Old 05-09-2004, 02:27 AM   #1 (permalink)
JR2
Need pics of gauges installed in your X!
I am the pround new owner of an 03 7.3 X. I need to see some pics of gauges installed in an X so I can decide where to put mine. My pillar has a handle on it so I think I will have to mount them somewhere else as the wife needs the handle to get in. So post some pics or links so I can make a decision.
Thanks,
John
2001 2500 Dodge 4x4 CTD - Modified a bit, 13.66 sec @ 98.03mph
2003 7.3 Excursion EB 4x4 - 10K Mod and a Hellwig Rear Sway bar
59 Lincoln Premier - Sunday crusier
JR2 is offline
Old 05-09-2004, 10:42 AM   #2 (permalink)
Re: Need pics of gauges installed in your X!
Go to the after market forum and there are many pics that you can find. Check out the under cubby gauges that FamilyRide installed and he also has pics.
jward is offline
Old 05-09-2004, 12:47 PM   #3 (permalink)
My Photos: (13)
Welcome to the board JR. Hope you are enjoying the X.
Doug
1999 F-350 CC,4x4,LB Auto,7.3PSD,air bags. ES9000s,leveling kit,Monster Exhaust,trans command,gauges,Six gun,Big Hoss,Brush guard,Front hitch,lights,35-12.5-16.5 BFG All-Terrains.
2002 Volvo XC
1994 Taurus SHO
A bunch of toys!
Snug is offline
Old 05-09-2004, 07:04 PM   #4 (permalink)
FamilyRide's Avatar
Yep, there is a link in my sig. to the uncer cubbies. I really like them. I'd love them even more if I could get the boost gauge to get quiet under heavy boost. [img]/ubbthreads/images/graemlins/laugh.gif[/img]
2004 EB Excursion, 4x4, 6.0, everything but step tubes and 2nd row chairs, Magnaflow Exhaust, Isspro Gauges in an under cubby pod, Fumoto sitting on V Codes and Revo 285's.
FamilyRide is offline
Old 05-09-2004, 08:48 PM   #5 (permalink)
The boost guage is noisy? Is this typical of guages, or should we avoid that brand?
2004 Excursion EB 6.0 Estate Green. As yet, unmodified. Delivered 2004-07-14
Zaphod is offline
Old 05-09-2004, 10:31 PM   #6 (permalink)
FamilyRide's Avatar
Appearentl "some" Isspro boost gauges are, but there is supposed to be a remedy. I found the jet to be loose in the gauge but it's didn't totaly fix it. You're supposed to be able to slit the tube at the gauge end enough that the slit goes a hair past the fitting to fix it, and I'm not sure it did. However, I didn't have a handfulk of compression sleeves to keep trying different things. David at Diesel Manor said ones that have come back he's tested to 30 PSI with a compressor and they were quiet. It's only on the turck when they make some noise. It's not that bad but I know it's there.
I'll still be looking at a way to get it stopped though.....
Old 05-10-2004, 07:59 AM   #7 (permalink)
Thanks,
John
Check my pics,
Paul B
2001 Excursion Limited PSD,2wd,Auto. Toreador Red,10/2000,4.5 Racor,unTAGed,203*,DP-Tuner,AIS Filter,Riley Coolant Filter,6.0 cooler,Cat ELC,Son/Tri,Underdash Lunar Gauges,Hadley Air Horn,On Board Air,Fumoto,2006 31' Flagstaff TT 6.5K,Prodigy
2000 Honda CRV EX
PIC'S
pabrannan is offline
Old 05-13-2004, 03:39 PM   #8 (permalink)
Check out the new Quad Pod on my pics. EGT, Eng. Oil, Tranny oil, & Coolant
[img]/ubbthreads/images/graemlins/smokin.gif[/img]
tginz
2001 PSD Excursion Limited, 3.73LS - White/Beige, minus the roof rack crossmembers, Door Badged, Quad Pod - 4 Autometers (EGT, Eng Oil, Trans Oil, & Coolant Temps. on the A-pillar), Turbo Temp Monitor, Firestone Ride-Rite Rears, Edelbrook IAS Shocks, X-pel Light Protection, Weather-Tech Window Deflectors, Grill Guard, GoRhino Hitch Step, Bob Riley's Coolant Filter System, Magnefine Tranny Filter, Garmin Street Pilot III GPS. Fumoto Drain Valve, Gofia Bug Screen, Custom Built Wheel-less Trailer, XM Radio - Always detailed body, undercarriage, & engine.
SEE MY TRUCK PICS. http://community.webshots.com/user/tginz
tginz is offline
Old 05-17-2004, 02:54 PM   #9 (permalink)
EBX
Tell your wife to use the steering wheel and put the gauges on the piler. You don't have to look away from the road as much to see them. They look factory there. When the Duramax guy drives by you and sees your gauges, he'll be jelous. Check my pics of my gauges.
'03 Eddie Bauer, Excursion 6.0 PSD, 4WD, 3:73 Limited Slip. 6.0 build date March '03, Premier group, video pkg, roof-rack (lighted), 3 pillar pod, Timbrens-on back, Hensley Arrow.
'04 TT Dutchmen 35ES-DSL, laminate sides, 3 slides, w/ Hensley.
'06 28' Enclosed Car Hauler, Dual Cam HP setup.
Check link for pics. & info.
http://community.webshots.com/user/ebx03
EBX is offline
Old 05-20-2004, 06:41 PM   #10 (permalink)
JR2
Thanks for the info guys, I think the pod that mounts below the cubby will be the best place. I am really just putting the gauges in to keep an eye on things. I don't plan on bumping up the power very much. Probably going to start with the "10K" mod and the rear sway bar.
Snug (Doug) - you need to change your sig [img]/ubbthreads/images/graemlins/laugh.gif[/img]
JR2 is offline
» Sponsor Links
»Garage Storage and Cabinets
