New toy; delayed-power-off radio feature - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Power Stroke Excursions
Old 09-08-2001, 04:52 PM   #1 (permalink)
turbodave's Avatar
Along with the latest feature (speed controlled volume) on the radio, there's another new toy that you can add.
If you've ever had a chance to test drive an up scale SUV like the GMC Yukon Denali, or the Lincoln Navigator their radios have a neat feature that allows the radio to stay on even after turning the ign key off and removing it!! (nice for when the wife goes into get groceries and you just want to set around listening to tunes without having to keep the key on or acc).
Very basically, what you do is provide a new signal to the accesory wire feeding the radio. Normally that wire is only hot with the key in acc position.
The signal you tap into is the same one that allows you to raise and lower your power windows even after the key is turned off!! Neat huh!!
Not to worry, your radio isn't going to stay on forever! This feature is only available for the same length of time the windows relay stays active.
AND, opening any door disables this feature, so if you turn the key off and open a door right away to get out the radio will power down. Staying in the truck after the wife gets out? Just turn the key back on when she's out and the doors are closed, and then turn the key right back off. You have a working radio, and power windows!!
How cool is that!!!!!!??????????
More info and links to pictures are available if you go to the "upgrades" forum in the speed controlled volume thread. You'll find good info and links about this near the end of the thread. Check it out.
I now have both mods working, speed controlled volume, and delayed-power-off.
Too cool. Where was Ford when these needed to be completed and added to (what I consider to be a high end SUV) the Excursion?
TurboDave, EWCS(SW)USN Ret
H&N Turbo 6 Racing
Seviervile TN
A MAN AND HIS TRUCK, IT'S A BEATUFUL THING
01 Excursion LTD (EBM3) 7.3L, PSD, Turbo, 4X2, TTS Race Magnum chip (original owner)
86 GN (original owner)
87 GN (second owner)
08 Honda Accord EX-L
My Photo Gallery
turbodave is offline
Old 09-09-2001, 05:16 PM   #2 (permalink)
Re: New toy; delayed-power-off radio feature
I could be missing something here, but why do this when you can just turn the ignition the "wrong way", that way you get the radio+power without the engine?
2000 4x4 Excursion-Limited, 6.8L V10, Red(mostly Mud-brown), Modified Koni Shocks, Htd Seats, Superchip, 10.4 Monitor+DVD/PS2, Fog light switch mod, Rear sway bar, Warn lightbar+4 Hella3000 extra lights, W-code springs, 24" Wipers
rogera is offline
Old 09-10-2001, 11:14 AM   #3 (permalink)
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by rogera:
I could be missing something here, but why do this when you can just turn the ignition the "wrong way", that way you get the radio+power without the engine?<HR></BLOCKQUOTE>
The same reason people climb mountains, "Because it is there." [img]images/icons/smile.gif[/img]
2001 Black Excursion, 4x4, XLT, PSD, LS, (EBM2), Super-Duty grill, 4" MBRP exhaust, Bilsteins, X-springs, OilGuard bypass filter, 295's, Badges, Suvlights harness, APC headlights, Weatherboots, Centramatics, Clear corners, AIC w/ITP mount, ISSPRO EVs, BTS trans, Open element intake, ATS compressor housing, Thule rack, BD Torqloc, F350 rear blocks, Randy Ellis lightbar with a couple of Lightforce 170s, Front receiver hitch, DP Tuner chip
1975 Ford Bronco, neglected since I bought the Excursion
AJ'sDad is offline
Old 09-10-2001, 04:15 PM   #4 (permalink)
turbodave's Avatar
I'll answer your question with a question. Why then would all upscale luxury cars and SUV's have this feature? And to take it a step further, why would the majority of SUV's and cars have the same feature available for the window?? Your does.
I consider my truck to be upscale and everybit as good as a Navigator or Denali, don't you? Why shouldn't we enjoy the same creature comforts?
H&N Turbo 6 Racing
Seviervile TN
My Photo Gallery
