Old 05-05-2004, 07:19 AM   #1 (permalink)
New tires for my X
I will be replacing my recalled tires shortly and would like your advice. I mostly drive on the highway and tow a #7000 camper about 20% of the time. I do not want my fuel mileage to drop so I will stay away for a more aggressive tire tread. My X is stock with a new AIS air intake.
1fast65 is offline
Old 05-05-2004, 08:11 AM   #2 (permalink)
Re: New tires for my X
4x4 or 4x2?
Michael
2001 Excursion PSD Limited 4x4, SCMT Max Tuner, Diesel Innovations 4" exhaust, 3 pod A-pillar w/ VDO Vision boost, pyro & Trans, AIC, Baldwin bypass filter, ATS Ported Compressor housing...See my mod pictures HERE!
1995 Camaro Z28 K&N FIPK, Throttle body Airfoil, Jet-Hot MAC Headers, Borla SS 3 exhaust /w bypass, 3.5" Aluminum driveshaft, 4:10 Gears, B&M Ripper shifter, Accel 300+ ignition, Accel SpiralCore wires, Shift light, 100hp Nitrous [img]/ubbthreads/images/graemlins/crazy.gif[/img] <font color="red"> FOR SALE! </font>
2002 32' Keystone Bobcat 294BHS travel trailer
PSDExcursion is offline
Old 05-05-2004, 09:25 AM   #3 (permalink)
Michelins LTX M/S are good tires. Not an aggressive tread pattern. I would highly recommend them . I have had them on other trucks and will again when my stock BF Goodrich wear out on the X.
jward is offline
Old 05-05-2004, 10:49 AM   #4 (permalink)
I love my Michelin LTX M/S tires. I have used them on many vehicles. A good all around tire with great long life tread wearing habits.
Hope this helps,
John
2000 Excursion Limited PSD 4X4 Dark Satin Green/Medium Parchmant Born 7/00 In-Service 10/00 All Factory Options except Transfer Skid Plate
JADFPE is offline
Old 05-05-2004, 12:27 PM   #5 (permalink)
My X is a 4X4 with the 7.3 diesel; I currently get 18 to 20 highway and 11 to 13 towing.
1fast65 is offline
Old 05-06-2004, 12:39 AM   #6 (permalink)
I've had GY 305's on 8" rims from day one and love them. Absolutely no problems
scott.
01 Black Excursion XLT PSD 4x4, loaded, 3.73LS, 305/70R16 Goodyears, Husky mats, Manik tube steps, J & J grill, K&N, Clifford Alarm, 4" exhaust-turbo back, 5" Magnaflow SS tip, Dynomax Race Magnum sound suppressor, Clear corner lens, back door storage bins."Scotpart 4X2 liftgate strut mod", 2002 headlights, Hellwig sway bar, Monroe Shocks, American Racing Wheels, Driver's A-post handle, Go Rhino 3000 front push bar and rear step.
scotpart is offline
Old 05-06-2004, 08:46 PM   #7 (permalink)
FJF
FJF's Avatar
Does the 305's rub anywhere. I had them on my 93 F350 and had to move the bumper out a little. [img]/ubbthreads/images/graemlins/cool.gif[/img]
2000 Excursion Limited 4X4, 5" Hypermax Exhaust,TS 4 Bank chip(D/P Tuner- stock,Tow,Econo,Race) A Pillar DiPricol Gauges (white face)Hellwig swaybar,Skyjacker stablizer,AFe Stage2, Slotted&cross drilled rotors,BB Turbo,Pioneer AVIC D2 <font color="RED"> *** ALL GAVE SOME, SOME GAVE ALL(FDNY 9/11/01)***
FJF is offline
Old 05-07-2004, 10:44 AM   #8 (permalink)
Location: Imperial, MO - 20 miles south of St. Louis, MO
My 305's do not rub at all!
2000 X ltd.,white/parchment 4X4 loaded,285/75/16 BFG's,dvd,converted 06 oem grill,Xtint,New style clear headlights & clear corners w/ Plasma white bulbs,Fumoto,cut front bumps,Bilstein's,ass'd X badges & ass'd door PSD badges,ISSPRO EV gauges,clear cab lights, Wet Okole front seat covers, Weathertech visors,Pro-Comp steer stab.,Tymar Perf.intake, AIH removal mod w/boost tap,muffler delete turbo back Magnaflow 4" SS exhaust,WW,ATS Housing,Turbomaster controller,CCV Bypass,Edge Evolution Programmer(Extreme every day tow heavy in 80HP Mode),Power Slot rotors all around w/Hawk LTS pads,Duralast Gold Batteries, etc.); BTS tranny & new programming if oem ever dies.
