New Flash and It's All Good So Far
Had my truck in this week for a couple of minor items one was some miss-shifts from 3rd to 4th at 2000RPM, light acceleration. It would fo it just once in a while. it wouldds shift out of 3rd then overspeed slightly prior to going into 4th.
They reflashed both Diesel fuel what ever mondule and the PCM I did not know they were three in the truck I though it was just the two.
PCM reflash seemed to fix the trans problem just fine.
The reflash of the engine fuel module seemed to help the MPGs also.
I had a Blackstone report done for my last oil change and it showed 4% fuel in the oil, I told the dealer and they said the new flash was also to help with some over fueling at idle.
If anything it sounds a little more diesel like at idle.
Not sure if this is for 04s also but I am glad I had it done.
Bruce
2005 X PSD Limited Mineral Grey, 4X4 Has Second row bench then Every other factory option available.
Under Construction
4x2 Lift Gate Lifts,
Tekonsha Prodigy
Ford 30MM Rear Bar
Catch All Linners
750 W Inverter
06 Chrome Package Grill,bumpers and hooks. After an encounter with a Honda, (She got the ticket)
2005 Ex and Specs and Pictures of 2002 X
