There's an adjustment nut on top of the steering box that can be checked.
Here's a THREAD from this past October that might be of some help [img]/ubbthreads/images/graemlins/cool.gif[/img]
Bill
__________________ 2002 Ford Excursion 7.3L 4x4 XLT 9th Annual Powerstroke Rally this Oct 3-5 2008 in Caddo Mills,Texas CLICK HERE for more Information & Register Here
After reading the post don't know if I should tighten or loosen the steering box adjustment? Where should I start??? One more question should I have the tranny serviced or just leave it alone???? I've heard so many people having trouble after service. What has been your experience. Many Thanks
[/ QUOTE ] If the steering box is loose tighten it by turning the adjustment screw down. Make sure you check the rest of the front end by looking for loose parts while someone is turning the wheel a little back and forth, the trucks front tires have to be on the ground to do this. I have found the drag link loose at the pitman arm off the steering box causing weird steering issues and play along with other worn parts.
As far as the transmission, I would service it if it fails after it would have sooner of later anyways. I recommend flushing it or the methods used on TDS. With 53K on it I would not worry about it.
__________________ Excursion Pics
2000 Excursion Limited 4x4 Dark Satin Green Arizona Beige 7.3 DIT, AXDO, 3.73 LS, DP Tuner F5, TERMINATOR II w R-IPR, Adjustable Boost Regulator, Turbomaster, EBPV Delete, Air Dog, ITP Regulated Fuel Return, Fuel Cooler, Tags 1&2, Harpooned Tank, Magnaflow XL Exhaust w Aeroturbine 4040L, Sonnax/Tricumulator, 8 Autometer Sport Comp 4 Gauge A Pillar 4 Gauge Overhead, Ford APCM, Crimestopper Remote Starter With Remote Fast Idle, Ford AIS w Zoodad, W Code Front Modified B Code Rear springs, Rancho RS9000X, Rancho 5406 Stabilizer, Hellwig Rear Sway Bar, BFG Rugged Trail TA, V10 Trans Cooler w Dual Electric Pusher Fans, Coolant Filter, IAH Delete, (((XM))) Line Of Fire Light, Ford Cab Lights, 05 Headlights w GOS Conversion Harness, Jimmi Jammers, 03 Lighted Painted Tow Mirrors w C-BETR, PSD Badges, Pullrite Hitch, Prodigy Brake Controller, Born 01/29/00
Can any adjustments be made to the drag link at the pitman arm off the steering box if this is the case? If I adjust the steering box I loosen the nut first and the tighten the hex head adjustment screw then tighten the nut? Sorry to keep on asking questions I just want to be sure of what I'm doing.
[/ QUOTE ] No problem on asking the questions, thats what we are here for.
Yes the steering box adjustment is like you describe, just don't go to tight a little at a time is all you need.
The only adjustment for a loose drag link is to replace it.
FMT
Hey 01EX, Is your problem actually excessive steering wheel play, or are you trying to remedy the Excursion's common wandering ailment? The replies above have done well at addressing steering wheel play, but the wandering ailment originates from the Excursion's weak rear leaf springs. The weak springs allow unequal axle-wrap, and the rear axle ends up steering you unexpectedly.
I feel like it's excessive steering wheel play but I could be wrong. The X didn't do this when I bought it in Sept 04 it's something that started about 1 month ago. I will make small adjustment sometime this week and let you know. Can someone tell me how much the pittman arm is and if I can replace it myself.
You don't need the pitman arm, Its just a chunk of steel with a tapered hole for the drag link short end to connect up to. The only time I ever replace this type of pitman arm is when the tapered hole is worn from the drag link nut loosening up or when the vehicle gets whacked and twists the splines on the sector shaft.
Have someone slightly turn the steering wheel like I described in my earlier post to check for excessive play. You could have the rear end spring issue but You were asking about "play in the steering" not why is my X all over the road. I don't want to see you spend your money on something you should not need.
FMT
....the Excursion's common wandering ailment?
"Common ailment" may be misleading. Some trucks wander. Out of those, most are steering related (same as SD's) I'd go as far as to say most others, ride and drive straight and solid. I'm lucky and have one of the later. [img]/ubbthreads/images/graemlins/laugh.gif[/img]
I am not sure yet that I buy into the weak rear springs on the X, I do agree they are low and do not have travel, boy does that sound familiar!
Acourding to ford the X has stiffer springs in the rear than even a 350 DRW
Here are the numbers
Excursion G code is 410#
A code = I do not know could just be the B W/O the overload
B code = 320#/" and is 2.94 thick 5 leaf OL rate is 670 For SRW
c code = 350#/" and is 2.32 thick 5 leaf OL is 730 this is for DRW
Bruce
2005 X PSD Limited Mineral Grey, 4X4 Has Second row bench then Every other factory option available. Under Construction
4x2 Lift Gate Lifts,
Tekonsha Prodigy
Ford 30MM Rear Bar
Catch All Linners
750 W Inverter
06 Chrome Package Grill,bumpers and hooks. After an encounter with a Honda, (She got the ticket) 2005 Ex and Specs and Pictures of 2002 X
2002 Excursion LTD(PCM:NQW5)Pheltech Tru-Cowl Induction Hood BTS transmission ITP fuel system, 38/15.5/20 Toyo's on Weld 12" wide wheels,15k warn and warn 9.5k rear 4:56's ARB air lockers front and rear. Trail ready front bumper,Road Armor rear bumper light force driving lights, PIAA backup lights,Dakota digital gages, F5 DP tuner chip,Hypermax stage 2 injectors,4" exhaust, 11" Edge lift, King shocks, edge crossover steering, ORU ram assist steering
Fabtech ladder bars,TN turbo, Dynatrac conversion kit. Alpine F1, Zapco amps. two dc1100.1, three dc1000.4, 1 dc750.2, driving seas reference series front stage and Zapco competition rear fill and 2 Jl audio 13w7 subs
AP Racing big brakes, Amp Research running boards
DEATH TO 2 MILE WIDE URL'S. THEY ARE DESTROYING THREADS EVERYWHERE
1 word........... "URL" link under "Instant UUB Code". [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
Coldair Bad member no Donut [img]/ubbthreads/images/graemlins/grin.gif[/img]
The THREAD using UBB code [img]/ubbthreads/images/graemlins/wink.gif[/img]
