Old 01-24-2005, 04:31 PM   #1 (permalink)
OIL LEAK
I have noticed that one of the tubes coming from the turbo up to the front has an oil leak. The tube that runs along side the engine on the passenger side up to the front between the battery and the radiator. The boot right there has a small oil drip. First off, should there be oil in that tube? Does this mean I have an oil leak at the pedestal? What kind of trouble will this cause? And as you will see by the next question how much I really know about this motor, What are the tubes and tell me how they actually work. Its ok to laugh since I am new to this segmant of the world, but am I sure glad I am part of the PSD number. So I ask alot of questions to gain more knowledge, so please hand in there with me.
2000 PSD Excursion Limited - best vehicle ever owned. Just upgraded to the PowerSlots Cryo Treated Rotors. CCV Mod - Zoodad Mod
hobhancock is offline
Old 01-24-2005, 08:34 PM   #2 (permalink)
Re: OIL LEAK
Mine has done this since we bought it new in 2000. I believe it is the intercooler tubes.
I talked the the guy that writes up the service on it. He says there is nothing to worry about and it doesn't hurt the efficiency of the engine.
Mine has started really leaking lately so I might have to crawl under it and see what is going on.
'00 Excursion LTD, PSD, Oxford White, Parchment Int, 6CD, 2nd Row Cap't chairs, Badges
'01 Sport Trac, Oxford White, Graphite Leather, V6 gasser, 4.10, loaded, no stinkin' badges
rfalcone is offline
Old 01-24-2005, 08:37 PM   #3 (permalink)
Re: OIL LEAK
My mechanic says that's caused by a dirty air filter. Forces the oil up and out the turbo and vent hoses. Not positive.
2002 4x4 7.3PSD Excursion, U-Codes, '03 Jounce Bumpers, Hellwig Sway Bar, Rancho 9000 shocks, Rancho Steering Stabilizer, Air-Lift rear air bags, Factory DVD, Driver side A-Pillar grab handle added, Rain-X wipersfront-24", rear-17"), riding on 285/75/R16 Bridgestone Revos.
IMartin is offline
Old 01-24-2005, 10:49 PM   #4 (permalink)
CHPMustang's Avatar
Re: OIL LEAK
If there's oil coming from around the boost tubes and boots after the turbo it's oil vapors from the Crankcase Valve,it's was designed into the system by International and Ford.
That stuff sure does make a mess after awhile if you don't clean the engine area regularly.
I did away with the prob by re-routing the CCV vapors from the air intake to open air,I removed all the intake tubes,boots,clamps and intercooler and gave it all a thorough cleaning inside out.
The compliment that is most enjoyed is "How do you keep it so clean?"
Another rule of thumb is if there's an oil leak or residue on the boots you may also be loosing some turbo compressor boost pressure at those locations,if left untreated the boots will eventually get soft and blow off if given the right conditions under acceleration,the accompanying noise from the engine area one never forgets.
Bill
2002 Ford Excursion 7.3L 4x4 XLT
9th Annual Powerstroke Rally this Oct 3-5 2008 in Caddo Mills,Texas
CLICK HERE for more Information & Register Here
CHPMustang is offline
Old 01-25-2005, 12:45 PM   #5 (permalink)
Re: OIL LEAK
Thanks. You know I have really been impressed with all your knowledge and the wonderful manner in which you respond to everyones questions. I have the pictures of your CCV mod but I havent got around to doing it. Now that I know this is what will help I will get the supplies. Sure wish we had hooked up back in Nov for the GM plant tour. Would have loved to have seen you X. I called a local dealer here and he told me basically the same thing, that it is common to do that but also to keep them clean would be a great help. Thanks again.
Old 01-25-2005, 12:47 PM   #6 (permalink)
Re: OIL LEAK
I have brand new AFE filter in. I was told that it was common for that to do it to help the lubrication of the turbo.
Old 01-25-2005, 01:09 PM   #7 (permalink)
Re: OIL LEAK
A real dirty air filter will cause more oil to be pulled into the air intake system from the crankcase vent. The engine wants air and it's got to come from somewhere.
Excursion Pics
2000 Excursion Limited 4x4 Dark Satin Green Arizona Beige 7.3 DIT, AXDO, 3.73 LS, DP Tuner F5, TERMINATOR II w R-IPR, Adjustable Boost Regulator, Turbomaster, EBPV Delete, Air Dog, ITP Regulated Fuel Return, Fuel Cooler, Tags 1&2, Harpooned Tank, Magnaflow XL Exhaust w Aeroturbine 4040L, Sonnax/Tricumulator, 8 Autometer Sport Comp 4 Gauge A Pillar 4 Gauge Overhead, Ford APCM, Crimestopper Remote Starter With Remote Fast Idle, Ford AIS w Zoodad, W Code Front Modified B Code Rear springs, Rancho RS9000X, Rancho 5406 Stabilizer, Hellwig Rear Sway Bar, BFG Rugged Trail TA, V10 Trans Cooler w Dual Electric Pusher Fans, Coolant Filter, IAH Delete, (((XM))) Line Of Fire Light, Ford Cab Lights, 05 Headlights w GOS Conversion Harness, Jimmi Jammers, 03 Lighted Painted Tow Mirrors w C-BETR, PSD Badges, Pullrite Hitch, Prodigy Brake Controller, Born 01/29/00
fordmastertech is offline
Old 01-25-2005, 01:21 PM   #8 (permalink)
CHPMustang's Avatar
Re: OIL LEAK
In my opinion the CCV vapors do more hurt than help when it comes to overall engine performance.
The turbo is internally lubricated via the engine oil which is why we get turbo pedestal leaks from time to time [img]/ubbthreads/images/graemlins/vulnerable.gif[/img] [img]/ubbthreads/images/graemlins/wink.gif[/img]
Bill
Old 01-25-2005, 10:32 PM   #9 (permalink)
Re: OIL LEAK
Bill
What do you use to clean the engine area and is there anything I need to watch out for when cleaning it?
Thanks, Tom
2002 Excursion 7.3L 4X4 Limited. "U" Code springs, Rancho 9000 shocks, BF Goodrich AT/ko 285/75/16, Trailer Tow Mirrors, Amsoil 5w30 Heavy Duty Oil and Amsoil filter, SilverStar Headlights, K40, Bright Box, Stage 1 AFE Pro Guard 7 Intake System, Predator OBDII Programmer, CatchAll Mats, XM Roady II, Garmin GPS 2610, Fumoto Valve, MBRP Exhaust, Hellwig Sway Bar, Viper 791 Alarm with Remote Start, Badged, ISSPRO EGT, Tranny, and Boost. TWO NEW INJECTORS COURTEST OF BROADWAY FORD IN ST LOUIS.
lauraandtom is offline
Old 01-25-2005, 11:49 PM   #10 (permalink)
CHPMustang's Avatar
Re: OIL LEAK
For cleaning the engine I'd use a light mix of simple green say 50:1 but I tend to stay on the safe side when using cleaners.
Make sure you cover the alternator and power steering pump filler cap car.
When cleaning on and around the boots use of a sponge may help loosen lift the oil residue,then just rinse off with garden hose spray and dry off everything with some terry towels to prevent spotting.
Once the engines clean the next time just a spray of the hose to knock off the dust and towel dry.
Bill
