Old 12-20-2004, 07:48 PM   #1 (permalink)
MotionMan's Avatar
!!!Must Read>>>>Front Hubs!!!!!!
You know how we always complain about the locking hubs becoming frozen and we are unable to turn them? People talk about just ditching them and using auto or taking them apart. Well I just found out why. That strip down the middle of the turn handle is a pourous rock and is designed to suck in WD40 or penetrating oil. THIS IS ABSOULUTLY AMAZING!!!! Go try it and watch it suck the fluid in like a sponge, around the edge or rim also. It sucks the fluid in so fast you could put a whole can in one side!!! This same stone sucks in water and salt also!!!!!! It will destroy the inside gears!!!! Every oil change spray it on. I could not turn mine if my life depended on it and this works like a miricle....for freeeeeeeee. [img]/ubbthreads/images/graemlins/smile.gif[/img] Now who else knew this one????? My oil change guy told me.....a friend for life. [img]/ubbthreads/images/graemlins/cool.gif[/img]
Some people are like Slinkys. They are good for nothing but still put a smile on your face when you push them down a flight of stairs. 2003 X Limited Ultimate, Mineral Grey Metalic. DVD, Limited Slip, Badged, Cab Lights, Magnaflow, Thule Rack, 3" Lift, T Prodigy, Air Bags, Edge Programer, XM Radio, Extreme sound system. 315/70/17s on AR Chrome/Aluminium.http://community.webshots.com/user/stellinm
MotionMan is offline
Old 12-20-2004, 08:49 PM   #2 (permalink)
CHPMustang's Avatar
Re: !!!Must Read>>>>Front Hubs!!!!!!
I remove the chrome hub covers when I hit em' [img]/ubbthreads/images/graemlins/wink.gif[/img]
2002 Ford Excursion 7.3L 4x4 XLT
9th Annual Powerstroke Rally this Oct 3-5 2008 in Caddo Mills,Texas
CLICK HERE for more Information & Register Here
CHPMustang is offline
Old 12-20-2004, 10:09 PM   #3 (permalink)
MotionMan's Avatar
It does make a mess. Thats why the oil change idea. [img]/ubbthreads/images/graemlins/cool.gif[/img]
Old 12-20-2004, 11:36 PM   #4 (permalink)
CHPMustang's Avatar
Add spraying the hubs along with the oil change and greasing the zerks for the maintenance routine [img]/ubbthreads/images/graemlins/cool.gif[/img]
Old 12-21-2004, 12:18 AM   #5 (permalink)
Well, if nothing pops up tomorrow, I plan on replacing both hub assemblies. Going to soak those lockouts with PB Blaster too! [img]/ubbthreads/images/graemlins/smokin.gif[/img]
'01 PSD 7.3L Excursion Limited EBM1, 8.5" lift, rear Deavers, 37" PJs, 16x10 Black Rockcrawlers, ORU dual shock hoops, Rancho 9ks all around, Magnaflow T304 system w/5" tip, FTVB w/50/50 mix regular Mercon/Mobil 1 in trans, Mobil 1 PS flush, Tri-pillar loaded w/Di PriCols (EGT,trans, boost), TS 4 pos. switch chip, ConFerr Rack, Cobra CB, TT/sig mirror conversion, 170 hi-amp alt, Hi Lift equipped, UltraDuty rearend cover w/Mobil 1 syn. w/OE friction modifier, Hutch/ITP intank mod, 2 Micron Dahl PrePump, FPR Jack shim mod@ 70psi, 203 deg T-stat & billet housing, Hawk pads, Centric rotors, Valvoline synthetic brake fluid 105.5k so far...
Recent mod: Dieselsite Coolant filter 4/21/05 @ 1100 @72 degs. F ambient temp ;P
Currently sittign in the driveway with a blown up tranny
Dirty X
Clean X
Vindicator is offline
Old 12-21-2004, 11:06 AM   #6 (permalink)
I actually think the strip was designed to allow air through it so that the vaccum system can pull the diaphragm in to auto engage the hubs. So, if you want to the maximum amount of lube in their, spray them up real good, throw your ESOF to 4x4 High and let the vaccum system pull the hubs in. When they get pulled in they will draw even more lube into them. Work great.
...danny
2001 'X' 7.3l PSD 4x4 Limited
Oxford White / Medium Parchment
K&N Air filter, Husky Floor Liners
20' H&H Speedloader MX Tiltbed Trailer
Bilstein shocks(BE5-6208 front, BE56209 rear) $259.80 to my door.
