Oil leak? - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Power Stroke Excursions
Old 02-25-2010, 12:58 PM   #1 (permalink)
Send a message via Yahoo to keith_1963
Oil leak?
When I scoot under my truck, say to change the oil, I always see that a black metal piece with a little birds mouth opening is wet with oil. Is this the vent spot that people mention that there is a mod for? Or do I have an oil leak?
2001 Excursion Limited. Tymar air filter. Marineco Mod, Oil change ball valve. FOR SALE.
keith_1963 is offline
Old 02-25-2010, 08:14 PM   #2 (permalink)
MotionMan's Avatar
I get the same small spot too, it is the cover for the torque converter, it could be a small leak at the rear main. Mine does not drip to the ground but it is there. I'm very impressed with the lack of oil leaks, I park on new concrete and I never have a drip of anything. So far it has been the only engine I have ever owned that does not leak. The boat engines are the worst. I could seal it in epoxy and the rear main would still leak.
2003 7.3 Excursion Limited Ultimate, Mineral Grey Metalic. DVD, Limited Slip, Badged, Cab Lights, Magnaflow, Thule Rack, Top Gun Bumper, 3" Lift, T Prodigy, Air Bags, Edge Programer, XM Radio, Extreme sound system. PIAA Lights, Toyo 325/60/18s on Chrome Alum rims.http://community.webshots.com/user/stellinm
MotionMan is offline
Old 02-26-2010, 12:21 AM   #3 (permalink)
There is also a drain for oil that gathers in the valley on the top of the engine. It is probably more common that the leak is on the top of the engine than the rear main.
There are few places that leak on top. The HPOP o-rings, turbo seals, and one more that is slipping my mind at the moment.
It isn't impossible for the rear main to be leaking, but it isn't very common.
steve
2000 7.3L PSD Excursion
4" MBRP 409 Turbo Back
Hellwig Swaybar
Isspro EV, Overhead 3-Gauge Mount
300K and rolling right along
Ford AIS
6.0 Liter Tranmission Cooler
BoilermakerSteve is offline
