I have an 05 X Limited with 15,000 miles. The OEM tires are BF Goodrich LT265-16-E RWL. They were just replaced under warranty because of cracks around the circumference on all 4 tires. These were not weather checking but actual cracks running the full circumference of all 4 tires about 1 inch from the rim. The spare did not have this problem and the vehicle is stored under a carport so they were not exposed to the sun. And I check the pressure on a regular basis. Manufacture date of the tires was early 05. I have not read anything about this problem so I don't know if its widespread or not. They replaced the tires with the same tire so I don't have the warm fuzzies about them. If they had not been replaced under warranty I would have replaced them myself. The Service Advisor said that Ford approved the replacement very quickly. I guess Ford is a little leary of tire problems after Firestone.
Has anyone else had this problem with these tires?
I dumped the OEM tires at 85 miles on the odo. Just got my 2nd set of Revo's and haven't looked back. [img]/ubbthreads/images/graemlins/laugh.gif[/img]
__________________ 2004 EB Excursion, 4x4, 6.0, Magnaflow Exhaust, Isspro Gauges in an under cubby pod, Fumoto, V code front springs, Revo 285's and bubba lights
Sounds like they were unde - for the weight. I had the same problem years ago with a set of Bridgestones on my diesel Suburban. As I remember they installed some C rated tires when it called for D ratings at a minimum.
Marc
2000 Excursion Ltd 2WD, Build Date 9/30/99, Oxford White, Medium Parchment Leather, 6 disk CD Changer, 3.73 LS, Magnum Deflecta-Shield, Vent Shades Ford Rear Air Deflector, AC Mod, Home Made Tymar, More to come sooner or later!
Let us put an end, once and for all, to this discussion of what a good man should be - and be one. -Marcus Aurelius-
Politics is the art of looking for trouble, finding it, misdiagnosing it, and then misapplying the wrong remedies. -Groucho Marx-
They were E rated. So are the replacements, I made sure of that. My 1st Excursion had D rated and I replaced them with E and I could tell the difference when towing.
Thanks for the heads-up 'curly. I have an '05 with the B.F. Goodrich all-terrain tires and I checked them after reading this post. There are 13,000 miles on the clock and I don't see what you described. I bought the truck new and I have driven it every mile. I am very meticulous about maintenance and I will keep my eyes peeled. Thanks for the post. Craig.
2005 F-350 Superduty, 4X4, 6.0 diesel, sc, srw, lariat, B&W Turnover hitch, tow command, red.
2005 Excursion Eddie Bauer, 4X4, 6.0 diesel, 2nd row buckets, all the bells and whistles, Ford 30mm rear anti-sway bar, true blue/arizona beige.
I am hoping that my Problem was just an isolated incidence. I like the way the tires ride and their looks and they showed very little thread wear.
