, Edge Evolution II, WalkerBigTruck Muffler, RS9000, RS5410, Performance Friction 2 piece rotors/pads, Sylvania SilverStars, Landyot Gen III, Air Lift rear air bag system, Amsoil from MAXoil.com in diffs/trans/transfer 251k miles.
ExcursionPSD is offline
Old 08-01-2001, 02:05 AM   #9 (permalink)
I would like to change out my stock muffler to the Walker BTM. Where have you guys that have one got it? Will I need to put in a flex piece of line? If so where is the best place to get me one? and Is it necessary to cut the down pipe or can I add it to the exhaust line by the muffler?
Thank you for the help
Oley
7.3L PSD Excursion LTD, Chestnut with Medium Parchment Int., 3.73LS, Hellwig rear anti-sway bar, Edelbrock shocks, Michelin LTX 265 M/S, PP III, Tricumulator spring set, & Sonnax modulator kit, Walker BTM, 3 pod a pillar, W/ Western Diesel gauges, Ram Air, & Turbo Brake, BD Pressureloc and Autoloc, AXD0, with LL #8, fuel pressure spring 86 PSI, Oil Guard by-pass, Firestone Ride Rite, Cyclone Power Fan
BRUTYUT is offline
Old 08-01-2001, 02:10 AM   #10 (permalink)
Straight exhaust, only way to go. Loud, but worth it. When I tow past whimpy gassers, worth every penny of taking out the muffler.
2000 PSD Excursion w/ 2000 30' TT, 1999 Arlen Ness HD, 1981 Rolls Royce Silver Spur, 1969 LS6 454 Z28 Camaro, 1957 Mercedes 190SL w/ Twin-Turbo 350 Chevy, 1921 Studebaker
mcadam is offline
Old 08-02-2001, 04:11 PM   #11 (permalink)
NAPA has them, so does Summit. Since it is longer than the stock muffler, my installer did not need to add any pipe to do the job. I have not added any flex pipe, I have a minor drone at highway speeds, but it is not objectionable, more of a hum.
He did cut the factory tail pipe and exhaust pipe as close to the original muffler as possible.
Old 08-08-2001, 08:28 PM   #12 (permalink)
Those of youwho responded to this post I wish to thank you for your help and providing additional "food" for thought. I ended up with the Magnaflow 24" stainles muffler which Iam extremely satisfied with. Now on to the next problem of getting rid of the drone the X has for the past year.
Old 08-08-2001, 08:34 PM   #13 (permalink)
I forgot to mention that Dennis with Inovative Truck Products helped me, since he handles both the Dynomax and the Magnaflow. As numerous others have mentioned he is an asset to us power strokers.
Old 08-10-2001, 03:31 PM   #14 (permalink)
I got the Walker BTM. Not too loud, but created a metal-on-metal resonance at idle. I solved it with flex-pipe. Flex pipe also reduced the drone.
2001 Black Excursion, 4x4, XLT, PSD, LS, (EBM2), Super-Duty grill, 4" MBRP exhaust, Bilsteins, X-springs, OilGuard bypass filter, 295's, Badges, Suvlights harness, APC headlights, Weatherboots, Centramatics, Clear corners, AIC w/ITP mount, ISSPRO EVs, BTS trans, Open element intake, ATS compressor housing, Thule rack, BD Torqloc, F350 rear blocks, Randy Ellis lightbar with a couple of Lightforce 170s, Front receiver hitch, DP Tuner chip
1975 Ford Bronco, neglected since I bought the Excursion
AJ'sDad is offline
» Sponsor Links
»Garage Storage and Cabinets
