Old 02-14-2003, 05:59 PM   #1 (permalink)
OK, what are your EGT's? loaded & empty
just want to compare what i am finding to those of yours.
thanks
Todd
2005 Midnight Blue Dodge Magnum RT...Yeah, it's got a Hemi!
TRADED 2000 "X" Limited, 4x4, Superlift 6", ProComp 35/12.5/16 Mud Terrains. Two Time Member: CPS F.O.R.D. club. water pump replaced at 51K.
4 SALE: 1996 Impala SS, Dark Green/Grey Metalic, 77K, Bridgestone Potenza RE730's, Dynamax's W/stainless tailpipes, 3:73's
Todd T is offline
Old 02-15-2003, 05:08 PM   #2 (permalink)
Re: OK, what are your EGT's? loaded & empty
Unloaded, flat interstate, 65-70mph I'm seeing 500-550.
Towing, flat interstate, 65mph I'm seeing 850.
Regards,
Dave
2002 Excursion Limited - 7.3 PSD, 4x4, Auto. Tekonsha Prodigy Controller. ISSPRO EV Gauges in A-Pillar mount. Diesel Turbo Lifesaver. Pre-pump Mod. SCMT-Trimode. AIC. Back Door storage bins. Banks 3 1/2 inch Monster Exhaust. AIS. "U-Code" Springs. Powerstroker Exhaust Brake. Husky Liners. Bilstein Shocks. ART Brakes, Helwig Rear Anti-swaybar. Zoodad Mod. Airlift Rear Airbags. Racor 3550 CCV. Forest River Wildcat 26FBS TT.
2003 VW Jetta TDI - completely stock and 49mpg!
2003 Kubota B2910
dmftoy1 is offline
Old 02-16-2003, 10:14 AM   #3 (permalink)
Todd,
The posted numbers compare very close with mine. Towing at 70 will range from 850 to 900. 70 mph cruise is 500-550.
Michael
2001 Excursion PSD Limited 4x4, SCMT Max Tuner, Diesel Innovations 4" exhaust, 3 pod A-pillar w/ VDO Vision boost, pyro & Trans, AIC, Baldwin bypass filter, ATS Ported Compressor housing...See my mod pictures HERE!
1995 Camaro Z28 K&N FIPK, Throttle body Airfoil, Jet-Hot MAC Headers, Borla SS 3 exhaust /w bypass, 3.5" Aluminum driveshaft, 4:10 Gears, B&M Ripper shifter, Accel 300+ ignition, Accel SpiralCore wires, Shift light, 100hp Nitrous [img]/ubbthreads/images/graemlins/crazy.gif[/img] <font color="red"> FOR SALE! </font>
2002 32' Keystone Bobcat 294BHS travel trailer
PSDExcursion is offline
Old 02-16-2003, 02:33 PM   #4 (permalink)
Hmmm....... typical is 800 - I may see 700 with a tailwind - of course, I am usually going 80 mph - never seen as low as 500 unless I am slowing down...... towing is around 900 - 1000 [img]/ubbthreads/images/graemlins/rolleyes.gif[/img]
I have the EBM2 code - maybe my problem? seems I am slightly hotter than some [img]/ubbthreads/images/graemlins/shrug.gif[/img]
2001 'X' Ltd 4x4 - 4" exhaust/TS Performance 3 position flip chip/Triple gauge pillar mount/K&N air filter/rebuilt and upgraded TC and transmission (local guru)/grill guard/front lighted logo/superduty grill/Lund screen front/clear corners/cowl induction hood/ Hella 550s / X code front springs / Add-a-leaf rear springs / Powershot 2000 / Evans NPG+ Coolant / Rancho RS9000X / http://www.webshots.com/search?query=beastdriver&new=1
A Rusch is offline
Old 02-17-2003, 09:44 AM   #5 (permalink)
thanks gang, i am seeing about the same. 550 @ 60 up to 750 @ 75 empty. it'll hit about 1050 in a 1/4 mile run @ WOT. i was surprised at that, i figured it would run hotter @ WOT. i can peg 1600 in the Dodge if i don't let off.
i havent towed with it again, yet.
Todd T is offline
Old 02-18-2003, 11:12 AM   #6 (permalink)
If I get a LONG stretch of road that is level. I'll see just below 600F pre-turbo at 70 mph unloaded. I haven't towed with it since I got the gauges in.
Those temps should come down a bit when I get my injectors re-worked at the end of March.
2001 Black Excursion, 4x4, XLT, PSD, LS, (EBM2), Super-Duty grill, 4" MBRP exhaust, Bilsteins, X-springs, OilGuard bypass filter, 295's, Badges, Suvlights harness, APC headlights, Weatherboots, Centramatics, Clear corners, AIC w/ITP mount, ISSPRO EVs, BTS trans, Open element intake, ATS compressor housing, Thule rack, BD Torqloc, F350 rear blocks, Randy Ellis lightbar with a couple of Lightforce 170s, Front receiver hitch, DP Tuner chip
1975 Ford Bronco, neglected since I bought the Excursion
AJ'sDad is offline
Old 02-18-2003, 11:40 AM   #7 (permalink)
My Photos: (11)
Unloaded at 75-80 I get between 550-600 degrees, about 6-7psi boost. Loaded (5000lb of open trailer w/car) it's about 650-700 degrees at bout 7ps at 75. Hills and headwinds to make them creep up to 750 sometimes.
2002 PSD Excursion 2WD, VDO guages, PPIII, pre-pump and tank mods, ZooDad, 4" exhaustw/ Magnaflow muffler and downpipe, Bilsteins, Hellwig bar, Air Lift rear bags, monochrome SD grille and bumpers, 20" Weld Velociti 8's
swhitney is offline
