Old 09-28-2005, 05:47 PM   #1 (permalink)
Is this normal, or is it time for a lift kit?
My front end rides like crap, hits the bumpstops constantly. So I took a look and a picture. Is this normal distance from the bumpstop?
I am thinking of doing an X code spring swap in the front. and a shackle flip in the rear to get some lift.
Here are the pics. Mind you this is just parked in the driveway.
Drivers Side
Passenger Side
k5chevyblazer is offline
Old 09-28-2005, 05:59 PM   #2 (permalink)
Re: Is this normal, or is it time for a lift kit?
Totally normal for a stock X!
Time to upgrade...
2002 Limited Ultimate Premier No Boundries Excursion 7.3l 4X4 all black with every option Ford could come up with. X-code F550 front springs, full size leaf added in the rear, 265 Bridgestone Dueler Revos, Edge Juice with Attitude, Edge Evolution, Autometer sport comp guages, IDM mod, Walker BTM muffler, SPDiesel exhaust brake with t/c lock up control, Catch-All floor mats.
edunn69 is offline
Old 09-28-2005, 06:32 PM   #3 (permalink)
Drivers Side
Passenger Side
OK Bruce the front spring guy here
Ok from the photo you have about .75 or a bit more ave.
You have a mid 02 or earlier X so change those front stops to the 03 stops now they are 13 to $15 each if you get any discount at all. they are a bit shorter and softer
Also I and guessing there is from 45 to 60 K on the truck based on the sag I see.
See my charts and posts by me and others on this subject.
For normal "WHAT IT SHOULD HAVE BEEN FROM THE FACOTRY" U and V codes are used
From where you are now Us will gain you about 1.5 and Vs about 1.75 adding back the .25 or more you are saged from the chart heights.
Change to the shorter stops and you will be back close to a reasonaable 2.25 to 2.5 travel range you can live with.
Of course these are just my thoughts and opinions
Bruce
2005 X PSD Limited Mineral Grey, 4X4 Has Second row bench then Every other factory option available.
Under Construction
4x2 Lift Gate Lifts,
Tekonsha Prodigy
Ford 30MM Rear Bar
Catch All Linners
750 W Inverter
06 Chrome Package Grill,bumpers and hooks. After an encounter with a Honda, (She got the ticket)
2005 Ex and Specs and Pictures of 2002 X
Bruce1954 is offline
Old 09-28-2005, 08:47 PM   #4 (permalink)
MotionMan's Avatar
It is always time for a lift. I used the V codes and a 1.5 add a leaf for the same 3" the X code gives. No sag in 60K. Just get a 4" block for the rear, make sure it is tappered, and you are done. I didn't replace the shocks for a long time, I did replace the U bolts too.
Some people are like Slinkys. They are good for nothing but still put a smile on your face when you push them down a flight of stairs. 2003 X Limited Ultimate, Mineral Grey Metalic. DVD, Limited Slip, Badged, Cab Lights, Magnaflow, Thule Rack, 3" Lift, T Prodigy, Air Bags, Edge Programer, XM Radio, Extreme sound system. 315/70/17s on AR Chrome/Aluminium.http://community.webshots.com/user/stellinm
MotionMan is offline
Old 09-29-2005, 12:13 AM   #5 (permalink)
That is normal.When i bought our exc. i took a trip from mn to conn. and going through chicago was rough bad highways but i was not happy with the ride started looking around for answers,come to find out that the tires were a 10ply tire which is like a concrete tire super hard for towing i went to a 20" rim and 8ply tire and MAN! night and day drove way smoother and handled nice.So maybe check to see if the tires are 10 ply and maybe go to an 8ply you will have a good enough tow rating w/those,i hope that helps. [img]/ubbthreads/images/graemlins/grin.gif[/img]
01 Ford Excursion 7.3diesel color matched with lime time green flames,22" chome rims,tinted windows,remote starter,bully dog tuner,4" exhaust turbo back,AFE stage II filter, HX mod,203t,AIH mod,big hd accuator,Banks compressor wheel,DI fuel gauge,DI fuel reg shim kit,stereo sytem with 4 monitors,ebpv mod
1HiLimo is offline
Old 09-29-2005, 01:07 AM   #6 (permalink)
FamilyRide's Avatar
Yep, my '04 has about 1/2" on the drivers side and about 3/4" on the passenger side. Difference is the '04 (maybe '03 too) has the soft cellular material bump stops that are made to be "ridden" on basicly. Makes the slam easier to take. LOL [img]/ubbthreads/images/graemlins/laugh.gif[/img]
2004 EB Excursion, 4x4, 6.0, everything but step tubes and 2nd row chairs, Magnaflow Exhaust, Isspro Gauges in an under cubby pod, Fumoto sitting on V Codes and Revo 285's.
FamilyRide is offline
Old 09-30-2005, 03:17 PM   #7 (permalink)
Hey Bruce, I have a question for you, how much lift would an 05 with no sag get from a pair of U codes with say 20k miles on them? They were under my V-10 F-250 for about a year and a half.
Thanks,
AUG
BTW sorry for the Highjacking.
2005 Excursion 6.0 4X4 EB 4" MBRP Turbo back 5" tip, Zoodad, Steveracer, Midland 79-290 CB, Wilson 5000, outlook monitor, DR 3" lift W/ Bilstien Shocks, U and Mod B codes, Billet Badges, 05 Powerstroke Badges, Weld Cheyennes 18x10, Mickey Thomspon 325/60-18's, DynaMated interior, Strobes, Train horns, 30mm rear and hellwig front sway bar, HIDs in Headlights, Fogs and backups, AIRAID Intake system, Randy Ellis light bar, 4 KC's, oilgaurd, FASS, LED markers, Bean's 190cc Injectors, Bean's Turbo, ARP Headstuds, Banks IC, Custom Fuel System, SCT by Kermit, More to come...
14.109 @ 95.96mph best 1/4 for now, Oh ya @ 8520lbs
AUGSX is offline
Old 09-30-2005, 04:16 PM   #8 (permalink)
Thanks,
AUG
I don't see a problem it is all about front springs!
There are some rumers that ford "revised" the front springs in 04 and 05 but is not talking, all codes are the same.
I have not replaced them on my 05 yet when I do I will put them side by side with the Ds from my 02 and will know for sure. If they did change them I am guessng they changed the arch just a bit.
To answer your question I would be surprised at anythng less than an inch and sould be no more that an 1 3/8".
Funny you should ask I have intended to pull my X into the shop so that I know it is level and measure it to see if I was going to get Us or Vs or??.
Just did it and It will get a V on the left and a U on the right the left is already sitting 5/16 of an inch lower than the right WITHOUT my fat but in it even with the "box o stuff" I keep in the right rear.
It should level it up almost even until I sit in it that is [img]/ubbthreads/images/graemlins/phoney.gif[/img]
Looks like Ford may be getting ready to do different springs (Left vs Right) up front in 07 since the new coil type in 05 have dual codes up front but they are they are always the same as far as I know.
Bruce
Under Construction
Tekonsha Prodigy
Ford 30MM Rear Bar
Catch All Linners
750 W Inverter
» Sponsor Links
»Garage Storage and Cabinets
