OVERHEATING PROBLEM...HELP - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Power Stroke Excursions
Old 06-18-2001, 08:19 PM   #1 (permalink)
I just bought a 2001 Excursion. Today it overheated to the point of shutting itself off. It only has 1081 miles on it. Has anybody had this problem? [img]images/icons/crazy.gif[/img]
Does anyone know what long term damage this may cause?
2001 Excusion PSD White/Silver, 2X, 40/20/40 bench, Bone Stock, except tint front windows and SAVE GLAMIS sticker on rear window.
sandman 36 is offline
Old 06-18-2001, 09:57 PM   #2 (permalink)
Re: OVERHEATING PROBLEM...HELP
How long have you had it? maybe the t-stat is not opening. Well could be several things including the t-stat: water level, water pump,fan clutch/clutch circuit. It could also be a faulty temp sensor saying its hot when its not. Too bad you have problems already, we've got 1,500 on ours. It had 35 miles on it when I got it. It seemed to run like crap for a little while but I think that was fuel related. I'm only getting 14 mpg also, I was thinking It was going to be better!
2001 PSD Excursion 4x4 Toreador Red, W code front springs, and at least one bad injector.
2001 E350 PSD cuttaway, 15' body with 2,000lb waltco liftgate, runs like a sewing machine.
2002 Toyota Xtracab Taco
31' Mallard travel trailer.
Worm is offline
Old 06-19-2001, 09:56 PM   #3 (permalink)
Worm,
Hang on -- it gets better. We started out with 10-12 mpg. It gradually rose over time to 14-15-16-17-18-19-20mpg. Make sure you count by the old fashioned manual method. As a check you can use the mpg guage but make sure you reset it with each fill up.
2000 Excursion LTD 4x4, Oxford White, PSD 3.73,K&N, PPIII, Dynomax, Ramsey Winch Mount/Grill/Brush Guard, Edelbrocks, Rancho SS, Hellwig Stabilizer, PIAA 90 PRO XT Lights, 295 BFG's, X springs, 2000 F350 CC PSD 4x4 Woodland Green, 3.73 K&N, PPIII, 295 BFG's, Edelbrocks
POLR BR is offline
