New goodies- my take...oh and what David Lott said about my Ex
Today and yesterday I added /changed 3 items on my Ex. Thought ya'll might like my take on them in case you're considering the same things.
1. New tires - Nitto Terra Grapplers 295-75-r16
Love them! I had BFG T/A KO's in the same size before. The Nittos are a little louder over 55, but not much at all. The Nittos seem more stable, IOW I can take corners faster with less perceived body roll. They balanced great and are smoooth. For the $200+ I saved over the BFGs, I'd go with the Nittos 10 out of 10 times.
2. High Pressure Crossover hose
Truck starts quicker/easier. It definately runs smoother at about 1500 rpms (45-55mph) and 2000rpms and above (70mph). It seems to be a teeny tiny bit quieter and smoother at idle. But its a small enough difference that I almost wonder if its just my imagination. Too early to tell if mileage went up at all. Bad thing is, there seems to be a vibration in the 1600-1900 rpm range. I'm sure its the engine. I can feel it in the pedal and hear it. Its very slight, but its definately there. Would I do it again? ahh...I could take it or leave it honestly.
3. Sonnax Tricumulator
WHY DID I WAIT SO LONG!? Man what a difference this thing makes!! Shifts are now quick but smooth. I was worried that they would be harsh, like putting in a shift kit in my old chevy. Nothing of the sort. They're just perfect. No more hanging between gears. It just SHIFTS plain and simple. Highly recommend!
OK, so I had my Ex at Diesel Innovation today for these and other things. First off, let me say THANKS to them. What a class act that company is. They go all out to make you happy and make sure you'll come back. And they're a fun bunch of guys to hang out with too. Well David Lott drove my Ex back from the garage to the store. When he got back he said, and I quote "What kind of program do you have in that truck? That thing runs GOOD." [img]/ubbthreads/images/graemlins/grin.gif[/img] [img]/ubbthreads/images/graemlins/biggrin.gif[/img] Coming from him, that felt great to hear! Now I'm ready to go out and pick a race! [img]/ubbthreads/images/graemlins/smokin.gif[/img]
Re: New goodies- my take...oh and what David Lott said about my Ex
A what -
I hate my shifting, if I wanted my father's Oldsmobile...
__________________ 2004 EB X 6.0 2WD, everything except 2nd row caps and 4WD, 6" Pro Comp, Hellwig rear sway bar, 285-65/20 BFG KO, Air Raid intake in factory box, MBRP cat back 4", 30% tint, color match splash guards, Prodigy, Sirius
Yep, I'm running stock rims. They fit and look great. No bulge at the top. And they should fit fine on yours with the modified springs.
Good to hear. I definately need some bigger meats to fill up the fenderwells now that the new springs are on. I also like the thought of dropping a few rpms at cruising speed on the highway too. My first choice would have been a 275/85-16 however, you can't find them like you could back 15 years ago.
Semper,
Ty
2004 4X4 Excursion XLT 6.0L Black, intake elbow, straight pipe, modified W and B code springs
1945 Ford GPW
1973 Jeep CJ5 350, NP435/TeraLow geared Dana 20 and lockers
1988 Dodge Ramcharger 360, NP435/241, D60s, 37s
1963 Dodge M43 Ambulance
7.3L IDI project engine
I had the Toyo Open Country A/T in a 295/75/16, which is basically the same tire since Toyo make the Nitto. The tires had good traction & were pretty smooth but wore out very fast, I only got about 25,000 miles out of them & I rotated them every 5,000 miles, I Would not buy another set.
I was worried about that. I figure that's where the $200+ I didn't spend went to. But considering that I only put 10k miles on mine last year, I don't think it will an issue for me. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Looking to find a race I may be game. David has always been goog to me.
01 Excursion 4X4 - DIY Injectors, Garrett GT38R, DI Regulated Fuel Return, HX CrossOver, AFE stage II, Diamo 17 Karat 18x10.5 w/ 325x60x18, 4" straight pipe exhaust, DI 6 position chip, X and F Springs with F350 Rear Blocks and .....................
01 Excursion 4X4 - RIP 2/22/2008
All work has been done by Diesel Innovations!!!!! Thanks to MR POWERSRTOKE RACER for all the help.
Got 80K miles out of a set of BFG 295/75/16's, they were on the F250 mostly but spent about 10K miles under the Excursion which was a perfect fitment (with 16x8 rims). Second set two blow outs prior to 40K miles and the other two have 70K miles on them.
First set was $850 second set was $820.
99(4/99)F350 PSD 4X4 crew cab long bed dually lariat isspro triple pod air bags with compressor
99(6/99)F250 PSD 4X4 X-cab short bed xlt 5in str8 piped air bags autometer ultra light triple pod junk yard pcm running 22 psi 250k miles bought 8/15/01 w/40k miles first diesel
00(12/99)Excursion PSD 4X4 limited
65 Mustang 289 V8 4brl 69 GTO 400 4spd 99 Neon R/T
04 and 09 PJ 15k dump trailer 04 H&H 9K tilt bed 98 Haulmark 7x14 enclosed
Let's do it big boy![img]/ubbthreads/images/graemlins/cool.gif[/img] I'm sure we can find a nice track in Tomball where we can take multiple passes. We're set up pretty close to the same. I'd like to run against you with your chip in each of the settings. Maybe that will give me an idea what is in mine!
Name the place I am game. I need to see what it can do.