In betweeen boats so now I have a custom 2003 HD Heritage Softtail I Love! Will return to boating when sons get older at 2mm LOTO, MO! Ride with friends now...Harley much cheaper on fuel!
http://community.webshots.com/user/jweiler27
Work hard, play hard; strive to be the best at whatever you are doing!
Jeff27 is offline
Old 05-09-2004, 12:52 AM   #9 (permalink)
Hand down, no question. Bridgestone Dueller A/T Revos. 285/75r16.
2002 4x4 7.3PSD Excursion, U-Codes, '03 Jounce Bumpers, Hellwig Sway Bar, Rancho 9000 shocks, Rancho Steering Stabilizer, Air-Lift rear air bags, Factory DVD, Driver side A-Pillar grab handle added, Rain-X wipersfront-24", rear-17"), riding on 285/75/R16 Bridgestone Revos.
IMartin is offline
Old 05-09-2004, 07:27 AM   #10 (permalink)
I normally do not make tire recommendations, because it just starts a big fight, but I will make an exception.
Consumer Reports periodically tests tires. I have bought 5 or 6 of its recommended tires and have never been disappointed.
Michelin LTX's are good tires.
Pros - Smooth, quiet ride. Long tread life.
Cons - Wet traction could be better, dry braking a little weak. $Mucho dinero$.
Bridgestone Dueler A/T (not Revos) are good tires. I bought 2 sets of them.
Pros - Excellent wet/dry traction, braking and cornering.
Cons - A little noisy.
Personally, I bought Dayton Timberline A/T's based on CR's recommendations. I have not been disappointed. I have driven in rain and snow (yes, we get that in Texas). Excellent grip.
Pros - Excellent wet/dry traction, braking and cornering. Not noisy (don't let the open tread fool you). Very inexpensive ~$425 out the door.
Cons - Hard to find. Only "D" rated.
CR has never been very impressed with anything with the "Firestone" name on it.
Goodyear Wrangers have never tested well. I also had a set on my Jeep. Crappy tires.
Toyo Open Country tested well.
Yokohama Geolanders tested well. A friend bought a set (replaced some Wrangers) and said that there was a night and day difference.
I had a set of Generals. I replaced them with the Duelers after I slid on a rain-soaked freeway and hit a bus (and a guardrail) at 60 mph (I was OK, not a bruise or a scratch). After the tire switch, never slid again. If I ever buy a car/truck with OEM Generals on it, I'll be buying new tires the next week for sure.
I have generally been impressed with the better quality Bridgestone tires. So has CR. I would have put Duelers on my X except the Daytons tested out just as good, had a less noisy tread and were about $200 cheaper.
If you want smooth and quiet above all else, go with the Michelins.
If you want to get an excellent tire and save yourself some money, go with the Daytons. 2/3 the price of Bridgestones, 1/2 the price of Michelins.
jschira is offline
Old 05-10-2004, 10:32 PM   #11 (permalink)
ANYONE try bridgestones yet
2003 Excursion 40,000 no troubles Amsoil everywhere, and 3 kids. You lightum we fightum !!!
http://members.cox.net/oil
ajrcj is offline
Old 05-10-2004, 10:44 PM   #12 (permalink)
FamilyRide's Avatar
Only about 50% of the trucks on the board. [img]/ubbthreads/images/graemlins/laugh.gif[/img]
2004 EB Excursion, 4x4, 6.0, everything but step tubes and 2nd row chairs, Magnaflow Exhaust, Isspro Gauges in an under cubby pod, Fumoto sitting on V Codes and Revo 285's.
FamilyRide is offline
Old 05-10-2004, 11:13 PM   #13 (permalink)
figured there good also ty
ajrcj is offline
Old 05-11-2004, 10:14 AM   #14 (permalink)
FamilyRide's Avatar
Yep, I really like them. They are a little noisier than the OEM tires but they are solid in every condition I've had them in.
They don't sound bad bawling through 1st and 2nd gear either, although I don't plan on doing that often at all, I had to try it with the new tuner! [img]/ubbthreads/images/graemlins/wink.gif[/img]
» Sponsor Links
»Garage Storage and Cabinets
