Re: oil leaking from turbo pedestal
This 2C3Z-9P466-AB O-Ring Kit (Seal should take care of your leaking problem as long as the turbo pedestal isn't damaged too bad. As far as common, it happens on some.
Excursion Pics
2000 Excursion Limited 4x4 Dark Satin Green Arizona Beige 7.3 DIT, AXDO, 3.73 LS, DP Tuner F5, TERMINATOR II w R-IPR, Adjustable Boost Regulator, Turbomaster, EBPV Delete, Air Dog, ITP Regulated Fuel Return, Fuel Cooler, Tags 1&2, Harpooned Tank, Magnaflow XL Exhaust w Aeroturbine 4040L, Sonnax/Tricumulator, 8 Autometer Sport Comp 4 Gauge A Pillar 4 Gauge Overhead, Ford APCM, Crimestopper Remote Starter With Remote Fast Idle, Ford AIS w Zoodad, W Code Front Modified B Code Rear springs, Rancho RS9000X, Rancho 5406 Stabilizer, Hellwig Rear Sway Bar, BFG Rugged Trail TA, V10 Trans Cooler w Dual Electric Pusher Fans, Coolant Filter, IAH Delete, (((XM))) Line Of Fire Light, Ford Cab Lights, 05 Headlights w GOS Conversion Harness, Jimmi Jammers, 03 Lighted Painted Tow Mirrors w C-BETR, PSD Badges, Pullrite Hitch, Prodigy Brake Controller, Born 01/29/00
