Old 03-10-2003, 10:18 PM   #1 (permalink)
New 03 TT SVM, Heated W/Signal??
Does anyone know if they will fit an 01 Excursion with Heated/Signal Mirrors?
I have since changed the regular TT, but would love the Heated/Signal
01 PSD Excursion 4x4 Limited - SCMT - BILLET GRILL - 2" Lift - 32x10.5 M/T MTX - M/T 10.5 Rims - 4" Downpipe and Exhaust - TV/DVD - PlayStation 2 - Kenwood Door Speakers - Kicker 600.1 AMP - Kicker 10' L7 Sub -
87 Mustang LX - 393CUIN Stroker - 351 Sportsman Block - Canfield Fox Lake Stage II Ported Heads - Downs Ford Intake - Vortech MONDO J-Trim SuperCharger - Weldon Fuel System - Ford Motorsport EPEC Computer - Dynamic Mighty Mite C4
94 - Triple Black Conv. - 351 Swap - 700R4 Trans - ATI Procharger 600B - Aeromotive Fuel System - Side Pipes -
01PSDExcursion is offline
Old 03-10-2003, 10:43 PM   #2 (permalink)
Re: New 03 TT SVM, Heated W/Signal??
X's are not available with the TT signal mirrors, only SD, so you might not have the right wiring.
Do a search, that question was asked about 2-3 weeks ago.
jschira is offline
Old 03-10-2003, 10:57 PM   #3 (permalink)
I know it wasn't an option...
But...
The Signal/Heated Mirrors that come on the Excursion, I would think would have the same connectors?
Why change the connectors to the mirror when the TT mirrors is the same as the little one..i.e. they do the same things, just look different.
If you NEVER had Heated/Signal Mirrors than you may not have the wiring.
Old 03-11-2003, 04:29 PM   #4 (permalink)
Since I have just recently crossed this bridge, let me share my findings. My 2001 Excursion came with Power/Heated Trailer Tow mirrors. At the time of purchase, I did have the option to get the smaller (Aero) mirrors with turn signals, but opted for the larger mirrors.
Anyway, since I'm not very fond of the way the TT mirrors look......and I don't tow that often, I ended up buying a pair of the smaller (Aero) mirrors from a member of this forum. They are from his 2003 Excursion and are heated, power as well as have the turn-signal LED's in the glass. I was hoping they would be a plug and play install, but no dice. Different connectors. The earlier trucks (like my 2001)had two connectors for each mirror..that is if you had the heated mirror option. If you didn't have that option, you may only have one connector. On my Ex, there is a round white colored connector for the power mirror functions....and another square black connector for the heated mirror option. The newer mirrors are all coming with one large gray rectangle shaped connector. The good news....Ford sells an adapter harness for just this purpose. The harness has two connectors on one end that will plug into your truck...and one larger gray connector on the other that goes to the mirror.
Part numbers as follows;
Driver's Side 1C3Z-14A411-AA $10.95 (list price)
Pass. Side 1C3Z-14A411-BA $9.97 (list price)
For what it's worth, I did not have to run any additional wires in my '01 Excursion for the turn signal function. they were already there. [img]/ubbthreads/images/graemlins/smile.gif[/img]
Toolman1
<font color="421193">**FOR SALE** -&gt; 2001 4x4 Excursion-LTD.,7.3L PSD, Chestnut, 3.73L/S, AIC, Michelin LTX M/S "E", Tekonsha Prodigy, Triple A-pillar w/VDO Gauges, Hypertech PPIII, U-Code Springs, Bilstein Shocks, Rancho Stabilizer, Rear Hellwig Anti-Sway Bar, ART Brake Rotors & Pads, EPI Exhaust Flex Pipe, Husky Floor Liners and Molded Mud Flaps, WeatherTech Vent Guards, 24" Wipers, Fuel filler neck mod. Fog light switch mod., Rear Aux Lights, Dual Alt. Upper Radiator Hose, Disabled key-in chime.</font>
Toolman1 is offline
Old 03-11-2003, 10:03 PM   #5 (permalink)
Great information, thanks alot.
What is the difference between driver/passenger Y adapters?
and which vehicle wiring connector has the turn signal wiring in it, round white or square black?
2000 Excursion Limited born 11/99 4x4 Toreador Red ext./gray int. 7.3PSD, 3.73LS, Skidplates, Pwr/Htd TeleMirrors, 6CDchanger, HtdBuckets, LT265/75R16E Bridgestone Dueler A/T Revo, Ford Wraparound deflector, PSDV8 badging, RoofMarkerLights, Tekonsha Sentinel brake cntrlr, PCM=AXD0, Edge Evolution II, WalkerBigTruck Muffler, RS9000, RS5410, Performance Friction 2 piece rotors/pads, Sylvania SilverStars, Landyot Gen III, Air Lift rear air bag system, Amsoil from MAXoil.com in diffs/trans/transfer 251k miles.
