Owners with 285's or 295's - Feedback Solicited Please
Hey gang:
I'm thinking of making the switch to 285's (not sure what brand) or the Nitto Terra Grappler 295(3415 load rating-same as 265 E's). I'd like some feedback as to how you like your upgraded tire size. A few questions:
Speedo recallibrated?
Impact on tranny (shift points)
Impact on braking?
Impact on mileage?
Sidewall stength/flex?
Would any of you go back to 265's?
Thanks in advance.
2002 4x4 7.3PSD Excursion, U-Codes, '03 Jounce Bumpers, Hellwig Sway Bar, Rancho 9000 shocks, Rancho Steering Stabilizer, Air-Lift rear air bags, Factory DVD, Driver side A-Pillar grab handle added, Rain-X wipersfront-24", rear-17"), riding on 285/75/R16 Bridgestone Revos.
Re: Owners with 285's or 295's - Feedback Solicited Please
285s
Fit fine
Ride Fine
Look great Like stock+
They put the speedo about right on however the Odometer is about 2% off
No difference percieved in breaking
Improved handling, but more the tire than the size I think
Over all the Revos have not had a bad review I know of and your chances of getting them are improved since it is BridgeStone/Firestone product
And the spare cover will fit.
Bruce
2005 X PSD Limited Mineral Grey, 4X4 Has Second row bench then Every other factory option available. Under Construction
4x2 Lift Gate Lifts,
Tekonsha Prodigy
Ford 30MM Rear Bar
Catch All Linners
750 W Inverter
06 Chrome Package Grill,bumpers and hooks. After an encounter with a Honda, (She got the ticket) 2005 Ex and Specs and Pictures of 2002 X
While the 285's fit fine and look great, my 2001 7.3 PSD does not have the acceleration as with the standard 265's and my milage went down. So - at my next tire change I'm going back to the 265's. Now my brand new 2004 6.0 rocks - it's sooooo fast I'm constantly doing 90 and don't know till I check the speedo - I think this truck will have no problem's going to 285's.
Thanks guys. Went to install 295's and they rubbed on hard left turn. Measuring with stock 265's, with wheel turned hard left the tire and fender liner have .75-.8 inches of clearance. A 285 will eat up .65 of that since the tire is 1.3 inches bigger in overall diameter thus leaving .10 -.20 inches of clearance. That's not much at all. You guys with 285's have not rubbed at all? Are you sure?
BFG's AT's 285 with "U"codes (if that makes a difference) No, Zero, Notta rub. I spend I long time washing and cleaning the fender wells everytime I was the truck, and I have not noticed any rubbing.
I have however noticed a little difference in break pedal feel. I think it is all in my head cause there is only 6.38# difference between a Firebomb 265 E and these tires.
In doing a little more research I found that my right side front fender well has 2" (almost 1.75" more clearance) between tire and fender liner at hard right turn. I think I can pull back the liner a tad bit and secure it out of the way to ensure clearance of 285's. I know the truck looks better with 285s on.
DUDE, go get the Revo's. LOL [img]/ubbthreads/images/graemlins/laugh.gif[/img] [img]/ubbthreads/images/graemlins/laugh.gif[/img]
Yep, if mine are even near half gone this fall I will get another set "for the winter" then swap back.
Tekonsha Prodigy
Ford 30MM Rear Bar
Catch All Linners
750 W Inverter
I have 285 Coopers and don't rub but I have a 3" lift. I am ready to get 315s on different rims. I hope they don't rub.
Some people are like Slinkys. They are good for nothing but still put a smile on your face when you push them down a flight of stairs. 2003 X Limited Ultimate, Mineral Grey Metalic. DVD, Limited Slip, Badged, Cab Lights, Magnaflow, Thule Rack, 3" Lift, T Prodigy, Air Bags, Edge Programer, XM Radio, Extreme sound system. 315/70/17s on AR Chrome/Aluminium.http://community.webshots.com/user/stellinm
I put 285 LTX M/S Michelins on recently- replacing the Firebombs just before the recall :-( - and they made an *incredible* difference. I highly recommend them. But they did rub on the left fender well [under your foot]. It seems the the parking brake cable loops behind it and creates less clearance.
Three attempts reshaping the plastic with a heat gun, and the problem is solved. Definitely worth the trouble. 'Still considering a 2" lift though...
I have 285 Toyo's on my 01 EX 4x4. It was told to me by Discount Tire that they were the exact same tire as Nitto's. I'm at stock height and had a little rub on the optional Ford mud flap, right side only. Heat gun fix, no problem. cliffsurfs
Cdub:
You hit the nail on the head. The brake cable is the reason the liner is pushed out a bit reducing clearance. I'm going to pull that liner back and secure it a bit to make the clearance. Thanks.
Bruce: How are you? I hope you are doing well.
I'm a little late in the posting on this thread but we did upgrade from the stock 265's to the BFG TKO 285's white lettered out.
Our speedometer is actually more accurate than with the 265's,I verified my speedo via Garmin GPS which was right on the number therefor no recal was needed even tho Ryan offered the service while in Phoenix last January.
Tranny shifting points are about the same if not better for my liking.
Braking takes a little more advance pedaling but not much as I'm a turtle anyways [img]/ubbthreads/images/graemlins/smile.gif[/img]
Mileage has been 16-18 around town and freeway is stying 19-22+ mpg depending if the NHRA bride drivies or I.
The sidewalls seem to be well built and not much flex compared to the stockers,the truck's ride and handling is much better when towing on the 285's.
Going back to 265's would be no big deal it's just the truck would look funny with little tires [img]/ubbthreads/images/graemlins/grin.gif[/img]
BILL
__________________ 2002 Ford Excursion 7.3L 4x4 XLT 9th Annual Powerstroke Rally this Oct 3-5 2008 in Caddo Mills,Texas CLICK HERE for more Information & Register Here
I'm expecting the same thing speedo wise. Against GPS, my speedo is about 2.0 mph off (on the high side). At 70mph on speedo, GPS says 68. 285's ought to fix that. Having 285 Revo's installed tomorrow. [img]/ubbthreads/images/graemlins/warmsmile.gif[/img]
