Old 10-09-2007, 11:32 PM   #1 (permalink)
A-Pillar Gauges
I'm going to get started with my mods on the '02- we rarely use our SUV during the winter since it's used mainly for summer vacations to Canada and boat pulling, so the upcoming months will bring a lot of projects, (and money spent)I'll probably be bothering you guys from time to time..... [img]/forums/images/%%GRAEMLIN_URL%%/smile.gif[/img]
I had a 3-guage pillar setup on my '00 Excursion Limited- trans, pyro, and boost from Western Diesel. I'm thinking about doing a 4-gauge on this Ex, and wondered what your opinions were on doing this, and what the 4th should be. I'm leaning a little toward a voltmeter, since Ford took that away with their crap trans gauge, and would probably mount it in the top position since that is going to be the hardest to see. I think they're going to be Isspro- I like the looks of the DiPricol Optix better, but have heard problems with them fading, something I won't tolerate.
Anyone gone this route? All opinions welcome!
Jim
2002 Excursion Limited Ultimate 4x4 in black w/ all the goodies-DVD & lmtd slip. 285 BFG's, muffler delete, DIY Tymar, 2x4 glass lifts, otherwise bone stock (for now)
jafo is offline
Old 10-10-2007, 01:14 AM   #2 (permalink)
FamilyRide's Avatar
Re: A-Pillar Gauges
I'd like to have an oil temp gauge added to my 3.
2004 EB Excursion, 4x4, 6.0, everything but step tubes and 2nd row chairs, Magnaflow Exhaust, Isspro Gauges in an under cubby pod, Fumoto sitting on V Codes and Revo 285's.
FamilyRide is offline
Old 10-10-2007, 11:36 AM   #3 (permalink)
Re: A-Pillar Gauges
My vote is X monitor flushed into the OEM radio position. That frees up room to add more gauges under the instrument display down the road. It is also very stealth and is not a visible hinderance like the A pillars.
Tx
2001 X, 4x4, White, Limited, PSD,. Oil Guard, Stull 6099 Grille, AFE Intake, X Monitor, Sonnax/Tricumulator, Mobil 1 ATF w/Racor tranny filter, DieselPower Custom Burn Chip, Walker BTM, W Code Frt Springs, Procomp Add-a-Leaf Rear, Rancho 9000's w/5406 SS. Pics @ http://community.webshots.com/user/txangler32
TXANGLER is offline
Old 10-11-2007, 12:21 AM   #4 (permalink)
Re: A-Pillar Gauges
I went with oil pressure and a real temp guage on my quad pod. The temp gauge mainly cuz I' running a 2 tank veggie system. But I think having real gauges no matter what you are running is worth it.
2003 Excursion 4x4 - 7.3 liter -
ajohansson is offline
Old 10-17-2007, 10:37 AM   #5 (permalink)
CSIPSD's Avatar
My Photos: (52)
Re: A-Pillar Gauges
The most important gauge to add to the normal 3 is fuel pressure... Nothing can leave you on the side of the road quicker then a dead or dieing fuel pump... Of all 16 I have... Volts is one I could give up if I had to...
The wifes X has the overhead pod with pyro, boost, tranny and fuel pressure... Looks great!
05/01 F-250 PSD, 125,000 miles, Zoodad, AFE Stage 2, CCV mod, Turbonetics Ball Bearing, Turbo-Master wastegate, Dieselsite's boots, 6.0 IC,Water Injection, AIH delete,ITP Regulator,DP and Wildman tunes,GTS Hybrid injectors, ITP Fuel system,Studs, 910 valve springs,Suncoast 4r100,MBRP T-409 duals,Aeroturbine, 6" tips, 16 Isspro gauge's, 100g fuel tank, 05 mirrors with recon lens, 4" Revtek lift 37-13.50-17 Toyo MT's
ME!
MY PICTURES
CSIPSD is offline