ExcursionPSD is offline
Old 03-11-2003, 11:50 PM   #6 (permalink)
Toolman1,
Do you still have your TT mirrors??? I am looking for a pair for my wifes 01 X. I can not see anything when towing the RV with the small mirrors. Shoot me a PM or email llcustom@netmdc.com
[color:"BLUE"]2005 F350 DRW Crew Cab, 6 Speed, Manual Transfer case, 4x4, FX4,
Lariat Luxury Package, Upfitter Switches, IBC, Line X, B&W Hitch W/ Companion
llcustom is offline
Old 03-12-2003, 08:23 AM   #7 (permalink)
There really isn't any difference between the DS and PS adapter, except for the wiring colors. Maybe the price difference has something to do with how many of each item are sold. I don't know??
The turn signal wires are in the round white plug on my Excursion. It's a White w/Blue tracer wire on the pass side..and a Light Green w/White tracer wire on the driver's side.
I don't think I am going to sell my TT mirrors. I do tow, but not that often. My plan is to swap them out when I take road trips that involve towing. And that's the whole reason I bought the adapters from Ford....so I wouldn't have to cut any wires and my old mirrors could be easily reinstalled.
Toolman1
Toolman1 is offline
Old 03-12-2003, 08:43 AM   #8 (permalink)
Toolman1,
Sound like a plan,
Just thought I would ask!!!! [img]/ubbthreads/images/graemlins/grin.gif[/img] It never hurts, well sometimes ! [img]/ubbthreads/images/graemlins/eek.gif[/img]
llcustom is offline
Old 03-14-2003, 07:43 PM   #9 (permalink)
Whoooaa. Stop the presses. I just got my adapters from Ford and although they will fit just fine, they do not include the wire for the turn signal. Went 'round and 'round with the part guys and he could not find another adapter that would work. So what I am doing is buying one extra adapter, and just using a couple of wires from it, to fill in the missing wire. If interested, here are pictures of the harness that I got from ford.
Drivers Side Harness
Passenger Side Harness
If interested, I'll post some more pictures when I get the mising wires added. I could have just done the job with a couple of crimp on connectors, but I don't want to cut anything, and I want to be able to swap these mirrors back and forth without any trouble. Beside, the extra $8.50(with my 15% off) isn't going to kill me. I hope I didn't steer anybody wrong with those part numbers. They will work, but if your mirros have the turn signal element, you will have to add one wire to each harness.
Toolman1
Toolman1 is offline
Old 03-19-2003, 09:07 PM   #10 (permalink)
Please do Post your results and pics.
I am very interested in doing this MOD.
Old 03-19-2003, 11:21 PM   #11 (permalink)
Toolman1,
That is the same harness I bought when I converted the TT mirrors on my 99 to TTT heated mirrors from an Excursion.
RichS
NRA Life Member
"Personal responsibility is the price of Freedom." -- Michael Cloud
RichS is offline
Old 03-20-2003, 08:08 AM   #12 (permalink)
Sorry, but I already did the job and installed them last night before you posted your inquiry for more pics. Wish I could turn back time.....because I put three nice scratches/gouges in my passenger side door while doing it. YIKES!! I was in too much of a hurry and my mirror fell out which allowed the threaded studs to scratch my paint down to bare metal!
Anyway the harness mod was really easy. Like I said before, I just bought a third adapter harness(got the cheaper one), then just disassembled this extra harness so I could use two of its wires to add a missing turn signal wire to the driver side and pass side harnesses. The missing wire goes in the middle opening of the gray connector and in the only open slot on the sqaure white connector.
Disassembly of the harness consists of removing the red locking plug(s) inside of each connector(push them out from the backside (wire side) of the connector using a precision screw driver). Then hold the little pin keeper tabs back (inside the pin end of the connector) with a precision screwdriver, while removing the individual wire(s). Insert missing wire into each harness, and reinsert the red plug(s) to lock them in place. Piece of cake. Works great. Just wish I didn't scrath my door. Now I have yet another project....to fix my paint!
Toolman1
Toolman1 is offline
Old 03-20-2003, 08:32 AM   #13 (permalink)
bill4d's Avatar
My Photos: (15)
I have some pics of mine installed and painted. Check my pics below. I have not wired the heating and turn signals yet though. Just waiting on some switches.
• 2002 • F-350 • 7.3L PSD • CC • SWB • Dark Shadow Gray •
Gray Goose
last update - 9|25|05
"World's most quiet interior" - compared to 7.3L PSD
'Ultimate' headlights . . . coming soon
bill4d is offline
Old 03-24-2003, 09:47 PM   #14 (permalink)
Very good instructions and nice clean work-around the missing turnsignal pins.
On my 2000, expect I will have to bring turn signal wires into the door from under the dash.
The pictures show different suffixes on the bag for the Y adapters than what you have in your earlier posting:
1C3Z-14A411-BA left hand (driver side)
1C3Z-14A411-AA right hand (passenger side)
[img]/ubbthreads/images/graemlins/frown.gif[/img] Sorry to hear about the paint scratch.
Old 03-26-2003, 08:49 AM   #15 (permalink)
Yeah, you're right, I just had the driver's side and passenger side numbers mixed up. Doesn't really matter though, since either one will work on either side. If I was going to do this project again, I'd order three of the cheaper ones. Only difference, besides price, is the wire colors..so no biggie.
Decided to fix the scrathes myself and the touch-up paint on it's way from Ford at this moment. I'm hoping to take my time and layer the touch up paint to build up the scratched/gouged areas. Got 'em waxed up real good right now so they don't start to rust before I can begin the painting.
Cheers,
Toolman1
Toolman1 is offline
