Old 01-09-2006, 04:22 PM   #1 (permalink)
My Photos: (12)
Need advice removing seats
I've been sound deading my 2000 X. To make the job easier I want to remove the seats. After trying to loosen the torx fasteners I do not believe that it will be possible. Does some one like Sears make 1/2" impact torx sockets or is this a specialty item??? Anyone know off the top of their head what T size it is??
2000 X XLT
97Crusher is offline
Old 01-09-2006, 06:03 PM   #2 (permalink)
Re: Need advice removing seats
Sears or any auto parts store will have one. It is a T55. It will be a little loose. A T60 is to big and a T55 is a little small. I do not think there is a T57 or anything in between. The one I have is tapered and I ground the tip down some to make it fit better. I would not use an impact on them myself but maybe a breaker bar if a ratchet won't do it. Good luck.
99.5 F250 4x4
2000 Excursion 4x4
http://community.webshots.com/user/mmsafd
mmsafd is offline
Old 01-09-2006, 10:33 PM   #3 (permalink)
Sounds like a little spray lube from the bottom might be a good idea.
I just pulled a seat from my 05 and it came right out so sounds like you may have a little rust starting on the bolts.
Good luck
Bruce
2005 X PSD Limited Mineral Grey, 4X4 Has Second row bench then Every other factory option available.
Under Construction
4x2 Lift Gate Lifts,
Tekonsha Prodigy
Ford 30MM Rear Bar
Catch All Linners
750 W Inverter
06 Chrome Package Grill,bumpers and hooks. After an encounter with a Honda, (She got the ticket)
2005 Ex and Specs and Pictures of 2002 X
Bruce1954 is offline
Old 01-10-2006, 07:49 AM   #4 (permalink)
My Photos: (12)
Thanks for the advice on the size and the spray info.
2000 X XLT
Old 01-10-2006, 08:02 AM   #5 (permalink)
It is actually a "Torx Plus" 55, not a Torx 55. The Torx+ has rounded points on its star tips, while the torx has pointer star tips. The best price I found for an individual torx plus 55 was through Snap-On, as they were the only company that was willing to sell a single bit instead of a set. While a torx can work, you risk stripping the head because it does not fit well. If you have not already stripped the head, once you get a +, it will come out easily with a long wratchet.
boatpuller is offline
Old 01-10-2006, 09:03 AM   #6 (permalink)
My Photos: (12)
Thanks for the clarification on the 55 plus.
Did a search http://www.mytoolstore.com/sk/sk03096.html
There's a difference between regular torx and plus size.
2000 X XLT
Old 01-10-2006, 08:47 PM   #7 (permalink)
Wow
Learn something every day!
If you don't ya need to get out of bed
Thanks for the Info
Bruce
Under Construction
Tekonsha Prodigy
Ford 30MM Rear Bar
Catch All Linners
750 W Inverter
Old 01-10-2006, 11:32 PM   #8 (permalink)
I always thought it looked a little wrong. I guess someone needed to make some $ again and came up with a new fastener head. What is really bad, the service manager at the dealership did not mention anything about a T55+ just a T55. [img]/ubbthreads/images/graemlins/crazy.gif[/img]
99.5 F250 4x4
2000 Excursion 4x4
mmsafd is offline
Old 01-11-2006, 07:50 AM   #9 (permalink)
Hey, thanks for the link to My Tool Store. That looks like a worthwhile site.
Old 01-11-2006, 11:28 AM   #10 (permalink)
If you need some pictures of soundproofing an excursion, feel free to take a look at my site....
http://www.turrisimotorsports.com/ga...rior_index.htm
Just look under dynamat.
Hope this helps,
Chris Turrisi
05 Excursion Ltd 6.0 - PSD Door Badges, BFG T/A KO 285/75-R16 Tires, C-Bet'r Mirrors, Catch-All Mats, ISSPRO EGT/Boost A-Pillar Mntd Guages, The Diesel Site Coolant Filter, Underhood Insulation & Weather Strips, Factory Mud Flaps, 22" Wipers, Valentine 1, Over Mirror Mntd ISSPRO Oil Temp, Oil Press, Volts, Diff/Tranny Temp Gauges, Custom Carling Switch Panel, KC back-up lights, Super-Springs, Custom 12v Power Outlets, Door Courtesy Lights, Vinyl Tubed Door Seals, Dynamat Extreme Everywhere, LED's in Door Handles, Amber Turn Signal Tail Lamps, PML diff & tranny covers, Fluiddampr, AFE Stage II Intake, LED TMI Tail Lamp & Rear Amber Turn Signal Bulbs, Cab Lights, Rancho Steering Stabilizer, RS9000 Shocks, V-Code Front & S-Code Rear Springs, 4.30 Gears, Edge Attitude, MBRP 4" Exhaust.
cturrisi is offline
» Sponsor Links
»Garage Storage and Cabinets
