Re: new Excursion wheels/tires
I had on my Ex (2WD - no lift) some nitto nt404's, 315/60/18 on 18x10's (stock offset - 6.25" backspace) Boyd poseidons. The nittos were 32.6" tall, and 13" wide at the sidewall mounted. Almost as big as the Terra Grappler 325/60/18 (They have a flatter, blockier tread section)
Fit with no issues, so the Terra grapplers on a 18x8 to 18x10 would be great. Just keep the offset close, lots of the welds and others have a 10-15mmm offset (stock is 25mm), that's what you want, around 5.5" of backspace.
2002 PSD Excursion 2WD, VDO guages, PPIII, pre-pump and tank mods, ZooDad, 4" exhaustw/ Magnaflow muffler and downpipe, Bilsteins, Hellwig bar, Air Lift rear bags, monochrome SD grille and bumpers, 20" Weld Velociti 8's