AllAboutJeeps is offline
Old 12-21-2004, 06:33 PM   #7 (permalink)
Okay guys, this one freaked me out [img]/ubbthreads/images/graemlins/tongue.gif[/img] Went outside (wearing latex gloves and carring a hand full of paper towels) and soaked 1/4 of a can into each hub. Sucked it right up, until I turned the hub and it spit it right back out. Will hit them again this weekend.
Gary
2003 4X4 LTD Edition PSD Excursion Rancho 9000's, Hellwig swaybar, U Codes,; 2001 F550 4X4 XLT PSD Smeal 6T Pump Hoist; 2001 F250 CC 4X4 XLT PSD
anoxic is offline
Old 12-22-2004, 07:54 PM   #8 (permalink)
By turning it you must have drawn the diaphram in contact with the knob.This happens when I wash the truck,water always spits out.I put some 3 in 1 oil on the edge and turned it a few times in the fall,it is drawn in by capillary attraction.
My Photos
<font color="red">2002 EXCURSION, PSD, XLT Premium, 4X4, Medium Wedgewood Blue,8' Meyers E-Z Mount Snow Plow,14.1" rear LCD video monitor and DVD, FS2500 bypass oil filter, Mobile 1 synthetic ATF, Rotella T 5w-40 synthetic oil, Baldwin transmission filter, K&N filter charger with Zoodad mod., Banks Trans Command, Bilstein shocks, Rancho steering stabilizer, Hellwig rear anti-sway, XM Commander satellite radio, C-Bet'r convex mirrors, factory remote start, daytime running lights, Silverstar headlamps, "Xtra" reverse lights, Hidden Hitch front hitch receiver.Cabela's Winter Grill Cover by Fria</font>
1996 Ford Crown Victora P-71, white, blue cloth buckets, super clean and super fast.
2006 Subaru Forester 2.5X Premium(I highly recommend it in snowcountry)
2005 Gulf Stream Canyon Trail 29TEBH,with Reese D/C HP
JOE_M is offline
Old 01-05-2005, 02:33 PM   #9 (permalink)
I had to try this one for myself, I just walked outside and tried it...vola. [img]/ubbthreads/images/graemlins/smile.gif[/img]
Pretty cool guys.
MotoMan44 is offline
Old 01-07-2005, 12:09 PM   #10 (permalink)
THANKS!!! I did this trick last night and I can turn the knob now!!
A1980GMC is offline
Old 01-07-2005, 12:58 PM   #11 (permalink)
FamilyRide's Avatar
Geez, I need to try it just for grins. I always thought it was a built in finger nail file, just never could figure out why they put it there!! [img]/ubbthreads/images/graemlins/eek.gif[/img] [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
2004 EB Excursion, 4x4, 6.0, everything but step tubes and 2nd row chairs, Magnaflow Exhaust, Isspro Gauges in an under cubby pod, Fumoto sitting on V Codes and Revo 285's.
FamilyRide is offline
Old 01-07-2005, 01:31 PM   #12 (permalink)
CHPMustang's Avatar
It's one of those things that I believe is not in the manual [img]/ubbthreads/images/graemlins/grin.gif[/img]
Old 01-07-2005, 06:40 PM   #13 (permalink)
If that white strip is porous, how does it keep the water out??? [img]/ubbthreads/images/graemlins/frown.gif[/img]
Dirty X
Clean X
Old 01-09-2005, 12:49 PM   #14 (permalink)
Ok...I have a 01 EX with 2 really pain in the ass hubs...I just went outside and try'd it!!!
And I cant believe it really works!!!
Thanks for the tip guys!!! [img]/ubbthreads/images/graemlins/cool.gif[/img] [img]/ubbthreads/images/graemlins/cool.gif[/img] [img]/ubbthreads/images/graemlins/cool.gif[/img]
Now to do it on my 99F250SD [img]/ubbthreads/images/graemlins/laugh.gif[/img]
99 F250SD 4x4..5in Exhaust.. MircoTuner
01 EX....stock
outplayn is offline
Old 01-09-2005, 08:09 PM   #15 (permalink)
If that white strip can't keep H2O out, then wouldnt this cause premature hub failure??? Does anyone know how deep that strip goes doen into the hub? I'm thinking of dremeling it out and using some sort of 2-part epoxy to fill the gap [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Dirty X
Clean X
