I am looking to replace shocks on my excursion. I tow 9000# travel trailer several times a year. Anyone have recommendations? Any recommended dealers here have them?
Wow you sure know how to start a good friendly fight!
I will not even say what I think however you may look at my bio for what works for me.
Bruce
2005 X PSD Limited Mineral Grey, 4X4 Has Second row bench then Every other factory option available. Under Construction
4x2 Lift Gate Lifts,
Tekonsha Prodigy
Ford 30MM Rear Bar
Catch All Linners
750 W Inverter
06 Chrome Package Grill,bumpers and hooks. After an encounter with a Honda, (She got the ticket) 2005 Ex and Specs and Pictures of 2002 X
I would go with the Rancho RS9000X if you are towing heavy. You can adjust them for what type of ride you want. This Place has the beat deal I have seen but you have to order them by 04/30/05 to get the buy 3 get 4 deal. I had these on my Ford Van and just installed them on the Excursion. The ride difference is unbelievable. I will see how the do when towing this weekend.
[img]/ubbthreads/images/graemlins/smokin.gif[/img]
FMT
__________________ Excursion Pics
2000 Excursion Limited 4x4 Dark Satin Green Arizona Beige 7.3 DIT, AXDO, 3.73 LS, DP Tuner F5, TERMINATOR II w R-IPR, Adjustable Boost Regulator, Turbomaster, EBPV Delete, Air Dog, ITP Regulated Fuel Return, Fuel Cooler, Tags 1&2, Harpooned Tank, Magnaflow XL Exhaust w Aeroturbine 4040L, Sonnax/Tricumulator, 8 Autometer Sport Comp 4 Gauge A Pillar 4 Gauge Overhead, Ford APCM, Crimestopper Remote Starter With Remote Fast Idle, Ford AIS w Zoodad, W Code Front Modified B Code Rear springs, Rancho RS9000X, Rancho 5406 Stabilizer, Hellwig Rear Sway Bar, BFG Rugged Trail TA, V10 Trans Cooler w Dual Electric Pusher Fans, Coolant Filter, IAH Delete, (((XM))) Line Of Fire Light, Ford Cab Lights, 05 Headlights w GOS Conversion Harness, Jimmi Jammers, 03 Lighted Painted Tow Mirrors w C-BETR, PSD Badges, Pullrite Hitch, Prodigy Brake Controller, Born 01/29/00
Rancho RSX 9000's. Had them on my '00, and just installed them on my '05. Bilstien's are also very good, but I like the adjustability of the Rancho's. Allows for tons of flexibility when towing or if you really load down the truck on trips. It takes a while to tinker with the 9 settings to find one you like, but once you're there, its smooth sailin'.
