PLEASE HELP!! Driver window controls not working!! - Diesel Forum - TheDieselStop.com
post #1 of 9 (permalink) Old 02-10-2011, 03:34 PM Thread Starter
I have no working controls for both driver and front passenger windows. However I do have working controls for the rear passenger windows. I have replaced the master control switch and still the same issue. I have lost my owners manual so I dont know what to look for under the dash at the fuse box.
Any suggestions as to what I should look for or to replace. Summer is coming and I want to be able to role the drivers window down!
Thank you in advance
T
Tikler is offline
post #2 of 9 (permalink) Old 02-11-2011, 11:56 AM
MotionMan's Avatar
This may sound simple but try turning your lights on and off, sometimes this happens to me and this fixes it.
2003 7.3 Excursion Limited Ultimate, Mineral Grey Metalic. DVD, Limited Slip, Badged, Cab Lights, Magnaflow, Thule Rack, Top Gun Bumper, 3" Lift, T Prodigy, Air Bags, Edge Programer, XM Radio, Extreme sound system. PIAA Lights, Toyo 325/60/18s on Chrome Alum rims.
MotionMan is offline
post #3 of 9 (permalink) Old 02-11-2011, 07:18 PM
rock_doctor's Avatar
Owners manuals can be downloaded here. Good luck
rock_doctor is offline
post #4 of 9 (permalink) Old 02-12-2011, 11:17 AM Thread Starter
@MotionMan, I tried the lights and it didn't work. Thanks anyway.
@ rock doctor, Thank you for that link.
Looking at the manual it isn't telling me anything about the switch not working. It doesn't show fuse for the window switch only has a fuse for the window motors which aren't the issue because the front passenger window can be rolled down from the passenger side. I'll still check it to see and will post my findings.
Tikler is offline
post #5 of 9 (permalink) Old 02-12-2011, 02:12 PM Thread Starter
No luck, the manual only shows fuse 601 for power window motors. I removed it and windows were unable to be rolled down from passenger doors. Not sure where the next point of failure could be.
Tikler is offline
post #6 of 9 (permalink) Old 02-12-2011, 02:42 PM
I wonder if the gem is dieing on you. Post this again in the 6.0 or 7.3 forum depending on the year of the truck. I would suspect the window wiring is similar enough to the crew cabs that they may be able to help you. good luck
7.3 = 2000-2003
6.0 = 2003-2005
post #7 of 9 (permalink) Old 02-15-2011, 01:18 AM Thread Starter
Thanks again Rock doctor. I've got one other possibility, I have a remote start alarm with the ability to roll down the windows with the remote. I think the transponder that controls the windows is faulty. Ive got my alarm guy coming to look at it. Thanks again for your time and patience. If the problem persists I will go to the other forum
Peace!
Tikler is offline
post #8 of 9 (permalink) Old 02-15-2011, 09:33 AM
Good luck, let us know in case somebody else has the same problem and finds this thread though the search engine.
post #9 of 9 (permalink) Old 02-16-2011, 05:50 PM
STMPDUST's Avatar
had the same problem, here is what fixed it, took the control switch out and sprayed it down real good with WD 40 took the air hose and blew it out , reinstalled and windows worked perfect again!
2015 KR Dually CC 4X4 Bronze Fire HC
2011 KR Dually CC 4X4 Royal Red
2005 Eddie Bauer Excursion 4X4 ,White
STMPDUST is offline
  Diesel Forum - TheDieselStop.com > Ford Diesels > Power Stroke Excursions
